本帖最后由 jacklee_47pn 于 2012-11-17 08:47 编辑 " v- {6 }% U9 L- X; U- P: ^
' a9 ~6 f8 H) Q9 D
在 A Guide to Voltage Translation With TXB-Type Translators http://www.ti.com.cn/cn/lit/an/scea043/scea043.pdf 裡面一段話,3 v3 l) p/ i8 o2 d9 Z
8 M8 L. w3 f2 ^- ~& G' a
The TXB push-pull buffered type architecture does not require a DIR control signal to establish the" d9 ^0 j0 D" a3 [" S1 i( u2 h8 h
direction of data flow. This architecture is designed to exclusively be connected and interfaced with a
( _7 _' E7 I* K& Rpush-pull CMOS driver and is capable of driving a capacitive or high impedance loads in applications such as Secure Digital (SD) or Serial Peripheral Interface (SPI). The TXB010x devices are not intended for use in open-drain applications. For applications such as I2C where there is a need to connect and interface with an open-drain driver, TI offers TXS-type (i.e., "S" for Switch-type) translators. Please refer to TI application report, A Guide to Voltage Translation With TXS-Type Translators, literature number SCEA044 for more information on the TXS-type voltage translators.
: Y2 U. h7 O" k( { F8 H) |" A
7 ^0 V) e, y3 U0 ~8 d) D2 {3 H所以看來你應該要選用 TXS0102 才對。5 E# S* X4 }; D
