( P9 Z# v; {8 Y9 b0 T! ]; ^. \: I( )0 r i3 g5 O' q
( ARTWORK LOG )
$ b% {+ S1 _5 C7 I- n* Y6 q( ): Y* U8 m' } v5 T
( Drawing : MSI-1358_V1_1-key.brd )! Y( [$ q4 h8 A$ }& o e" b
( Software Version : unreleased )
% \. @$ g: c- ?5 F9 u0 T( Date/Time : Thu May 16 21:19:25 2013 )3 v" C! L: X/ R
& g1 N: d) V5 b# m* G(------------------------------------------------------------)
2 e* S$ j- \0 N% E- h$ s* L5 Y
* j6 h) Z; Q% h9 r& ]' [; T" q4 K0 P J6 l
4 S1 K0 x$ H1 P# Z' ~/ x( q ******************************************+ Y1 G [8 \# }8 n5 w; L) I- g
WARNING: DRC OUT OF DATE on this layout.* p& K/ K. [8 ~, c! U+ O. I
******************************************: T; H: W, ]7 y7 J1 N6 w
7 T7 c* E% Z e- Q ]% b4 R) H ---- Photoplot outline rectangle not found ... using drawing extents
c4 C: j7 h5 s0 w+ T* z" `# s- b1 T3 l* T- c2 r2 w6 G& I7 \% n% X
s1 t! Y1 j H. L# d3 ~$ ?" s6 w( ? R
Results from parameter file ...3 H. _* O1 s! F% Z3 |- `
DEVICE-TYPE GERBER_RS274X# W3 ^0 S0 w. P7 A1 k: Y
OUTPUT-UNITS INCHES6 ]9 \! y9 Q& B2 }
FILM-SIZE 24000 16000/ ]" y# Z2 X6 c; L l2 O0 e7 J
FORMAT 5.3
; f5 K3 B; {2 k6 N1 Q ABORT-ON-ERROR NO
- O5 M* |' l! _9 m SCALE 1
' l' F# E7 y; Y- a# q SUPPRESS-LEAD-ZEROES YES
% N9 h. _- {, Z) R SUPPRESS-TRAIL-ZEROES NO
Q. D: y" _% g8 a# c; Z: b SUPPRESS-EQUAL YES9 a9 W" k/ \! f* X3 }$ @( O
UNDEF-APT-CONT NO9 \$ Z6 F4 q2 m7 }+ b8 q
4 ]/ ~' d# C! a) ^ WARNING: for raster artwork formats, artwork accuracy must be0 V6 n J- o7 @: N; T6 x8 s
at least one place greater than the database accuracy, up
. Q, E a; G0 H4 l to the maximum accuracy allowed by the selected output format.
% V% ?4 Z$ }9 U3 M
! d% {9 }; |8 O6 M& a$ `1 E% R Increase the accuracy by increasing the "Decimal Places" in
; P. K5 |) E3 Z& O- h8 R; J the FORMAT section of the artwork parameters and then rerun
\* d5 A$ {2 i: { artwork.+ l9 N+ I; L+ ~' u1 s2 @
% e2 M$ o% I6 g. x* C! a The current output is rounding down the data. Failure to change
& v) t9 t* m; ], R' P% E9 i7 H the format may result in inaccurate arc coordinates in the output
( }' y3 e0 Y4 O7 t; D; S files and possible shape/void plotting failures.* `. L. k* a% T" R X* p$ @
9 D, N) p/ Q5 v% n- [
) x) Z2 f. h$ V/ d- h" _0 L================================================================
+ p1 @4 F. {5 U3 I PROCESSING FILM < drill ># {8 B, @5 X) J$ d# i* S
TO FILE < D:/Documents/Desktop/99/drill.art > ...5 T+ V& ^3 Y" q) s- e/ N6 O
================================================================# r( g5 a3 e {5 W0 d, a
$ l& _# s2 C6 X6 g3 k9 J6 [/ e FILM PARAMETERS :
& S `5 l( M9 T- P$ O6 z ---------------------------------------------------------
/ `1 O4 g( t9 P# `* P) q+ w Undefined line width 5.00
, N$ L$ o# b1 U6 \ Mirror code NONE
1 ]. O+ K$ x5 ^2 u5 [0 S, \ Rotate angle NONE$ x' O: n0 L, H8 \$ V/ W4 z
Offset x: 0.00
+ z5 b% ?* K O7 v c- Z$ E Offset y: 0.00
% i+ O+ A3 ?; j9 N Plot negative NO h% ^. w. j/ J5 ?; j3 {6 ]# x8 C/ X
Suppress unconnected internal pads NO
2 x# `# X6 N! P3 d! r7 z7 x
8 W; n) m) _5 p* u9 U WARNING: 0 width line found at (17257.00 7693.00); P4 O! u& q( q( }3 |' j: C5 Y; [
... using undefined line width of 5.00# O$ Y9 o$ s% {+ s$ a% `
$ s1 a0 Y, e3 Q3 ^4 f) |: z WARNING: Multiple 0 width lines; all will be treated the same as the first.- m+ g1 j) U& J' D. a6 K
... using undefined line width of 5.00; N) b( q6 W+ K
' U9 G* ^' m6 {
WARNING: text composed 0 width line found at (17706.50 10596.50)
) B7 o1 U2 @8 |' r' N ... using undefined line width of 5.00+ N! U7 c! Z" e
+ R, v# ?+ p7 b" k' A# P$ y1 q
WARNING: text having Multiple 0 width lines; all will be treated the same as the first.
/ \1 Y0 x/ z8 Y, `: E3 g ... using undefined line width of 5.00; T# g; d$ z* P# y( F& }
i7 l! T l, _8 a
8 `8 E# o7 F; z9 S, q" r, a
9 \7 h) d7 E/ H* X. g2 R$ R1 { APERTURES USED:
3 j( S9 i7 Y4 e: l7 u# W8 F ---------------------------------------------------------
2 ?% H5 t, Z( n x, j: q TYPE SIZE/NAME ROT MIRROR MODE
" X2 `& j% O, `- P" Q Y2 N ---------------------------------------------------------
( M8 S0 D8 n. w8 Q% d CIRCLE 0.00500 DARK . `4 |: T* f' w; ~2 e, x
9 |. U$ x6 Q( J) A8 U
drill created with warnings
, w, V- P4 O# A- s7 u$ @
% e# E. c; i3 p* K" L. n7 v1 W8 L3 m% Y" d9 o2 _9 w( C: h
================================================================- K2 K. q* k% C1 v
PROCESSING FILM < solder_bot >
5 C# n0 o6 o* C TO FILE < D:/Documents/Desktop/99/solder_bot.art > ...
1 W. L5 I l, a================================================================
0 n8 U. W+ ?$ ~
9 c% |* l8 P& B$ B FILM PARAMETERS :
& y. S5 m& v( V0 @8 C& F ---------------------------------------------------------
: n v$ ?; [2 o# R" ]9 ~ Undefined line width 5.00! y7 k& K8 P& Y D( Y% |; Q7 d
Mirror code NONE
1 I4 l# v4 \ W0 M* _+ b C! H Rotate angle NONE
3 i9 ^- N/ |( G" [$ f* F Offset x: 0.00$ o6 Z: Z% T( M# i# } O5 g# b ^& `
Offset y: 0.00
3 _( i) {* I! y0 `0 m Plot negative NO
1 ]# L, @$ u- r; _( x( N- U Suppress unconnected internal pads NO7 |8 N" a$ M/ D) e+ V% P7 L
U* x% \& k4 S" i: x- ~8 m
1 V7 v2 q( t" Z6 u* V( f
y2 v2 H' _: A4 b" [
APERTURES USED:
6 g! _$ a/ K/ w+ _ ---------------------------------------------------------
4 E: m4 S0 Z- S TYPE SIZE/NAME ROT MIRROR MODE 9 `* b Y0 [! B4 ~3 c" I, o
- i3 ?2 \. F8 D+ \ CIRCLE 0.00500 DARK # d0 \& R" H0 @' |+ y; _& {
CIRCLE 0.03000 DARK . U, B3 \1 x. `6 W& }1 U
CIRCLE 0.04330 DARK 5 b8 `) s }$ K$ s7 Q. p
CIRCLE 0.04600 DARK 9 k5 x) y+ M- K/ D- o
CIRCLE 0.04900 DARK
' g! z/ \" b8 i6 _+ L CIRCLE 0.05300 DARK
7 U. ` ^4 l. B9 }0 l* B CIRCLE 0.06000 DARK $ U% X: d9 i4 t; e
CIRCLE 0.06100 DARK & L. b3 ]0 g/ S( s. H3 R4 f7 F
SQUARE 0.04200 0.000 NO DARK
) U% c7 u7 L0 h K0 ^7 c, q SQUARE 0.04600 0.000 NO DARK + @+ ~. p3 g- ^6 [* C
RECTANGLE 0.02600 x 0.03000 0.000 NO DARK ) C0 N& S+ i4 N7 R! V! G
RECTANGLE 0.02600 x 0.03000 90.000 NO DARK
$ |! r8 Y1 Z" J/ d5 h7 p; K RECTANGLE 0.03800 x 0.02600 0.000 NO DARK ( @ a R, i5 m6 n0 f9 G8 f/ I3 h( D) y
RECTANGLE 0.04000 x 0.03600 0.000 NO DARK 8 B4 m! N$ r f0 @0 y
RECTANGLE 0.04000 x 0.03600 90.000 NO DARK . J, Z5 \1 `5 m- g. d, @
RECTANGLE 0.04200 x 0.05600 0.000 NO DARK
9 @3 m9 G$ S7 W7 A3 M. |5 @0 q3 } RECTANGLE 0.19685 x 0.19685 90.000 NO DARK , l8 B& n7 L" K7 H3 `2 E+ W, _
OBLONG 0.01378 x 0.04331 0.000 NO DARK 4 @1 z. A- ^9 X/ h7 a: W1 l
OBLONG 0.01378 x 0.04331 90.000 NO DARK & {/ N* ^7 q0 ]! Z7 B/ T! Z* p
OBLONG 0.01600 x 0.03600 0.000 NO DARK
# F4 q) F7 J# Z( I4 \; Z6 O% s3 r u OBLONG 0.01600 x 0.03600 90.000 NO DARK 1 _& w0 Q4 ?2 |4 P0 F
OBLONG 0.06000 x 0.15900 0.000 NO DARK
+ U3 b0 D! l$ r1 l* C7 p2 i0 G OBLONG 0.07100 x 0.14400 0.000 NO DARK / N; b9 ]4 ^8 S: d# b
OBLONG 0.07100 x 0.16700 0.000 NO DARK ; k) {! U( I, K
OBLONG 0.07500 x 0.15600 0.000 NO DARK 4 G) j- z6 }0 ?% Z9 S9 J4 |! `
PAD SHAPE SHAPE26X34 90.000 YES DARK 5 a9 D3 S8 z; F" w9 [" \
PAD SHAPE SHAPE26X34 270.000 YES DARK 3 b8 `. D5 X! ~( |$ r" J
% W3 d: C: Y4 D* g solder_bot created with warnings
6 Y1 s9 D F* C0 c/ I6 g6 N. }: |9 D7 A9 G0 i
, h2 `, x8 s) [, l. x
/ j2 Q: C& n/ a, B PROCESSING FILM < solder_top >' m! d( j/ w" x: m
TO FILE < D:/Documents/Desktop/99/solder_top.art > ...
1 } ]7 D/ V9 i/ {* u================================================================
1 }9 Y! p3 E, Q* S& j
+ ]- {7 V4 [' F5 z FILM PARAMETERS :# C" }; g; j( H* f0 X
---------------------------------------------------------) T3 O& m2 d2 P3 ?
Undefined line width 5.004 f; a/ r T. h( E
Mirror code NONE4 q; q0 {" [- e& ~9 P
Rotate angle NONE
$ H; ^3 B' m9 g% a0 L Offset x: 0.00
: a2 }2 N8 T% p0 B1 m! [5 {1 J Offset y: 0.00
+ h! P5 `; Y& Q0 D+ E/ M Plot negative NO3 C7 n" d% z! j+ t$ ?3 H# i A* y7 M+ H
Suppress unconnected internal pads NO% l5 m% A- d8 f1 t
: n( ]7 T1 H. y _/ W
p2 T: t' W5 j& B3 Q4 R
, t0 q9 o7 E* d& Z; o APERTURES USED:( @% a; r' u1 l/ ` g$ w
---------------------------------------------------------5 r* O& A+ I& z9 g2 [) p$ Y
, x6 N- v! \2 s' { Z4 c( ] ---------------------------------------------------------
7 ]" v5 J; U4 S. Z- W( v2 m CIRCLE 0.00500 DARK
6 V7 f( K: W( J% Z& H CIRCLE 0.03000 DARK
5 P' J, N3 r* i3 b N R) [ CIRCLE 0.04600 DARK
0 S1 ^, ~/ m4 v: n$ h2 q CIRCLE 0.04724 DARK
' k" o, U+ C% N+ i# c/ J/ H5 t# d( w CIRCLE 0.04900 DARK
. z4 d* f7 s5 [# s CIRCLE 0.05300 DARK
5 {+ J U0 v4 {* u9 ]' G CIRCLE 0.06100 DARK 9 F6 h+ X V( K% u: Y/ Q7 L6 F
SQUARE 0.04600 0.000 NO DARK $ K X# A, t) P2 W
RECTANGLE 0.01600 x 0.05300 0.000 NO DARK
: B+ Q+ z5 W: @/ D7 P& S RECTANGLE 0.01700 x 0.10800 0.000 NO DARK
. j* a) E' h- u9 i; s( I RECTANGLE 0.03600 x 0.10400 0.000 NO DARK # o- s. _; ~+ H* \ n
RECTANGLE 0.03800 x 0.10400 0.000 NO DARK
: k W! [9 {6 Y4 ]7 d0 z RECTANGLE 0.04900 x 0.10400 0.000 NO DARK ; \7 k! b6 E& P$ r
RECTANGLE 0.05500 x 0.10400 0.000 NO DARK
; x3 z! h: J8 u S3 |9 a RECTANGLE 0.06300 x 0.08900 0.000 NO DARK
: d, Z: n/ L7 a( q- P' q& U4 Z1 i RECTANGLE 0.06500 x 0.08500 0.000 NO DARK
X: z6 e$ M& x. u RECTANGLE 0.07100 x 0.08100 0.000 NO DARK
6 D" T$ o2 z6 Q' l7 M RECTANGLE 0.09300 x 0.14400 0.000 NO DARK
9 k- P" ~5 m# i OBLONG 0.03100 x 0.08100 0.000 NO DARK 4 y: o0 ?! @/ b! i
OBLONG 0.04100 x 0.08100 0.000 NO DARK 8 S; N# ~' R1 k' R( W. Y
' Q2 C1 H9 o; |. l: ~9 u/ t OBLONG 0.07100 x 0.14400 0.000 NO DARK & Q; z7 L) }# ~; x
OBLONG 0.07100 x 0.16700 0.000 NO DARK / s+ g5 o8 v/ J5 O: R- _
OBLONG 0.07500 x 0.15600 0.000 NO DARK 1 o: c* H3 E! p" ?% `/ l" {" C
OBLONG 0.08394 x 0.03346 0.000 NO DARK
' c b. L, ]# i, D+ K2 T PAD SHAPE SHAPE26X34 0.000 NO DARK 4 }0 H$ r; b! v* S. }' \
PAD SHAPE SHAPE26X34 180.000 NO DARK & i0 b6 O7 s! f) m% V
$ P1 r- {0 T k: M9 c v! i solder_top created with warnings( y$ Y" R. N2 z
# A9 {, m, D, y+ S3 G3 E: {/ Y
7 ^7 ]1 g( o5 @& \( [% n
================================================================, d; k5 P3 q5 r, [ W$ Y
PROCESSING FILM < paste_bot >
+ k: W4 c/ O% w5 |1 h7 R9 e& g, Z TO FILE < D:/Documents/Desktop/99/paste_bot.art > ...
$ j' a7 w: N5 L1 c1 _: x- j5 u================================================================
6 A' j* T6 t4 ~, R, @7 Y; I: O" @ _! y6 [0 o* f' i# K
FILM PARAMETERS : M7 i: r9 F2 C
---------------------------------------------------------" K$ J& l) c! P3 D* q4 r
- w3 W1 J* ~& A, A Mirror code NONE# h, t3 y% q* m2 g5 M0 i9 n
Rotate angle NONE
% v: X$ @2 I5 X5 {& Z1 d# B2 n# x Offset x: 0.00
) e2 j2 q* Y/ Q; C+ E2 ?4 u Offset y: 0.00( D/ J: b% M( t9 n) U
Plot negative NO7 l' o% }7 `' k, J" R0 u
E* k( m1 z. m: Y: T$ ^9 {2 `( I
: B6 s( h3 h0 q: i, l# k+ L( \0 w5 o8 t) B2 N% `% G+ h* M" p9 u2 F
" o- n; s' y1 n. Q APERTURES USED:5 ^) S5 O7 l" h/ R9 {' d; O
( q1 K, c# @% o TYPE SIZE/NAME ROT MIRROR MODE
1 ^. {- m& X; L ---------------------------------------------------------5 T4 J ^/ R8 a I d0 X& M. X
CIRCLE 0.00500 DARK + j4 c1 T; {" f9 k# Q' @" `
CIRCLE 0.03940 DARK , O, }1 E' R% {; u# w6 b! Q; r h
CIRCLE 0.06000 DARK
9 s! P% n: `$ {% B SQUARE 0.03600 0.000 NO DARK 2 P2 X( e/ h% O9 k- P* D4 a1 N
RECTANGLE 0.02000 x 0.02400 0.000 NO DARK
( }9 ^- x* T4 t$ F RECTANGLE 0.02000 x 0.02400 90.000 NO DARK
% I; D7 A, ^3 d& K% c2 b B2 K RECTANGLE 0.03200 x 0.02000 0.000 NO DARK
5 Z$ Q8 O" H) I% N/ T2 J+ `& m RECTANGLE 0.03400 x 0.03000 0.000 NO DARK
X; R4 O" o, g5 } RECTANGLE 0.03400 x 0.03000 90.000 NO DARK
+ G% L- E! p+ j, u. d" D7 x RECTANGLE 0.03600 x 0.05000 0.000 NO DARK ' b) J* ^7 Q8 T* M" H+ k" h! Z% B
OBLONG 0.00984 x 0.03937 0.000 NO DARK 0 {! O# u8 o% Z+ V
OBLONG 0.00984 x 0.03937 90.000 NO DARK
+ Z5 q6 p# F8 C0 x8 M* L9 w OBLONG 0.01200 x 0.03200 0.000 NO DARK % \; F+ [' ?0 a& Z+ L/ H- a; \$ c
OBLONG 0.01200 x 0.03200 90.000 NO DARK
( h @! v, N& `" J# s2 C: [8 E- F* Q OBLONG 0.19291 x 0.19291 90.000 NO DARK
?5 v" G% D0 M PAD SHAPE SHAPE20X28 90.000 YES DARK 5 s, W4 X9 a8 x; ?* x
PAD SHAPE SHAPE20X28 270.000 YES DARK
( u2 D) v. p( X" Z& N
0 U6 s( h+ O# p+ g paste_bot created with warnings9 C5 x3 X1 K; J$ X- o' U8 h
- I. q8 s n5 [* Q+ ^4 Q$ t' z, k
8 H6 T% Y# ?0 g' ?9 d9 t8 v PROCESSING FILM < paste_top >8 x7 l( M4 G' `9 ?8 e
TO FILE < D:/Documents/Desktop/99/paste_top.art > ...+ \) Q) Q* Q# O; L
# Q# C: [, a# g8 r
' f6 D. k, E2 D FILM PARAMETERS :
) p2 K# _/ M' E# b- ^$ ^' F0 \ ---------------------------------------------------------- ]0 e# o- `, C* `' q
Undefined line width 5.003 B8 g4 o {+ M: ?1 H
Mirror code NONE: A* ~' w) C4 s! F7 I" J5 ]) f
Rotate angle NONE
: D8 s; Z% y$ u. y! p. O# | Offset x: 0.00
5 s n4 a9 O6 \& J7 [$ v Offset y: 0.00% m4 r! q; u" s0 W
Plot negative NO
# _+ o. w& g" m Suppress unconnected internal pads NO
% @0 A$ G. ]5 d# Z" l \
. c, q+ E, X( I0 B. C" L% h6 p D+ r* F
; L. J3 M+ E! r5 W+ P
APERTURES USED:; C5 K. m2 q& i ~+ |- W; ^
$ t" `# A G8 p+ B) z* w2 j/ J TYPE SIZE/NAME ROT MIRROR MODE
* C5 u& r* F& D _% H- x0 n! ` ---------------------------------------------------------
( b4 L, P) t+ p+ G7 o: w" z2 \ CIRCLE 0.00500 DARK
/ \3 h3 h6 l" z6 c! ^ CIRCLE 0.04000 DARK 7 p$ R8 l: Y( N5 E5 _3 m
CIRCLE 0.04724 DARK
# e: T4 B `2 `+ ^% a/ V CIRCLE 0.05500 DARK
$ V% a% ^1 b: G. H/ `( _ SQUARE 0.04000 0.000 NO DARK
5 _, B% u. T) }% j( ~% q RECTANGLE 0.01000 x 0.04700 0.000 NO DARK
6 T' R8 M' W! L! x RECTANGLE 0.01100 x 0.10200 0.000 NO DARK
( C# n1 R. S5 C$ |! q& i RECTANGLE 0.03000 x 0.09800 0.000 NO DARK
4 U& e# [% l; A ?- R6 q6 ]6 I3 W RECTANGLE 0.03200 x 0.09800 0.000 NO DARK
" z9 W; C4 `$ L [+ Y$ p RECTANGLE 0.04300 x 0.09800 0.000 NO DARK
. w! G+ O2 K0 G) _ RECTANGLE 0.04900 x 0.09800 0.000 NO DARK
! x# A) x9 c5 m7 c, `3 X0 o RECTANGLE 0.05700 x 0.08300 0.000 NO DARK 5 G* i% O/ e7 u4 {, e$ f# l' x& \
RECTANGLE 0.05900 x 0.07900 0.000 NO DARK : U0 o+ H* n' G' Z: g3 K
RECTANGLE 0.06500 x 0.07500 0.000 NO DARK j$ W" Y. f; x/ |' N) u
RECTANGLE 0.08700 x 0.13800 0.000 NO DARK
$ t; Q+ @# S, @: ]* P OBLONG 0.02500 x 0.07500 0.000 NO DARK
- i& A" g) d) m6 {) Z OBLONG 0.03500 x 0.07500 0.000 NO DARK - ]' P( \. r& `" |
OBLONG 0.05400 x 0.15300 0.000 NO DARK
5 [) X$ ]# Z4 E+ U8 g2 z- R: Y OBLONG 0.06500 x 0.13800 0.000 NO DARK
$ i& @, ]2 J# C# m# M OBLONG 0.06500 x 0.16100 0.000 NO DARK ' s) x/ S) |$ {4 d5 J
OBLONG 0.06900 x 0.15000 0.000 NO DARK
( Y+ f& v; r: T I! d2 o* C OBLONG 0.08000 x 0.02953 0.000 NO DARK
/ m4 r7 J6 m3 ?7 { PAD SHAPE SHAPE20X28 0.000 NO DARK
$ k' Q8 Q8 d, V' @" ]8 g PAD SHAPE SHAPE20X28 180.000 NO DARK 7 x: S' H- Z& N
/ G7 f! A# g: m paste_top created with warnings* P2 r( ~$ C8 z5 I: l, D
2 J" T: b% P$ ]; t& V7 b
+ V1 c) U# n V================================================================9 k3 w: V9 N% S& Y2 j
PROCESSING FILM < SILK_BOT >
+ U$ d- r, v+ r& [) c' ? TO FILE < D:/Documents/Desktop/99/SILK_BOT.art > ... D( @1 J0 |$ U6 X9 F7 a; b- Z% w
================================================================9 ?6 h: s0 [+ _/ N/ E
+ w. Q* E2 W/ G/ E" h: |
FILM PARAMETERS :/ R, i/ X; q6 |" e, j' u# p6 K
---------------------------------------------------------7 a- N2 N/ P; m2 F: l S
- o# j; J2 \; R" i4 X6 } Mirror code NONE/ a/ m F6 Q/ ^* F
Rotate angle NONE
) K- v1 f( p& t9 E) j$ [% C Offset x: 0.005 ^, b( H* N. U$ R
Offset y: 0.004 w2 d8 {* ]; C p0 ^" ]
Plot negative NO
- u3 _. N, `9 M$ O2 F Suppress unconnected internal pads NO! T& K3 M+ [$ E; Y8 x3 n; ]
( K" T" t: w1 A+ Z
$ u! `: _; ?8 @! T& `
( H6 S2 \6 d1 \' d3 `7 b# n
APERTURES USED:
X1 l- ~5 s" V2 H& y ---------------------------------------------------------
. m4 q1 d2 g+ T" J TYPE SIZE/NAME ROT MIRROR MODE
0 H" Y7 z- x3 r" L3 ]8 _) A ---------------------------------------------------------
2 v9 N. ], m" J CIRCLE 0.00390 DARK 8 C- g" ]1 ]4 S% D: V
CIRCLE 0.00500 DARK
& f% T3 N. U# t' D# U; N9 ?/ d8 l. {
X" ~, ^* t' X8 w \/ h SILK_BOT created with warnings
# k y. `) I# {$ z2 K3 \5 e
; G; f1 A0 ~* j
- s E) a$ ]1 b# i================================================================
& K% N R! w& J$ s8 K, q PROCESSING FILM < SILK_TOP >
/ l7 |- Q9 D$ j* c) l TO FILE < D:/Documents/Desktop/99/SILK_TOP.art > ...
2 _6 \( W B1 N+ J9 D! x a================================================================" p% m+ s6 Y: H8 r9 O
# T0 g1 d/ A8 h) @" B8 s FILM PARAMETERS :) Z$ Y- C1 P) O' g/ F! O
9 k* x5 |0 X+ a7 P8 B$ Q0 f Undefined line width 5.00
: g4 s# \* w5 ]+ @ M# D Mirror code NONE
+ J9 ^/ e# g; |: W* D3 W Rotate angle NONE
7 J& a1 s7 E) y7 a2 e2 F7 m J# D0 p Offset x: 0.003 F$ q& V$ V8 |/ s- \5 a1 {. K+ u
Offset y: 0.00
& L( F2 j |8 V0 x5 A, Y2 U* f Plot negative NO
, v; B% e i: q; i/ k0 P" c Suppress unconnected internal pads NO
1 s2 ]! S# C% s: z( Y" m% t( O! {
WARNING: Segment with same start and end points at
; S9 Y8 h. I0 f( s( L, D& M (9516.44 9028.15) will be ignored. Increasing output
5 i" V7 P; E" e; V( k/ v$ F accuracy may allow segment to be generated.
" Y; ~8 C; V+ e& E' n& T! b/ a# d2 Z7 A& j9 `2 y
, @& l' T+ [. p+ l4 g (9526.69 9029.69) will be ignored. Increasing output
* D1 O0 A% R: G. P accuracy may allow segment to be generated.
( h' ]$ g% @) x" _# S* ?! K6 q, i7 P1 F* Q9 |% o: j
3 s1 S1 F& W7 C6 d6 k) n7 o4 u (10127.72 9269.39) will be ignored. Increasing output
1 k2 _$ s5 x6 e* s& G accuracy may allow segment to be generated.
- f9 _& J, R! y, K* K% v# e
5 w x8 n* j, j" b WARNING: Segment with same start and end points at% i# L0 ^; F! M/ o. d
(10141.97 9283.34) will be ignored. Increasing output
2 X! ~& F1 A/ S$ e3 V% W7 x accuracy may allow segment to be generated.
2 N) M9 z6 y/ m; J) l& t# _ Q# K0 l
' q& o- h' {8 a5 ~4 T# o& a& t (10127.72 9298.79) will be ignored. Increasing output: x3 {+ x Y- X4 ?
+ q2 i, d q+ I) c
7 J1 a" W- D3 Q1 q2 v WARNING: Segment with same start and end points at
K( a9 F5 P0 F- p$ k* w (10142.84 9284.05) will be ignored. Increasing output
5 c" W8 [. P* Z6 C1 h% X( E9 K accuracy may allow segment to be generated.6 ~' v8 @+ ~" |' J
" G# [9 o; b x; `/ S
' k1 L3 G3 L1 E5 M$ r T ^ (10128.02 9269.09) will be ignored. Increasing output; ^4 B' Q7 J, q; L$ l5 d0 R* W4 S1 _
accuracy may allow segment to be generated.' e9 e& T2 d& n
$ R( d4 J1 J. u p
( W+ b4 H; F3 I' F: T+ s9 [ (14925.41 7863.94) will be ignored. Increasing output, F. ]" |0 N# t" d
accuracy may allow segment to be generated.' n# @/ j$ d2 Q7 e! s
' w& ?+ T6 t3 }2 c/ i
& h- |( K: J- j( f (13755.58 7716.52) will be ignored. Increasing output W+ ]' d- s4 B: v* B
accuracy may allow segment to be generated.1 {3 F% C; k4 b* u/ @
' p/ I" ?) t1 J, g- S- Z- k" B; P" J- I3 i9 p
; C4 K3 j: ^6 S1 j) I5 C
APERTURES USED:* X& D$ z! g: s) M+ O
---------------------------------------------------------/ P0 ^0 R2 b' c" U+ f
% v0 K! E ~, g ---------------------------------------------------------2 O0 ]& ^! G3 B7 _# L6 v8 ]
CIRCLE 0.00500 DARK
8 D9 Y1 w7 o8 ?/ _1 R4 S CIRCLE 0.00600 DARK
' ]0 v' J5 @2 }# f X+ h( P+ M& J CIRCLE 0.00700 DARK
7 {: p% B! o3 r, a! [8 o CIRCLE 0.00800 DARK
: j2 M9 {5 t7 Q& X$ s3 j9 I0 G$ W! n, `% [; k
SILK_TOP created with warnings; S- T& j7 ?3 K
% ]; _ G( s# \+ h
! X0 r" K3 s9 @ m5 I$ N1 Y6 H6 F
================================================================& b3 N- {' ?, D1 G6 @3 C& I) L
PROCESSING FILM < BOTTOM >, j" S; P7 P. h4 N' l% p
TO FILE < D:/Documents/Desktop/99/BOTTOM.art > ...2 z: `6 `8 O1 f$ U
6 o* W# m( x8 W5 K/ q, f3 ^
n: G, Y/ R9 d3 ~ FILM PARAMETERS :
: l5 G! W7 i5 T ---------------------------------------------------------
+ e1 d$ N9 G7 N0 [ Undefined line width 5.001 a: p% g8 M: C2 Q
Mirror code NONE
& [5 \- D7 P$ `7 L$ R- | Rotate angle NONE
' j( v3 v& L3 X9 k: R Offset x: 0.00' |) y& l" z9 S5 F! H9 V
Offset y: 0.00- j3 A2 P! {0 I. o f
Plot negative NO
- x* U, C% C! p- o/ t: ` Suppress unconnected internal pads NO
$ U& ], R; F/ v A% U' z, E K' M" | `2 C
' ]1 y, T0 v9 A( V. m- u ERROR: aborting film - Shape with first seg=(11210.08 7727.26) [layer=BOTTOM]
' i& O6 V1 f( y( ~; h+ w0 n has a void with extents [(12294.72 7788.51) (12369.76 7959.55)] that touches
) U: q% x; m) e, l5 k% c; ^. [ another shape with first seg=(11210.08 7727.26). Manually resolve problem.) a* _/ C2 H9 L- x3 S5 [$ ~
8 R4 D! Z: D$ R/ T+ r
ERROR: aborting film - artwork will not be generated!
( ~) B) Y8 t& N. G" N! @ Error in BOTTOM--halting output. Artwork file not generated.
1 r" E: d3 ?; C2 Z0 @& Z2 U$ z *** ERROR with BOTTOM
9 x- K0 b0 a0 a* B
7 G/ b9 x' b2 z7 T- m1 d5 c! ^7 j. c% ~
( D* ?$ t/ d7 k6 j; y
% i9 S8 a0 O, X2 g' F9 u7 y8 ?================================================================
' {" B* G0 ?1 `$ A6 B' p Y. g0 z PROCESSING FILM < GND2 ># J4 j! o. w" D9 q9 Q2 N+ S
TO FILE < D:/Documents/Desktop/99/GND2.art > ...) E+ `3 t' J2 U' F+ u& c
9 G7 K v/ Z6 M4 q( D& @3 M, g
! G) Q/ P# o9 x. d! p FILM PARAMETERS :
, I. z* X2 A8 }, u8 `# K6 _8 | ---------------------------------------------------------
8 J c$ x% V; j! r; A5 A Undefined line width 5.00
& _) R; a7 k2 g+ q& `% U8 L Mirror code NONE
9 `* v- X% j3 Q/ Q! I Rotate angle NONE
1 w0 h$ T+ a$ n1 ^# i Offset x: 0.00) n! ~" J/ u" Q8 v* e
Offset y: 0.009 o4 R7 @$ }" I+ r
Plot negative NO0 W: e+ L+ Y3 G* Y/ [2 R0 u5 ~
I" a4 s, @7 M9 s7 n2 X9 M* X& G7 a$ b8 q; I% A
WARNING: Segment with same start and end points at7 G% t8 Q5 u% x
(12333.42 8070.95) will be ignored. Increasing output& u' `1 k# `8 b Y/ R
accuracy may allow segment to be generated.$ n/ e& J0 N9 a9 X
; r) ~0 V: D, y0 @) y WARNING: Segment with same start and end points at0 ?6 L# }! ]7 B* m' J% _
(13689.30 8070.96) will be ignored. Increasing output5 g, S5 i+ S* t- V1 @3 N: e
accuracy may allow segment to be generated./ H8 _; t# Y' g. M2 D9 ]5 L5 t% Z
+ R: v; k" B+ e4 z
' G' i Q2 n- ]
' r1 E. t" h! W0 Z9 A- {! d" p5 z2 l APERTURES USED:0 J) F( O! B" U6 j# M4 L
---------------------------------------------------------7 N: D+ b, N7 h/ \ p) |
$ b5 j! L, x. ? ---------------------------------------------------------# _4 q# a9 V7 P }( `. d7 K; |8 t
CIRCLE 0.00500 DARK
# ]" i: L) h. s3 o% G3 w' {' _0 G( |- y0 v CIRCLE 0.02000 DARK $ y" y7 x$ B7 A% _ c* e
CIRCLE 0.02400 DARK - Z2 C4 Y4 a4 D% z
CIRCLE 0.04000 DARK
4 B8 U- r& u& s- ~ W* B* V CIRCLE 0.04300 DARK $ Y' h1 i0 r# ^8 [# u, d+ L$ U( f
CIRCLE 0.04700 DARK 4 c- P0 S- K: _$ H
CIRCLE 0.05500 DARK : s3 R, s/ }9 E& Y4 ]
CIRCLE 0.06000 DARK
8 c' d$ R/ p5 l- B OBLONG 0.05400 x 0.12800 0.000 NO DARK 6 Y$ n3 h _. g& A- \! [
OBLONG 0.06500 x 0.11300 0.000 NO DARK # N( i% h* ^: n: f$ u( h' V: h
OBLONG 0.06500 x 0.13600 0.000 NO DARK
; K( n- _1 B* D2 j \( p& e OBLONG 0.06900 x 0.12500 0.000 NO DARK
# V, ?0 c$ w6 [, n$ u' V$ _3 M# z5 G1 W
GND2 created with warnings
9 J# V# w' k/ L
! ?. Y9 H9 V) S9 I. B0 P' [ J* |- F% T: G4 G% X
================================================================' K7 e& f" n9 \
PROCESSING FILM < SIG >+ A' U# L3 @3 C
TO FILE < D:/Documents/Desktop/99/SIG.art > ...
/ X3 r6 z6 b/ X; U, ]5 {$ c3 U) _7 C================================================================8 {. ^& F# a, |5 Y% R' t5 a
+ l* w3 A$ E3 M+ K
FILM PARAMETERS :
: W. x$ x% [# s% ]7 T, e$ n! _7 e ---------------------------------------------------------
$ ^* e4 L( h+ c9 O" D Undefined line width 5.00/ [+ c0 B% c- W3 J1 O2 N
Mirror code NONE2 A4 b4 e/ X/ c0 X% r: k
Rotate angle NONE
2 D! Y8 r/ P& o/ P; v3 B Offset x: 0.00
) K8 x) l7 g4 t0 | Offset y: 0.001 U' L( n4 K: ^! O2 j
Plot negative NO
! v' b7 H: P/ p4 C, ^ Suppress unconnected internal pads NO
2 f: A( E* j. \2 b1 T+ `5 _$ ^0 z; [: z; F/ l& n; u
: h) B3 \0 Z, D$ o% v% P0 H (10849.82 8267.53) will be ignored. Increasing output
/ ?" B8 O: d. ]* X% h1 s accuracy may allow segment to be generated.
( U% {8 N1 H6 l0 A `0 |" W
/ H% H5 k7 L( ^( Y' \% }- i7 \ WARNING: Segment with same start and end points at4 s; e; ~9 s/ c9 o7 i! S, V" N
(10849.69 8268.11) will be ignored. Increasing output
( h6 J5 s4 q; k# A7 ] accuracy may allow segment to be generated./ z. R. l3 a# w R( H: V9 d
- H9 M, I# }) g! B& Y7 o
WARNING: Segment with same start and end points at. E: I) q8 G6 e, S% ]( M4 s( x
(10831.89 8250.31) will be ignored. Increasing output+ n- g+ A/ \, C$ x2 C
! \8 i* D6 z& {1 o" U2 e0 d) S# f e P
WARNING: Segment with same start and end points at" h2 Z% A0 c7 J5 O% @
(10831.89 8190.31) will be ignored. Increasing output5 v3 G: D, |+ x& l' x
accuracy may allow segment to be generated.5 a% Z4 t0 s2 W. c
# w( y! d/ L7 ^* z
& c2 a G& ] c1 ]& j (10874.89 8009.20) will be ignored. Increasing output6 O1 z& e j* A; ?. d7 c
accuracy may allow segment to be generated." Z' ]$ j' y5 M4 E' ~
( q- M1 T/ c( L) M) Y- \( A WARNING: Segment with same start and end points at& Z0 X( M0 a0 }
(10874.89 8009.19) will be ignored. Increasing output3 Y- B0 X1 p4 D: T- e# q" {
$ ^, E9 ~3 x' t Z1 I- M7 t+ V' d
7 ~' j m& R9 c3 P4 h3 r WARNING: Segment with same start and end points at+ o9 P3 K( R9 R0 X) j9 s1 e7 y
7 [( M! y1 F3 K4 g$ ` |, L accuracy may allow segment to be generated., g; p. w! J- Z/ b" g; Z
# Y1 e4 o+ @! d8 z$ M" B' x WARNING: Segment with same start and end points at
]# g/ X2 J, \8 e; a# d4 a U6 Y (13689.30 8070.96) will be ignored. Increasing output
* e% }1 Y; F! M accuracy may allow segment to be generated.
* V) k: m+ _- V+ N$ |( q2 w& M1 `9 J' o$ s+ P2 I
WARNING: Segment with same start and end points at8 d3 Q* g7 W1 ?! ]/ n# R9 d: ^
(15022.82 7964.66) will be ignored. Increasing output
7 R% M1 H3 Z; Y accuracy may allow segment to be generated.% L% d+ m6 I; @1 g" l
% r. W3 G6 m8 c) e! a
- S" ?* m7 ~) n9 N7 V; ^( G (10618.75 7691.98) will be ignored. Increasing output* C" s A! L) b
: s& W, i- N) G7 q
0 z" [# ^4 B! `8 h2 F WARNING: Segment with same start and end points at
# N% @$ n) E7 x (10562.38 7691.98) will be ignored. Increasing output
3 T2 c0 q. ]% c( x accuracy may allow segment to be generated.
5 U1 F0 V \: P$ O @( n% ?9 G2 E# r& i0 j4 d% x
WARNING: Segment with same start and end points at: _$ J5 i2 ]3 X
(10562.37 7691.98) will be ignored. Increasing output
/ b; `, `0 B, ?2 V' @& T accuracy may allow segment to be generated.& [# D$ o6 T6 X1 a- ]
! i! N9 O- J+ {- s+ Q
WARNING: Segment with same start and end points at1 |& H r. X b
(10159.98 8986.71) will be ignored. Increasing output9 D' f6 j6 H* Y0 M
accuracy may allow segment to be generated.3 X2 R7 E6 p s3 C8 t. a
/ Z; y- S% g8 C/ q8 u
+ H" A/ S1 }# z( p# b$ }: K7 m. E (9968.32 9057.48) will be ignored. Increasing output
6 ?4 y& f6 K# G# A8 g accuracy may allow segment to be generated.
! `/ q/ P8 f; \3 Y7 Z
2 M' G1 V# p# e4 p) N9 h/ e WARNING: Segment with same start and end points at- e1 H c/ Q7 {( L+ T/ u
(9488.92 8836.26) will be ignored. Increasing output* S" O3 _7 c9 z7 {
" `9 Z" E& {' n8 p+ W3 q3 a; t x6 ^/ j+ v1 S: g5 O
- r; |6 H5 G: z7 c8 U+ \ (9508.59 8856.40) will be ignored. Increasing output. e8 K2 F! }; V9 j
accuracy may allow segment to be generated.1 S4 u; {* {' A. k! U2 a, y. E
. I8 m, j. @5 Q+ m( r6 ?/ s WARNING: Segment with same start and end points at2 G* M3 m( g7 R ~& b; Q/ q) K8 W
(9548.59 8866.40) will be ignored. Increasing output
- x, Z, b5 r0 t8 O& t) w accuracy may allow segment to be generated.9 P7 t1 s3 s, x( v
k, a. |; v- `3 [& e! _! R
WARNING: Segment with same start and end points at7 k$ m# k# ]3 N
(10555.87 9195.08) will be ignored. Increasing output
* _6 i8 R2 G9 u9 D8 L7 P- d accuracy may allow segment to be generated.3 a- a( {0 K+ n7 c& m
% \' y! v% i7 h7 `/ {
WARNING: Segment with same start and end points at% \: r" i/ m8 J1 g7 B: r; ^
(10498.74 9183.92) will be ignored. Increasing output) A2 s) ]' j! b9 e- i/ F8 O: m5 N
2 M( r; r c0 J3 }
3 R7 K& z" c7 F }% W4 k WARNING: Segment with same start and end points at
; ~ K7 [6 U5 v+ ^% m$ q (10456.40 9206.41) will be ignored. Increasing output
+ E6 ~2 F5 C$ F accuracy may allow segment to be generated.
0 H1 m# O* m. [# r# D3 ^7 m
% Y7 E! E) h& D# W# f: j* Q6 x WARNING: Segment with same start and end points at
+ M7 U8 D$ I* Z5 ~/ R. [# e r0 ~ (10497.28 7856.12) will be ignored. Increasing output+ [4 }' i0 y/ E$ ?8 A; o7 h
' c1 C3 N, Y7 F6 _3 h. O$ e% v2 H; L" |
! F1 c* I, Z, l8 d (10563.19 7694.00) will be ignored. Increasing output4 E" ~- ?/ x1 b# n- D' z$ a
accuracy may allow segment to be generated.+ w6 o7 a; ^. ~/ a! f
1 C( s5 [2 [9 V) M" }
WARNING: Segment with same start and end points at# k6 O4 n& D$ c$ s8 v# k
(10563.20 7694.00) will be ignored. Increasing output! G* |4 Z! {1 h5 R, f9 k
7 R# u: c* A. `7 d
X$ P' L1 v* [8 r7 }% W% c8 v WARNING: Segment with same start and end points at
2 }# C0 r7 k# O8 D( V (10617.91 7693.99) will be ignored. Increasing output/ I9 N" f! r& i3 @, Y
5 m+ e: i+ V$ t' R4 H: g* Y! ?, A% J# r" }5 @4 H3 X
, s3 s* W3 ^3 C g, ~ @ (10595.12 7749.00) will be ignored. Increasing output1 \% L# ^! y# h8 W% ^ B" A" @) k9 ~$ v
0 Q, t0 I, q2 q, ?: G/ Z7 B, s3 _$ G0 e4 ]" Z
1 \; w. f4 }) e" [( E (10586.01 7748.99) will be ignored. Increasing output' K. L5 N: ^$ R- ~0 Z# S
accuracy may allow segment to be generated.1 k. t/ l7 N# P7 s }& L8 T
' i) m* i7 H/ H3 p9 d WARNING: Segment with same start and end points at
* Q R/ O4 p! K& o (10586.00 7749.00) will be ignored. Increasing output
+ M$ l d' s% c9 Z8 r( n1 q accuracy may allow segment to be generated.. x% i& p' f* ~. g# S+ M* A
9 X; G8 _+ f% c. o
f' c$ Q# V, P (10484.27 7850.72) will be ignored. Increasing output0 H. L) {" `/ K& f
accuracy may allow segment to be generated.* n2 ^8 D M5 `8 `- ?
2 R( `/ f" }5 @/ Z
0 y$ J# i* Q7 B (10599.68 7738.00) will be ignored. Increasing output
: Z4 m6 v) q# R. Y% ` accuracy may allow segment to be generated.1 w) B) y% D: Q
* ~5 T: ~ `1 `/ h, C WARNING: Segment with same start and end points at( D5 z( V! W4 R9 }6 L, [" r, @1 O
(10581.45 7737.99) will be ignored. Increasing output
5 F, M- f9 j- W accuracy may allow segment to be generated.- E1 h3 d! s1 v4 R
3 I6 m" C4 A1 |& u WARNING: Segment with same start and end points at
6 m+ D' C, K" E$ K' } (10581.44 7738.00) will be ignored. Increasing output
" Q. _$ Y* b8 e$ t accuracy may allow segment to be generated." Z! C1 I# W5 e* T: \/ V( `9 C
O! y1 l- X/ f$ I! l8 z
WARNING: Segment with same start and end points at$ O( l4 {. j' Y9 O
(10613.36 7705.00) will be ignored. Increasing output# Z( x4 Q6 P7 Q# p& _
accuracy may allow segment to be generated.7 j, t4 M6 s$ n6 I9 v- }" h3 w2 n
1 P8 u% V' z. i+ B% m WARNING: Segment with same start and end points at; }" K' i8 q' q2 I
(10567.77 7704.99) will be ignored. Increasing output
4 V6 j1 B1 r; r% Q8 ?- V accuracy may allow segment to be generated.
" Z/ M* N0 S% a
/ E; b* U* t& A' R5 x' K; d+ Q WARNING: Segment with same start and end points at- N0 k, ^; W7 z1 \6 K# G/ J
(10567.76 7705.00) will be ignored. Increasing output6 y" n* j# s0 m2 _% R5 D
( n; N8 w- a( z. p1 B% T- }1 w: X" s2 m: b# a
WARNING: Segment with same start and end points at( E% k ^: w7 Y0 p6 Z" q
(10576.87 7727.00) will be ignored. Increasing output
" l. z& U6 k% w; I accuracy may allow segment to be generated." t6 q: j- j' s, r8 ^
g( Y7 I% S8 t
! L: b- I$ P" z/ t (10576.88 7727.00) will be ignored. Increasing output
0 {8 O5 q3 T0 F' n/ \ accuracy may allow segment to be generated.: A, m- Z% f1 P5 e$ j5 y& F( V
# ?4 T$ ]# R4 w WARNING: Segment with same start and end points at4 K O7 r( v0 ~7 A F/ N
(10604.23 7726.99) will be ignored. Increasing output1 z, _9 ^# h- P; U, L6 N# e3 a
accuracy may allow segment to be generated.$ q; E. b, c6 s0 w: ^* H
2 J2 n1 m" I0 `
WARNING: Segment with same start and end points at' Q% @1 \, j) Z& @ l1 {6 S
(10572.31 7716.00) will be ignored. Increasing output
+ J* v! ^# a$ V) R$ G accuracy may allow segment to be generated.
1 W" Z8 g+ d. z/ q5 w
3 ^6 V2 p s) i WARNING: Segment with same start and end points at
/ _- S! I Z( A; r& j/ h9 X9 e: x (10572.32 7716.00) will be ignored. Increasing output
: f: i* M' U- ^. A accuracy may allow segment to be generated.5 `3 H9 Z" V* @& B& G R
! [6 k1 S' n0 T" ?* p
& V( Z4 g2 h" m (10608.79 7715.99) will be ignored. Increasing output
3 J1 _' J/ u, B d/ }" V; v% o accuracy may allow segment to be generated.& n% _+ |+ c+ w5 f& n
6 ~3 f& U8 a8 ~" O4 I2 J( A
# T. d; I7 R/ L
. t! u( l* {1 h5 }) A2 n APERTURES USED:
9 \; s( l9 f. \; ?& g: k ---------------------------------------------------------
6 b. x6 p% Z' p& Z7 N TYPE SIZE/NAME ROT MIRROR MODE
! p' |) c' v$ n+ | ---------------------------------------------------------( ~! D! O+ q# X* m
CIRCLE 0.00450 DARK
5 F3 u7 k9 m' C0 u1 Q CIRCLE 0.00500 DARK 1 e7 M4 K8 O( P% @0 ^
CIRCLE 0.00600 DARK ; [) r6 T9 T. [
CIRCLE 0.00800 DARK D& q: `9 c! l2 @1 I% _
CIRCLE 0.01500 DARK ' R% P/ `" y+ R9 d
CIRCLE 0.02000 DARK
5 i* u9 V' Z: u! s6 i* D! I CIRCLE 0.02400 DARK ! h& u* s+ s ?% [, P/ u9 E4 P
CIRCLE 0.03000 DARK
. M- ~8 `' l- \" F CIRCLE 0.04000 DARK
& Y. K w9 u) J( P; t/ _ CIRCLE 0.04300 DARK
' ~- T! k" ]2 ^1 D. \! I5 i CIRCLE 0.04700 DARK 5 N5 u5 e0 Q0 N+ p" ?
CIRCLE 0.05500 DARK - S" ?' o/ T; g7 S
CIRCLE 0.06000 DARK / O) q/ F* w3 S ?) m9 y2 |# C
4 D1 z/ k( _5 H+ x- S+ N# q( j OBLONG 0.06500 x 0.11300 0.000 NO DARK
% E: D) O5 E8 V c/ ^3 Y& v OBLONG 0.06500 x 0.13600 0.000 NO DARK ; U1 m/ I- r6 ? o9 K( q0 E
# J+ i! S2 C# j! L' Y( c
# Z) D' H2 ?; g& o3 \ SIG created with warnings. D {( I$ Z9 U8 Q4 C) X
9 F3 y+ ]+ v: k; }2 f
4 ]& E/ y: c) t, o3 Y1 ]% D================================================================
' e, Q1 H0 `/ y! @) R/ p PROCESSING FILM < POWER >* c9 Q0 v2 A+ \% { ]9 s, v* y
TO FILE < D:/Documents/Desktop/99/POWER.art > ...
9 g* c. ~6 l Z, K7 |================================================================
4 K. n+ g8 p; i" _" g5 a5 Z9 U o) p3 r1 |; _
FILM PARAMETERS :
4 @, ]5 c5 B) X$ N: b ---------------------------------------------------------
& {' U* x8 r* q5 ^ k7 N+ B Undefined line width 5.009 w$ [3 ~) O/ e- ^: R5 h* w& `' |% M" [
Mirror code NONE
6 Z; V' |- Q( R9 v$ F Rotate angle NONE
1 j5 v0 g' Y2 W# `% U- e Offset x: 0.00
. M: F4 x! D. `7 E% F6 I" A Offset y: 0.00
( x/ ?! q4 ~" n: C8 Z2 j2 } Plot negative NO
- ]3 d( }' w1 D4 h0 x7 a( L Suppress unconnected internal pads NO. h# f! m; [- x, t3 u& \" \
- I( V1 @' k/ T7 ?4 L
0 ], q1 M" y4 v0 z0 E0 y, D (12333.42 8070.95) will be ignored. Increasing output. J6 h0 E/ o3 _
accuracy may allow segment to be generated. o T& @7 w2 S% ?
2 J. U: d/ d& X WARNING: Segment with same start and end points at
) ^9 n6 y6 ?+ ~& `/ ^9 q (13689.30 8070.96) will be ignored. Increasing output
8 x% f1 A+ U7 m g% ]! p accuracy may allow segment to be generated.* w) `$ C. `$ T* T! J
7 ?" q: J# W5 k0 U( w
WARNING: Segment with same start and end points at( ~% [* t* J! l f1 C1 \7 W, b
(15022.82 7964.66) will be ignored. Increasing output6 m8 Y8 f) q( w4 R; q0 H
accuracy may allow segment to be generated.' W5 ^% @) V" B) G: d
8 F3 x- G3 u. \ WARNING: Segment with same start and end points at
6 @' c; `& f- e2 U. F* H/ q6 j: g (10229.61 9150.02) will be ignored. Increasing output
8 w" r( A" X9 {& t accuracy may allow segment to be generated.0 {: f( o7 Z) G6 e
4 ~ }% x8 ]7 T6 h* L. M WARNING: Segment with same start and end points at* W% u7 F j: f9 R
(10229.64 9150.02) will be ignored. Increasing output
( F5 ]! f3 `0 P0 i accuracy may allow segment to be generated.* t2 W$ k E* @+ b& J( Q
: X! a. V$ @) b9 k5 g! i WARNING: Segment with same start and end points at& `# z2 `$ Q. Q( L" S
(10230.36 9150.02) will be ignored. Increasing output
5 H* d5 V$ I( C accuracy may allow segment to be generated.8 f/ Q, A+ W" B8 ?& n* N0 U
. S5 ? ]" E) ^# @; Q! @
' w, p: M. U. V% c6 s3 e7 Z3 x (10255.00 9110.73) will be ignored. Increasing output
# t" f; v. J% S5 e: }$ ]* k: ~7 k accuracy may allow segment to be generated.
" u( c4 B( L# v. G1 ~3 ]
4 K7 \( M3 J, Q2 T% F2 y* A WARNING: Segment with same start and end points at
4 V0 D7 ?: D# b7 U, @! I. X (10255.00 9109.31) will be ignored. Increasing output$ G/ |( G a. }7 h' x, r% K
' y3 z7 t* I" D) A6 C, |% L# r0 C1 A% `; {5 X, g0 {$ L
. b9 o5 F0 y+ A. u
/ j( Y7 W( U. J# V0 I APERTURES USED:
7 x% g; ?6 m5 W# ~ [9 M ---------------------------------------------------------8 w: @1 h8 v& ^# {0 v$ ^: r; ~
TYPE SIZE/NAME ROT MIRROR MODE 0 \# t- p7 S a# {7 L
0 D9 {/ o8 H+ a) ?& c7 \ CIRCLE 0.00500 DARK
2 R' b4 R: G8 h2 t% f9 j6 b CIRCLE 0.01000 DARK
4 w6 a8 Q9 ?3 M. {* @# a; Z4 X' ~ CIRCLE 0.01500 DARK : N l" ~5 ` H! Z" n5 T7 c7 S w
CIRCLE 0.02000 DARK
% }7 `' y* {! B. q& x" ]: @% r$ O CIRCLE 0.02400 DARK # r( @" C( F1 P
CIRCLE 0.04000 DARK
$ o7 Z; ]& S' ?: E i* ~ CIRCLE 0.04300 DARK
/ e9 J/ B& O2 q9 o! [2 f, b( L CIRCLE 0.04700 DARK 4 j8 ]1 A& G% {+ c5 _# P: z7 p
CIRCLE 0.05500 DARK
0 \& I% _8 b" p+ u7 U CIRCLE 0.06000 DARK
; p1 h5 e8 D( ?& J# d OBLONG 0.05400 x 0.12800 0.000 NO DARK
' x& Z3 d1 u5 Q6 B) w OBLONG 0.06500 x 0.11300 0.000 NO DARK
( P+ p' b% j4 t% a, P OBLONG 0.06500 x 0.13600 0.000 NO DARK
7 R3 [4 b4 S5 a OBLONG 0.06900 x 0.12500 0.000 NO DARK
" U5 t4 z1 q8 k
+ X+ F5 r) G2 ]7 ?. f7 ~0 w POWER created with warnings
7 G1 Q( l7 Y! Q. {
( [$ Y; L- d, ]% P3 a) O' \1 S* F7 D& @, t
# s( n0 w p p: ]! Z PROCESSING FILM < GND1 >' Q7 O9 w3 L+ b$ d
TO FILE < D:/Documents/Desktop/99/GND1.art > ...
: ^& i) w6 ^; f4 ~================================================================4 q' b6 r0 x* Z' s( |- x
( p. X: S, i b
FILM PARAMETERS :) }( n) n) |+ ?+ N: J) T
) r0 N3 F# Z4 ~+ [" A Undefined line width 5.00
+ I7 O; C, l0 Z3 h2 ^5 s Mirror code NONE0 l, V1 J! R1 U4 E7 |. B( B
Rotate angle NONE: e% F3 A* l% C F5 S
Offset x: 0.00; ]# b- ]' W8 R, E G. T2 w
Offset y: 0.00
4 M, {5 \5 t- z, `4 c& t9 r Plot negative NO9 u1 i+ ^! t( L, ?! ?( `
Suppress unconnected internal pads NO# W) H! k. _$ U% I. C
# `( m5 s R+ M. o9 N- S WARNING: Segment with same start and end points at, \- K, n9 t) A1 H- L
(12333.42 8070.95) will be ignored. Increasing output" h/ X# s* s1 S
accuracy may allow segment to be generated.; s( c$ N5 P* s: Q' E3 E
]( e' \6 u5 M7 u) v" L
& L% D% r+ I! H" r6 m. E (13689.30 8070.96) will be ignored. Increasing output% g7 V" u" E( Q: A( f( u! U+ Y4 K$ s
2 J& E! H! S3 U2 v- `: Z3 w5 Z3 C+ j. T# ]
/ b; X8 l: K5 X4 {7 U
3 l3 }4 x! k' t3 q( u* \ APERTURES USED:) M# k$ P8 t3 a3 U1 _2 ]
---------------------------------------------------------" {% l- b/ ]: B+ N# ~, W* k
1 V5 F, V' o# r) z( `1 K8 j ---------------------------------------------------------
! v8 y2 M" [3 K( |# z CIRCLE 0.00500 DARK 7 W. Q: C' i8 l V' W
CIRCLE 0.02000 DARK
g& E5 n# X% R; {4 f+ h0 Z' X: Z CIRCLE 0.02400 DARK 6 M8 R9 l! B* U5 |
CIRCLE 0.04000 DARK n0 p( @. i2 S
CIRCLE 0.04300 DARK 8 v" B; T. s- U4 O9 B; k$ z' [
CIRCLE 0.04700 DARK 0 R" n1 O# ~6 G, {0 Z: K( p; J
CIRCLE 0.05500 DARK / \. c. \( {2 O
CIRCLE 0.06000 DARK
- H1 E! Q3 {& }3 U% O5 O OBLONG 0.05400 x 0.12800 0.000 NO DARK
; F# w& H& B1 q8 V9 r# o; ` OBLONG 0.06500 x 0.11300 0.000 NO DARK % ~1 F% _4 `& b, O
: h3 }: G H2 s: P/ ~6 s0 W9 X2 ^ OBLONG 0.06900 x 0.12500 0.000 NO DARK
2 a/ D U9 L8 n3 P e E0 e
, Q4 W& M3 z# r/ z GND1 created with warnings) _3 A" L- c0 {2 ~% B* w
z4 Z: P7 m$ z! i
. q( j3 v; q, I- V================================================================
/ V/ z8 ` U2 r7 J5 h& c% q6 l PROCESSING FILM < TOP >
8 \3 y4 }7 q: m0 s3 ^. y, _, L$ i TO FILE < D:/Documents/Desktop/99/TOP.art > ...; M& r0 U% A$ V) q( C/ F" r
4 j0 x5 Z! U5 A. T% I: f. P2 n
& W8 p" k% _ f5 N FILM PARAMETERS :* K) C5 e3 T8 E% d/ {
1 A+ Q& f, }) e0 u, \ Undefined line width 5.006 A! P* g7 k* h8 s6 b, @: L0 \
Mirror code NONE
9 M8 }8 u1 E5 H' {# `$ m- L Rotate angle NONE; u! I* k' y# J& p( M
Offset x: 0.00
) w1 e8 l: _6 B7 e% X Offset y: 0.00
' Q. J+ {; J7 s, q8 ? b Plot negative NO2 |1 _! d$ m- H
Suppress unconnected internal pads NO0 c! a# p: Z6 a# F
0 a( E) ]6 f; s; }
WARNING: Film contains DRC error(s).
1 v3 q7 R T7 o% n* Y2 ^ WARNING: Segment with same start and end points at8 [3 ~/ ?9 Q8 e. y. S
. \7 C5 E1 T+ l4 Z9 P accuracy may allow segment to be generated.
1 a* X( \6 _' ^- J9 D. S
) |0 ~9 n9 O0 V. w) ^! f WARNING: Segment with same start and end points at; x, u4 q0 A$ n. w. R. O' Y0 I
(13689.30 8070.96) will be ignored. Increasing output' B- [# f: Q1 b" `! b' c4 c8 A# }/ M
accuracy may allow segment to be generated.1 F& g6 f A( m4 Z2 s0 J9 m
* g, Y k4 V/ d( y. F
F% U, J2 F- q- s) ~; p; ^, K (10837.53 8279.82) will be ignored. Increasing output
5 D; h0 ~' R# k0 [) ~ accuracy may allow segment to be generated.
% m. C4 H! n; g4 L% f) N+ o
2 C3 _0 Y5 U l6 e* L7 ^* o WARNING: Segment with same start and end points at1 A0 d/ E5 R; b2 A% U% V& ]
(10838.11 8190.31) will be ignored. Increasing output
! g; E4 R& g2 d* y- b accuracy may allow segment to be generated.
# L9 k# Z1 @# K' H& ?3 n: I1 U
1 a/ H3 K' o( V7 O% A; F WARNING: Segment with same start and end points at
2 X T; i0 ^5 g6 D, l1 @. v (10874.76 8008.61) will be ignored. Increasing output# j+ A+ S- s1 K; U
accuracy may allow segment to be generated.8 i; R4 I% k: j. I
3 ^+ A1 l' t8 w l2 c1 U5 G WARNING: Segment with same start and end points at$ ]7 D2 R7 Y+ \1 q
(10251.89 8270.02) will be ignored. Increasing output
. {4 u- A W- r$ l; I accuracy may allow segment to be generated.& {& r0 F* W1 l& U
9 R+ |3 N1 a# o2 a. ]( |
* j2 |7 p% Q }. C. d8 q (10252.31 8275.22) will be ignored. Increasing output+ B* I9 x1 U; w+ ~8 e7 }/ c
accuracy may allow segment to be generated.2 n5 Q$ y" {! w* Y( b6 N
" [! @$ y3 U' C! H& h
: f+ ]) \& x- |0 _7 g2 K* y9 X (10650.26 8947.01) will be ignored. Increasing output9 j0 `3 L" a: h i8 ^
1 Z+ L! _) S0 e6 D# K0 Q; q* ~( n/ S) ]4 P* v
WARNING: Segment with same start and end points at% `% c9 E8 L* w m) O6 p4 k9 g
(10685.52 8947.45) will be ignored. Increasing output
- a2 D \/ U. D; X! H accuracy may allow segment to be generated.
6 O- c) L. f9 x9 q/ G% a' G8 ~" g5 R; J6 s* [. c4 Z
3 h3 j' }6 M5 c/ i- l& ? (9623.74 8638.92) will be ignored. Increasing output
# ], k6 K" \2 n( v" X& ? h( F3 } accuracy may allow segment to be generated.
* c: A* l3 }7 X) `4 X C! {
0 n p) Q% ^+ Z- {; `1 `1 c( S' } WARNING: Segment with same start and end points at
$ q% v7 c7 S8 b( f% s# M (9738.92 8741.26) will be ignored. Increasing output' r3 t) `8 d; F' l# t! s
accuracy may allow segment to be generated.1 k, z; Z# j, G! o5 D" ^ B
3 l6 J( T! W" j* V
; K2 c9 `2 x0 E (9799.84 8751.38) will be ignored. Increasing output; i- D( I7 C9 W/ @, _3 ~8 x' u' M
accuracy may allow segment to be generated.3 U% z. a! ~9 b% V# u* C/ ^$ K, `
, p+ s) w% v7 @% R: I- i
WARNING: Segment with same start and end points at, M( S) b0 v: ^% x& E0 p
(9805.45 8751.25) will be ignored. Increasing output( K, J# ?5 F$ r8 h
% _# y0 |+ ]8 a7 q' Z9 ~4 p. v9 i- Q0 p+ d, |
6 T% w, J( M$ l E2 ?0 o (9859.13 8749.92) will be ignored. Increasing output( ^( P* Z: P0 S" j" D) o" M% S7 l
accuracy may allow segment to be generated." M* c% H! E D0 }
v. q. R7 S6 e$ l2 e P1 q WARNING: Segment with same start and end points at5 W4 J: ~: t5 i8 H
(10685.74 8725.29) will be ignored. Increasing output
/ k$ z/ b0 {5 n0 [- L accuracy may allow segment to be generated.' O$ x1 w9 _3 F$ h8 a7 L
: I! G+ Y3 V5 r8 G& A! S' M. F
WARNING: Segment with same start and end points at# \7 o& B% J& a$ D; ]& g
(10650.48 8724.85) will be ignored. Increasing output
: I/ m& o5 D) z' f5 M u# t; j+ X accuracy may allow segment to be generated., o+ N9 V6 g2 ~4 a
+ ?/ Z4 U' i. G7 D/ B. } WARNING: Segment with same start and end points at
7 X4 b, Q1 e0 Q (10632.02 8770.07) will be ignored. Increasing output9 `, v; k- V" v7 n' l9 i( S8 e
accuracy may allow segment to be generated.& p7 w! H+ @/ u5 |3 e9 g
$ Q+ j3 S5 c3 A B/ `7 e& X
WARNING: Segment with same start and end points at+ n0 k0 E; I) Y
(12617.86 7825.24) will be ignored. Increasing output; g; V" Z4 z. E S
7 c2 A4 p, a# o1 p
& f/ R3 d9 s6 `, R E! k w WARNING: Segment with same start and end points at
. d' f: O6 Y, j) n( T' i7 z: D (12577.55 7825.11) will be ignored. Increasing output5 G# y! } w$ X
4 W( |# `. ]2 Z; B
" r4 W4 I8 Z; J. v. K WARNING: Segment with same start and end points at
* o0 M; Q( ~$ {. u (12416.68 7847.50) will be ignored. Increasing output
/ I. G& R& y; i l) g- E accuracy may allow segment to be generated.
: x- m3 q1 f+ L% q; e; l
) w% `- ]' s8 p WARNING: Segment with same start and end points at
# x- U1 C" T" B( M (12611.23 7969.61) will be ignored. Increasing output
$ K, [9 ]0 \& _7 q accuracy may allow segment to be generated.
# N1 X1 M" n1 ~/ d+ [9 V' i3 O- @
8 n, f7 g& P6 m' r; Q/ `9 F' \ WARNING: Segment with same start and end points at: B- U" T- y* t0 d
(12685.18 7977.53) will be ignored. Increasing output
. U, H; ^! k' @, c7 E3 j accuracy may allow segment to be generated., P7 }5 x4 \4 w; b
# v7 c/ Q6 d, M1 V5 M WARNING: Segment with same start and end points at
/ G$ W9 b; B) o: i+ T (12709.45 7963.32) will be ignored. Increasing output# Z @, Q2 t3 ~# A0 a& M1 e. Q
accuracy may allow segment to be generated." x% Z. G, O3 K. ^
; _8 B% \/ r/ Y' v! R: e
WARNING: Segment with same start and end points at: T9 R' B3 h* a. W% U
(12748.31 7968.04) will be ignored. Increasing output
# \9 k+ k, T- Z q' [1 m* z accuracy may allow segment to be generated.- `, S- t6 M# u: [% i
( s6 k5 l, e1 s- k. I* K
3 W+ f4 a X* G4 j( O0 |7 H$ N% { (13074.14 7942.98) will be ignored. Increasing output: K3 V8 a' V4 O6 R" f! J
$ p" Z; l( {% ]" L. x' V! d6 S
- b3 r# ^1 [( v9 p& p WARNING: Segment with same start and end points at- w; B- ?# ]: j0 X- q, @
(12413.82 8006.14) will be ignored. Increasing output- G; `+ i8 }4 w' ^
accuracy may allow segment to be generated.% `+ t' f4 y6 U; }. ]( A! H
/ [( G8 R! ^5 n WARNING: Segment with same start and end points at; \5 h- ~ V3 W" {$ I
(14482.52 7744.48) will be ignored. Increasing output* R/ A/ m0 q p" \6 \( v
3 c: u' }7 O' C0 J) l# m( r3 w5 J* P) e
WARNING: Segment with same start and end points at- c& w3 X1 R3 P, G
(10468.74 8894.25) will be ignored. Increasing output
$ c% {) Y& e! K accuracy may allow segment to be generated.5 E( P( C' @4 \( {
9 Y3 _- P2 [: I! n5 f
/ s/ L' `! l6 Y0 h# V1 z (10444.86 8963.10) will be ignored. Increasing output
" ^9 \1 h1 P+ R. A1 l# w% y+ p accuracy may allow segment to be generated.
6 V% ^8 @, n; z8 M _
: O' A( `% {" ~& t# K WARNING: Segment with same start and end points at
) y5 b- V' Q0 S4 r! B- z- q (10193.74 9003.92) will be ignored. Increasing output- V' X' D/ ]2 }! f
accuracy may allow segment to be generated.! E5 ]! L- {0 X- ^2 |& l; c
1 K) l, h/ q. q0 l! E+ T: z; M+ x9 i
4 D' u5 T, o$ D1 X (10168.92 9106.26) will be ignored. Increasing output
4 P1 H3 `" z& X3 M$ p accuracy may allow segment to be generated.
% J3 A7 K b# c1 h/ `8 x9 G% {7 w/ G6 F
( q6 o/ n ?( \8 H { (10188.59 9126.40) will be ignored. Increasing output7 \) m, ]( n: k' K8 x% X
accuracy may allow segment to be generated." n0 ?' k# F% ?# [2 O" S1 y
5 E/ q2 O/ N9 J WARNING: Segment with same start and end points at
' n, y# e8 N; t2 A, b8 U (10555.87 9195.08) will be ignored. Increasing output' ~4 u. \+ t0 d+ ^, T* Y- n: p
accuracy may allow segment to be generated.0 f* M9 C4 s$ b# P
9 J! G9 g3 J/ t( c WARNING: Segment with same start and end points at
- i4 V5 L- l! e (10530.15 9227.84) will be ignored. Increasing output
3 D6 r+ P) R( R r4 o: b" w accuracy may allow segment to be generated.4 F1 w5 a) u0 v/ _" i
3 m7 _: q" x5 t) C/ j
8 @4 l4 D1 b1 C; H# \ (10498.74 9183.92) will be ignored. Increasing output
* N8 O$ }7 S$ l6 ^+ |. c accuracy may allow segment to be generated.3 j# N! w, ?# `
* v2 L( ^/ K& @2 i4 ^# U WARNING: Segment with same start and end points at) |. I M6 d$ t- T7 q
(10359.89 9160.81) will be ignored. Increasing output
; J+ h4 N' i* e" @1 ^% c: Z' R accuracy may allow segment to be generated.5 u& O. M% B8 A1 c
& }$ L+ A# I) ?+ }5 K
WARNING: Segment with same start and end points at g5 ~- H* Z H
(10510.77 9126.24) will be ignored. Increasing output c) z6 G- _% h9 q5 u
( w3 q; e5 o# q7 \' A1 S
6 D* W I6 h! | t WARNING: Segment with same start and end points at: n8 |1 F l. ~; m% d, D
(10515.93 9125.66) will be ignored. Increasing output O! I8 y" A& A! |* W( n
4 ?- Q5 w; T+ V7 L* N0 m
- h( l5 k1 E0 F WARNING: Segment with same start and end points at
8 [+ L( }' f( e7 O# w" Y( u (10626.40 9103.63) will be ignored. Increasing output K# O2 G/ J0 Z# C' w
accuracy may allow segment to be generated.: d+ C2 z2 G$ k }0 C5 r. K. x
; x) ?, ~1 k3 q; u$ w2 ~& A
WARNING: Segment with same start and end points at7 {+ L. S$ N0 d* |
(10460.32 8999.40) will be ignored. Increasing output
& y3 m+ I" a+ C/ i ]9 L7 B1 u accuracy may allow segment to be generated.
2 {: j, d, r6 v+ b0 A
; J& e8 z9 I4 e WARNING: Segment with same start and end points at
+ O K) W @: s" B" g! z4 P (10479.86 8979.81) will be ignored. Increasing output
% v2 h. [1 x9 d2 U" }1 ~ accuracy may allow segment to be generated." b, [& \2 e- Y" c) F' }
5 i+ A" E8 @2 \ WARNING: Segment with same start and end points at3 [; g8 }2 S' O1 T
(10473.90 8893.67) will be ignored. Increasing output
{. ^- q3 E( i1 l' q accuracy may allow segment to be generated.1 |8 @7 J1 o7 v3 P7 y7 i
" S+ A! F: W; ^! f @9 d, t WARNING: Segment with same start and end points at4 j* }: p; H" a4 c$ w8 ~2 m) Q6 @
(13641.76 8004.98) will be ignored. Increasing output
8 L% z( \4 J3 s( X: m accuracy may allow segment to be generated.2 v; q |# R3 u% _7 }: i1 a5 `
6 Q; Z& q3 ~3 P2 Q8 h3 g: F5 {8 \' b WARNING: Segment with same start and end points at8 B# P7 c3 B$ D0 ]. E) C+ N& g. f
(14216.98 7694.64) will be ignored. Increasing output, n4 ?) Q1 @% {
0 H5 ~! E& p% _9 x7 v9 g( E
+ P8 x( Q* p7 [9 T$ k WARNING: Segment with same start and end points at
/ y, b3 ]- ^9 P4 A8 a. W/ ? (12425.47 7835.00) will be ignored. Increasing output
1 a% M+ {# X! v+ ~ accuracy may allow segment to be generated.
) t3 h. Q7 j, O; }; s* F9 O# H5 A' v6 {* k$ N
WARNING: Segment with same start and end points at0 p6 W% o6 e1 L( s0 o9 D
(12775.00 7975.00) will be ignored. Increasing output8 s; o. T3 D% q4 x# U/ B) H
2 G% M ]8 K; c$ D7 X" E. o
3 e5 f2 |. i k1 r# p5 r' ^! T WARNING: Segment with same start and end points at& X. ?( c6 J9 O8 I' Q
(10472.50 8970.00) will be ignored. Increasing output5 M8 X8 V- W8 ]9 L# K e& Z6 _
accuracy may allow segment to be generated.. o1 A* H$ ?' i
* T* C1 k& _1 k4 A1 I
WARNING: Segment with same start and end points at- I$ O4 n/ Q) O7 I/ ?
(12443.85 8095.00) will be ignored. Increasing output# D8 @1 `6 `9 d. [" o% I' W
accuracy may allow segment to be generated.$ { X$ A9 l5 b; k! B5 a) I) G+ C0 b
! W* M6 P& F! J/ E B T2 q+ ^ WARNING: Segment with same start and end points at
! m6 C& o4 l! ]- B* F( j/ A (12035.24 8025.00) will be ignored. Increasing output& x. k. F: Y7 V" S+ @
$ K \ L% E F* w( R* _
5 H" G/ j/ a9 x5 m% _4 { WARNING: Segment with same start and end points at4 x( i' `/ w5 r" y
(11763.48 7785.01) will be ignored. Increasing output
% I: I" E3 P; T' m accuracy may allow segment to be generated.
' J8 ^6 c M8 `* x* c, D* D" K
$ o# |) H% ]4 a# ]2 b WARNING: Segment with same start and end points at0 [3 K" K' Z: L/ q/ f) I2 v
(11759.32 7795.00) will be ignored. Increasing output
- U) k; I9 _" }7 ~. p8 N accuracy may allow segment to be generated.( d: F" }8 R& [8 Q, ?
1 H) N* Z. q5 z! l) S9 M. \5 i
WARNING: Segment with same start and end points at0 z4 s" r9 b& }
(12039.38 8035.01) will be ignored. Increasing output
0 S; R" \6 @; R6 S! ~! N8 V4 f accuracy may allow segment to be generated.2 m/ Y- ^* q0 ?* k
7 O; G* f. n" J6 X8 d1 f
8 a/ n, Q+ R, b- L (12447.99 8105.01) will be ignored. Increasing output
* b5 x& G3 O' ~5 n$ x' o) h3 q, u accuracy may allow segment to be generated.
$ k' o O$ ~3 _+ J
% @: p g4 G! @( s w$ i WARNING: Segment with same start and end points at, J y j8 ?5 u) H0 r4 j
(12411.80 8006.96) will be ignored. Increasing output
) D# s9 k& T$ m accuracy may allow segment to be generated.* u1 A; j/ s+ Q& b+ ^
6 F l) q% ?! [- P' C: m- R WARNING: Segment with same start and end points at2 C5 A. u( D& S7 e" N
(13073.68 7956.00) will be ignored. Increasing output
/ I# g& w# e& j6 i6 p1 h6 b accuracy may allow segment to be generated.2 b8 a& e- @* X; r5 v" s B3 { g
8 J/ H2 L! `# g' ~$ H
WARNING: Segment with same start and end points at3 Q4 y0 I5 d3 a+ ~( b Z( v+ G
(12400.80 8011.53) will be ignored. Increasing output5 G# k) a) C. n4 U6 V% }5 ^! ~7 ^: j) d
accuracy may allow segment to be generated.6 e( L# l% b1 D+ ^8 s! U* w
! a2 B* C! S8 q WARNING: Segment with same start and end points at
& e! F5 g+ o+ i3 A (12378.80 8020.65) will be ignored. Increasing output
- d- ~1 y. _ ?) C; m3 ]0 t accuracy may allow segment to be generated./ ^' w- F1 ?- D
9 \9 ~3 R0 K# I s- @' B! K
WARNING: Segment with same start and end points at9 T8 q& |# R/ l0 b; @/ X- g
(12389.80 8016.09) will be ignored. Increasing output- u8 W7 q$ t% K6 \
( F1 K+ m% T- |; o8 Q& R; O; q7 ~5 W0 \5 z5 C) V- @, ?
! Q" |/ g8 E: U: \5 q1 x9 a2 o (12026.33 8003.50) will be ignored. Increasing output
+ F/ C8 @6 B7 |4 ? accuracy may allow segment to be generated.
: V: T: I& D# y6 q# q! d
$ `9 E8 Y2 z: @+ A; v6 p2 N WARNING: Segment with same start and end points at
. R* F. ^# A F) x' K& f3 \ (11772.39 7763.51) will be ignored. Increasing output* [. D H/ \; Y) C! K
accuracy may allow segment to be generated." t- K( \: ]3 ^7 a) a& v
) l' p' F; `! u/ ~5 X5 ~/ M' X2 ~
; M, w0 I& v7 Y% m! L9 |+ E (13078.23 7944.99) will be ignored. Increasing output
1 U* G$ y* T$ a2 _ accuracy may allow segment to be generated.
" ~# @! x9 _# q/ D n$ h1 s0 r0 T; e4 H( i
WARNING: Segment with same start and end points at6 h3 n- y% x Z v
(10381.34 7936.34) will be ignored. Increasing output) {3 V: W, U, D5 ]4 L
( E9 x0 T- D9 G9 @" \9 r, K0 [( c; ^; C& E$ K' Q4 x a
9 z% i" t* ?2 {) X* T7 E0 j+ y6 E2 E
9 _5 } `+ r( a- z! w9 U3 { APERTURES USED:
# A% n- v5 R9 H- F! w% W7 i ---------------------------------------------------------
6 S! x; p8 A. a P" G. K TYPE SIZE/NAME ROT MIRROR MODE ; x Y4 y3 u6 y! H- P& f
3 r7 G3 c2 t! s/ I: C3 w CIRCLE 0.00400 DARK & U7 g& K$ @4 W s9 R, F
CIRCLE 0.00450 DARK 5 W S! {% |. f
CIRCLE 0.00500 DARK # G* }: c5 e, D. ^. J7 U- a1 F$ e8 u
CIRCLE 0.00600 DARK : D' K9 n# |! H1 x# p' `
CIRCLE 0.00800 DARK
" s( B! P& \9 C5 R7 O$ H CIRCLE 0.01000 DARK
& @* g5 q F4 a CIRCLE 0.01500 DARK
% [8 j4 a. S3 n5 D& m4 N CIRCLE 0.02000 DARK / w7 r5 i+ f" U5 {8 i9 b3 B3 q. C
CIRCLE 0.02400 DARK # S, x Q; b R6 y
CIRCLE 0.04000 DARK ) z0 |" M6 S& |) Q$ M
CIRCLE 0.04300 DARK ) ], N1 ]1 L7 s r" |. O% M$ f/ |) ^
CIRCLE 0.04700 DARK
* A# B& y1 m- m% K1 J* C CIRCLE 0.04724 DARK
- h' y, z( J+ b3 i3 { CIRCLE 0.05500 DARK
: q& m2 k' s( W SQUARE 0.04000 0.000 NO DARK
4 g' y, ^# j: t' K/ ?# u RECTANGLE 0.01000 x 0.04700 0.000 NO DARK
6 I) t) q8 V" ]7 q: l RECTANGLE 0.01100 x 0.10200 0.000 NO DARK n9 C& W8 t$ A1 } p$ P6 X
0 s3 A( E+ ?5 b4 u4 T# v, e8 [ RECTANGLE 0.03200 x 0.09800 0.000 NO DARK ; P, v& ~7 V6 ^ F) g3 Q! t% k/ L/ k8 h
RECTANGLE 0.04300 x 0.09800 0.000 NO DARK ! }9 Z7 O- l3 `) w' w: [. q" B' ]
RECTANGLE 0.04900 x 0.09800 0.000 NO DARK ( P# G( w' D: A5 e" q2 n
RECTANGLE 0.05700 x 0.08300 0.000 NO DARK ( @0 h5 q1 z9 [: @
RECTANGLE 0.05900 x 0.07900 0.000 NO DARK & e2 E4 s; \4 w" W' V" h
RECTANGLE 0.06500 x 0.07500 0.000 NO DARK ! u u) ^ ~3 _" }
0 p+ O$ l! t/ u" a; K( r( b7 Q+ N OBLONG 0.02500 x 0.07500 0.000 NO DARK
/ A% V; G/ [. P6 B& x0 b/ Z OBLONG 0.03500 x 0.07500 0.000 NO DARK - {( Z# ~ y3 Z- b9 ^# N
OBLONG 0.05400 x 0.15300 0.000 NO DARK 7 I: }$ v2 C1 U( g
OBLONG 0.06500 x 0.13800 0.000 NO DARK $ h! Q& G6 M8 Z9 A$ ~7 Y
& i$ z( W& ]2 N" F/ I OBLONG 0.06900 x 0.15000 0.000 NO DARK
" x; Z: B3 G" s3 A, O' o$ `! | OBLONG 0.08000 x 0.02953 0.000 NO DARK
9 H3 L* O5 T7 S+ L, w PAD SHAPE SHAPE20X28 0.000 NO DARK
y1 V k* y: h, G4 O0 G PAD SHAPE SHAPE20X28 180.000 NO DARK
E' J# k" E* R- a! D; g- [" J. t) n# Y' h( J! {
' Q& _, b2 z) b* j, r% b0 N; ~) ?* N) {/ ]% A* q% n) ^
& o" H1 i8 J, V# v1 N w Q5 T------------------------------------------------------
! c4 w, A" L$ }7 S7 f0 v SUMMARY:
8 S0 T% h# t8 E# Y$ _% C drill created with warnings# D* N: a. R" T& n: k2 d
: S' r4 z9 S( ~* c& q solder_top created with warnings
. `- x% A p$ f" o: q, F paste_bot created with warnings
" g: r5 f) L& Z: V$ L! S: s paste_top created with warnings; [" \1 o' H: L( K2 W2 p, e
- Z* E- ?! t$ v8 T. g SILK_TOP created with warnings
9 C* R5 W9 e( H: ]5 G# x *** ERROR with BOTTOM
+ I1 a6 s2 @1 n; |0 W: Y+ B GND2 created with warnings% v0 a, S( ]4 l
# ]- I6 \: M2 q, p$ @ POWER created with warnings9 J- R( y3 G& h7 ~" Q% q l& B
: k4 j5 X$ x8 |. `. n TOP created with warnings4 {, e7 H' m3 a8 _0 h' I" M+ n
ARTWORK Error |
