查看: 1545|回复: 2
请教版主,如下D码,如何编写CAM350的".arl"模板 (cr5000设计的)
发表于 2013-3-1 16:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
# 0 - mm
8 F# ]% [/ Y7 e: l+ H, {2 A" _" q' E# 1 - inch! g( R8 B* a6 I0 I( ~
# 2 - mil  o. t6 K+ ^; V" o& f
# 3 - micron2 O5 L- B6 n3 i2 M8 B0 f7 h, L
: [- @+ H% \- a3 CUnit             : 0! g, I( l* [! q' U0 Z0 |" N
; ~  ]( G+ H, S! |7 f# b#
# ^; N0 E+ L1 m) d* c/ \8 o& W# Aperture Table5 D2 n: Z+ U, y9 O
#; |) t( {( `5 v# W. @7 P
#  "[Code]:[Type]/[Posi,Nega]:[Figure]:[Size Parameters]"3 N' }4 T/ D, w0 y# j2 _+ L3 f6 q
3 x' O2 I9 x2 Z) t#   Code           - Aperture Code
4 w4 q" `9 m+ D5 J/ W#   Type           - 'F'(Flash),'S'(Stream),'P'(Polygon)1 X" O. e6 J+ _" n, o
#   Posi,Nega      - 'P'(Posi),'N'(Nega)0 d) ]& Q2 B0 J0 b8 r9 L0 p! ^
#   Figure         - 'CI'(Circle),'SQ'(Square),
$ `2 y8 M! i) N+ m6 \# F% L: W#                    'RE'(Rectangle),'DO'(Doughnut)
0 U# b" q/ v0 g# K( b#                    'RT'(Round Thermal),'ST'(Square Thermal),
/ x6 h2 k2 a/ b# y2 A#                    'CU'(Custom Aperture)
& k' B( Y" Z5 p5 b9 s6 U0 N+ P4 ?#   Size Parameter - Figure is 'CI' -> '0.1'
6 i0 R* E9 x* ?( c" `; Q9 b#                                      Circle Diameter (Radius x 2)
* H; j0 ]! z5 c8 A( K#                    Figure is 'SQ' -> '1.0', `+ H8 R' F" T& ]: O+ W
#                                      Square Width+ V7 i" A% x0 y1 R: P5 ?! J+ _* Y# ^
#                    Figure is 'RE' -> '2.0/1.0/30'* a. P+ `( F  G  J
#                                      Rectangle Width,Height and Angle
) y4 u3 ^. L& f5 p- ]& S8 o6 R) ]#                    Figure is 'DO' -> '3.0/1.0'
0 c0 p: H# n3 ]( P) ?2 @#                                      Circle Diameter and Inner Diameter& I' d& f( X+ R& D3 @5 V6 g+ B2 B4 G
#                    Figure is 'RT' -> '3.0/1.0/0.1/4/0'( Q! x( f# c& `
#                                      Circle Diameter,Inner Diameter,
- W4 D: ]! _. g) u2 o' h( e#                                      Slit Width,Slit Count and Start Angle
  A' E# w0 @2 Y" i0 B: E- n% F#                    Figure is 'ST' -> '3.0/1.0/0.1/4/0'+ F4 G8 ~! t! d2 Z8 T7 J" o
#                                      Square Width,Inner Square Width,: \, {3 Z. n. j. _9 ]* T; D* {5 a' }
9 y: [, V2 r/ o- Q  z7 e2 e#                    Figure is 'CU' -> 'XXX/0'7 q) z0 h, H. ~' ?& v
#                                      Pad Name and Angle
1 H+ l+ u/ O- Q/ u: `1 J#& z' c/ L+ L! U
ApertureTable 1 {2 S! V0 `2 z2 q% h( m2 L9 G5 [( {) L
    "D010:F/P:CI:0.08500"
6 l6 Y1 Z# G* B4 U( c& p2 j' c   9 r2 ~6 P2 E" q
    "D193:F/P:CI:10.00000"
) _+ k& w$ e" g+ U$ Q7 X( p( C; n& U    "D201:F/P:SQ:0.10000"  |! j4 I3 h0 t( ?0 b
9 ~; X" q4 F) O    "D510:F/N:RT:1.00000/0.60000/0.30000/4/45"/ @) M& a8 c3 t0 d" G6 J
   6 M/ Q9 o5 n) R/ [/ h' g
    "D560:F/N:RT:6.00000/5.20000/0.40000/4/45"
0 N" K% r1 U7 J+ o}
发表于 2013-3-27 19:06 | 只看该作者
看不懂
 楼主| 发表于 2013-4-24 10:31 | 只看该作者
已解决,谢谢大家支持
GMT+8, 2025-7-14 11:22 , Processed in 0.125000 second(s), 23 queries , Gzip On.
