查看: 3659|回复: 0
PADS2007的元件制止的错误的修改
发表于 2008-8-5 23:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
pads2007做元件时定义PIN时检查时的错误.那位有这方面的资料 ,这里有重NAME ,但元件上是这样的9 V/ p' L: k2 z! f- N* i, u
Error: Gate A Decal NEW_PART has 124 terminals but gate definition has 95 pins.
  k! d8 P9 n! z! }Warning: Duplicate pin name (OPEN) for pin number B50 on Gate A.
% t; E; o) n% D8 ?; t) G- e) z: mWarning: Duplicate pin name +3.3V for pin number A45 on Gate A.
5 }; X/ S* A* uWarning: Duplicate pin name +3.3V for pin number B41 on Gate A.
2 ?- x; v( R6 f: Q+ d9 k. W5 EWarning: Duplicate pin name +3.3V for pin number A21 on Gate A., c4 {3 D' {5 s+ `/ g2 ^
Warning: Duplicate pin name +3.3V for pin number B54 on Gate A.: R! p# R. u1 ]; ]
Warning: Duplicate pin name +3.3V for pin number A27 on Gate A.6 H3 E; ~$ z- I
Warning: Duplicate pin name +3.3V for pin number A39 on Gate A.
+ d3 v9 B  J+ h  m- ~2 L/ Q4 ~Warning: Duplicate pin name +3.3V for pin number B43 on Gate A.9 q, S: ~# _$ b. d5 l: ?/ I
Warning: Duplicate pin name +3.3V for pin number B36 on Gate A.
& ~" q  k, [. x0 i. W( mWarning: Duplicate pin name +3.3V for pin number A33 on Gate A., _& i1 l1 n* A- r) o' B
Warning: Duplicate pin name +3.3V for pin number B25 on Gate A.( S( j; o* D* J4 \% j8 |
Warning: Duplicate pin name +3.3V for pin number A46 on Gate A.' e7 t) v4 z$ w$ s- [( A2 p( @
Warning: Duplicate pin name +5V for pin number A8 on Gate A.
9 R, ^( W9 H; MWarning: Duplicate pin name +5V for pin number B5 on Gate A.
7 d3 i3 ?& O8 c6 z; l7 e3 eWarning: Duplicate pin name +5V for pin number B62 on Gate A.2 ~" Z) h4 z( S. T1 s
Warning: Duplicate pin name +5V for pin number B61 on Gate A.- _. t) x9 ~. b4 _) Y5 k
Warning: Duplicate pin name AD24 for pin number A25 on Gate A.! F- q4 ~% a) E9 I4 e- L3 H8 L8 j
Warning: Duplicate pin name CONNECTOR_KEY for pin number A12 on Gate A.
( x5 C4 a& ]! A2 tWarning: Duplicate pin name GND for pin number B49 on Gate A.2 }8 N5 S1 O7 r" x! U
Warning: Duplicate pin name GROUND for pin number A42 on Gate A.
4 l3 K0 C& t. i& k* k; y5 L# r4 ~Warning: Duplicate pin name GROUND for pin number B38 on Gate A.- E0 k7 W) X) e8 I' R
Warning: Duplicate pin name GROUND for pin number A37 on Gate A.' M* a/ N* @& K# d
Warning: Duplicate pin name GROUND for pin number A35 on Gate A.2 [2 \/ x# W  u: E: J* I
Warning: Duplicate pin name GROUND for pin number A30 on Gate A.
1 G' P" v2 V2 {. L' SWarning: Duplicate pin name GROUND for pin number B15 on Gate A.
( F+ @# t+ e. M, H, L4 u9 ?Warning: Duplicate pin name GROUND for pin number A24 on Gate A." U+ }' \/ y* v0 w
Warning: Duplicate pin name GROUND for pin number B17 on Gate A.
0 g6 z3 }( n1 l5 VWarning: Duplicate pin name GROUND for pin number B28 on Gate A.
7 y, W! [7 i0 u0 i' v' C( q9 MWarning: Duplicate pin name GROUND for pin number B22 on Gate A.
. r8 U9 r% b7 P! r" f6 N' _Warning: Duplicate pin name GROUND for pin number A18 on Gate A.
  s6 k9 N& N; Z7 EWarning: Duplicate pin name GROUND for pin number B46 on Gate A.
& w  V$ E& j0 u* ~# RWarning: Duplicate pin name RESERVED for pin number A14 on Gate A.0 E7 R/ ^6 I1 |7 `4 n
Warning: Duplicate pin name RESERVED for pin number A9` on Gate A.$ _, V& u% i9 x. n. ?
Warning: Duplicate pin name RESERVED for pin number A11 on Gate A.7 h% U; l, P$ F1 z* ~2 C7 D
Warning: Duplicate pin name RESERVED for pin number A19 on Gate A.
0 ^8 x0 ~4 _' V5 QWarning: Duplicate pin name VCCIO for pin number B59 on Gate A./ [! f% G& s% K9 M; e( _
Warning: Duplicate pin name VCCIO for pin number A10 on Gate A.
% B7 Q* t8 ~4 C$ P* M8 IWarning: Duplicate pin name VCCIO for pin number B19 on Gate A.
* r9 A  l% n; }2 e3 H  Q. i  HWarning: Pin number A51 not defined in PCB decal PCI-62.. ?% d+ w  e) _: ^& S
Warning: Pin number A50 not defined in PCB decal PCI-62.
7 t2 y3 E  g2 {4 o4 \% jWarning: Pin number A45 not defined in PCB decal PCI-62.# ]0 c: n+ h9 \( R; J! J
Warning: Pin number A21 not defined in PCB decal PCI-62./ d* |* L+ k( C( ^; A7 V
Warning: Pin number A27 not defined in PCB decal PCI-62.$ Y) P. Y8 B  q3 T6 i
Warning: Pin number A39 not defined in PCB decal PCI-62.
+ }; O$ e  U2 _( `' MWarning: Pin number A33 not defined in PCB decal PCI-62.# v' e$ r" T2 `4 ^6 S" p2 ^0 u' b) Q
Warning: Pin number A46 not defined in PCB decal PCI-62.4 U; S9 }$ U9 l0 {$ F
Warning: Pin number A5 not defined in PCB decal PCI-62.  o7 h0 H, T: G0 S: ~) F
Warning: Pin number A8 not defined in PCB decal PCI-62.
, K+ I( ~4 h+ L: hWarning: Pin number A2 not defined in PCB decal PCI-62.0 E1 m. y: l! q# m5 m8 D2 c
Warning: Pin number A53 not defined in PCB decal PCI-62.6 {8 S  T. a2 ]# g# p3 D' X4 n& S
Warning: Pin number A58 not defined in PCB decal PCI-62.
: A. W# ?7 j1 Y& V" s2 L! WWarning: Pin number A57 not defined in PCB decal PCI-62.
% B* d$ F/ k6 D0 a, c7 a5 qWarning: Pin number A55 not defined in PCB decal PCI-62.. r/ n0 s' |9 r' d3 U( S  s. c
Warning: Pin number A54 not defined in PCB decal PCI-62.: ?/ ]# O9 _$ a1 C& n' R3 r( W
Warning: Pin number A47 not defined in PCB decal PCI-62.
$ e) |8 J+ d! n! eWarning: Pin number A44 not defined in PCB decal PCI-62.0 m. Y1 H4 n& k' k9 O9 h. c+ l
Warning: Pin number A32 not defined in PCB decal PCI-62.9 U: A3 K2 B2 S8 I% u
Warning: Pin number A31 not defined in PCB decal PCI-62." h8 a6 p' V" Q( a. x0 K1 `  [
Warning: Pin number A28 not defined in PCB decal PCI-62.
' y6 w, a# k6 J9 ~! ~$ gWarning: Pin number A29 not defined in PCB decal PCI-62.4 c7 `# s" i  {% |7 d7 Z6 N
Warning: Pin number A25 not defined in PCB decal PCI-62.
# Y* I! {1 f+ `1 W* N4 zWarning: Pin number A23 not defined in PCB decal PCI-62.0 h6 e$ @4 @) R' l
Warning: Pin number A22 not defined in PCB decal PCI-62." j" |+ l) l+ `2 {9 n" t
Warning: Pin number A20 not defined in PCB decal PCI-62.( m3 \  F- f- y/ `: ^# ~  K' W
Warning: Pin number A52 not defined in PCB decal PCI-62.
$ r! u4 T) C8 ]  r0 k: l' E# k5 FWarning: Pin number A13 not defined in PCB decal PCI-62.
- S6 p2 C. A* ^' |$ \& PWarning: Pin number A12 not defined in PCB decal PCI-62.( j. e, a; U4 r, ?/ ~- l
Warning: Pin number A34 not defined in PCB decal PCI-62.; c* Q! ~: F% n5 a5 Q' t* x9 G7 Y
Warning: Pin number A17 not defined in PCB decal PCI-62.- m+ f; F: E: }  ?) T8 v
Warning: Pin number A42 not defined in PCB decal PCI-62.
' M) h7 c2 G$ z4 B% w1 d: e9 IWarning: Pin number A37 not defined in PCB decal PCI-62." R# M7 E: U0 Z' j
Warning: Pin number A35 not defined in PCB decal PCI-62.
! u; `5 L$ w: w: j* oWarning: Pin number A30 not defined in PCB decal PCI-62.
& z! T. F- I, A6 g) x' V. _Warning: Pin number A24 not defined in PCB decal PCI-62.
9 |: P% r; E! Y( g4 y8 L( Z3 vWarning: Pin number A18 not defined in PCB decal PCI-62.$ `0 I5 y6 D: F
Warning: Pin number A48 not defined in PCB decal PCI-62.
8 s  E5 \; [3 q9 s4 D, q! I2 z7 K$ ZWarning: Pin number A49 not defined in PCB decal PCI-62.) r! X+ P3 F1 m" f; z8 D2 E
Warning: Pin number A56 not defined in PCB decal PCI-62.
9 h9 b1 f* [) |; t; E9 CWarning: Pin number A26 not defined in PCB decal PCI-62.
2 g2 @* P, ?- O( k8 cWarning: Pin number A6 not defined in PCB decal PCI-62.
& b8 S( P1 }& oWarning: Pin number A7 not defined in PCB decal PCI-62.
; K1 U8 p1 ?/ [2 m; HWarning: Pin number A43 not defined in PCB decal PCI-62./ |: `( n" N6 X7 m4 f4 I* S
Warning: Pin number A60 not defined in PCB decal PCI-62./ z. H" p% r; b3 V& G) {
Warning: Pin number A14 not defined in PCB decal PCI-62.5 K$ f1 ^5 D1 @, I
Warning: Pin number A9` not defined in PCB decal PCI-62.
! d. Y) O8 O9 ~$ t8 ?. B8 S! Q5 OWarning: Pin number A11 not defined in PCB decal PCI-62.
& E& ?. Q  ^  xWarning: Pin number A19 not defined in PCB decal PCI-62.' L- V( ~  z% X+ X
Warning: Pin number A15 not defined in PCB decal PCI-62.
; B- [" ?( N# F7 ZWarning: Pin number A41 not defined in PCB decal PCI-62.
5 @, e0 W4 W4 q, w' ?1 ?2 {Warning: Pin number A40 not defined in PCB decal PCI-62.; ~. `2 n, M9 p- ^
Warning: Pin number A38 not defined in PCB decal PCI-62., n! L6 G5 V9 E: f! p8 {
Warning: Pin number A4 not defined in PCB decal PCI-62.* d( D# n# P* @7 l, Y; h
Warning: Pin number A3 not defined in PCB decal PCI-62.* _3 y5 g7 @2 l. V1 c
Warning: Pin number A36 not defined in PCB decal PCI-62.
" F- A4 c' Y2 Z; G  p# UWarning: Pin number A1 not defined in PCB decal PCI-62.
1 Z- Q4 Q' B- F" o" O+ @Warning: Pin number A16 not defined in PCB decal PCI-62.! e  u2 N  ~( I) V
Warning: Pin number A10 not defined in PCB decal PCI-62.
" Z' A( R6 R% z# Y& WWarning: Pin number A59 not defined in PCB decal PCI-62.7 h6 u* e! B) G. K# V
Warning: Unused pin A61 is not defined in PCB decal or pin mapping - it will not be, or was not, saved.
: c/ p; \3 ^6 H2 i$ i+ t( x) z3 N0 tWarning: Unused pin A62 is not defined in PCB decal or pin mapping - it will not be, or was not, saved.
GMT+8, 2025-7-21 02:17 , Processed in 0.109375 second(s), 24 queries , Gzip On.
