请各位高手帮忙看看,orcad导入网络表后出现如下的错误:
$ o1 Q6 v% k h, c" |+ UReading file -- C:\ORCAD\FIC8120(REWORK).asc
& d2 m, @& ] y+ a3 Q*Unspecified or unsupported version of ASCII file. n2 W3 A" }0 i
*pads-PCB*% t6 x& I" U' C( b2 A% U1 v
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal ARMICESEL2 t; z& w* e9 O# U( d
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal ICE_GOICE
: d: e, q& Y& U- l- G/ B*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal ICE_TCK
9 y' o% ^ ~/ E. @; S- m Q6 y4 [*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal ICE_DBGACK
9 K0 X# C" W8 l8 {* a*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_PHY_LINKSTS( U1 f, [" w% t9 S' F* E6 M4 D
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal ICE_TMS0 ?7 M9 I1 _* E
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_RX_DV# i) J( K( ]8 Q2 J$ W( g
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_RX_ER. p6 _8 [; Q1 ?- b9 h* Z8 e
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal S4_TXD
% b! h" K% ~% l/ s- `3 D*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_RX_CLK8 ` @! R" ~+ P3 l9 ?! Q
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal ICE_TRSTN
- J7 k4 z# {" b, o, ~! G+ t2 @*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_MDC
k1 y) k9 u: v7 N( E7 f& C4 H% Z x*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal S4_RXD
/ n( s* c' B; S+ n* [- r*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_TXD0
* |. I, o. Q: H3 F6 ~9 |' A*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_TXD1' M6 b! q, D7 W
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_TXD2" w# R! q9 [+ y0 j+ K! \. j
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_TXD3+ `, X( M4 F; f, w f
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal S2_TXD_168669715 D$ t% Q" \$ I3 r, U1 S' U$ V
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DO6_16866325/ I% r3 ^2 h; Z# A) [ L8 a$ B
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DO7_16866325
( d4 ^* w4 R# i4 y6 z6 N*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_PCLKIN_168663259 H0 E) C" o1 C' Z9 r. ?& t
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_RXD0: \. w& H& n j1 V7 U5 k
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DO5_16866325
2 h8 H0 N* O/ J0 l( n1 V*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_RXD16 Z& \/ Y9 ~/ n
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal U_VBUS_16866872
! K! j1 i( h3 I& }: I- I0 s" p*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_RXD2
* e/ I& o1 \8 ^: m( A O*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DI5_16866325: y# w# ~! B& F0 Z
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_RXD3' o* K$ `# K# j. o( W$ N
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_PHY_LINKSTS_16866325. p- L, q% ]% E- {5 [' r; t5 o) h
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal S1_TXD_16866971 b& V) l" B1 X
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal S3_RXD_16866971
( \, j* l( `9 y3 [! F2 X3 m) K4 Q*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal U_PWM_EXT_16866872+ U1 ~( H: W2 C* Q9 V% r
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DI3_16866325# o2 d) C/ Z' _( T. x
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DI2_16866325, F% S$ ^8 k6 `4 Z
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal U_PWM_OUT_16866872) b7 M% b* R) s$ `2 d# g
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DI0_16866325 q! H+ L7 j% v* T4 O
& f# y0 B0 e: [. o* K*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DO0
B5 O) q) b8 M! h* w*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DO1
0 P9 E3 g) G/ ?% V' ^3 s" `7 C*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DO2
9 O" q" r5 z! B*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DO3
) A1 ^" A; c( h- J+ ]*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DO4$ |9 y/ | S( a% I
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DO56 p* e0 s# o; r2 c9 I) x8 f. l1 Y
* f ]6 I* }: D8 t# i, U*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N20752712: r6 D& N" ~6 K6 Z. W3 ` e
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal U_PWM_PDMOS
; ~+ T9 x" f; d/ F6 c*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N185289021 x2 u% |5 j2 N# n$ | E
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal A3.3VAUD
1 N9 G7 `+ Z" A$ N*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal S2_RXD# Q, k; q# O; F; g
/ w7 [/ S, v* {$ Y1 l2 ~) `*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_RXD1_16866325% C* _/ a6 _/ K7 m( [9 K
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_RX_ER_168663259 ]* b4 Y( e3 C$ \! @$ ?$ ~
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_MDC_16866325
* W) b- K( D& T% p: R( e$ H9 ]*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_RX_CLK_16866325
8 z) U) v! k. D0 ?9 b9 X7 v# ]! }/ n*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_TX_CLK_16866325: O2 v- T# C0 m' V
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DO2_16866325
! N4 D) L6 c& u7 f' N*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_CRS_16866325; e! `8 _3 K8 _
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_COL_16866325
, u, U! p0 @. q1 V*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_RX_DV_16866325
3 i# L' u% f( n/ {*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_TXD0_168663251 p5 b- ] f5 H; d; C
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_RXD3_16866325
6 F; k" B% y9 g" S1 C*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DO4_16866325! {0 a& U' X6 T' c" R- P
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DO3_168663255 L2 J* }7 m& m2 a. v4 K
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DI6_16866325
( q$ v& N4 B6 \2 e. ]$ D' n*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DI4_16866325
: k3 Q6 o/ t5 r5 n5 L7 P* s*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal S4_TXD_168669710 ?1 c/ `1 x9 L- i2 B O5 o
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_TXD2_16866325
7 \& G3 ]4 h0 b3 c*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal U_PWM_PDMOS_16866872
) S' P; N( o( u4 Z& E*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_RXD0_16866325
8 D6 E: |8 h. ]7 j# k. q0 Y1 b*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DO1_16866325
e8 s0 x9 \5 Z* A0 w*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SD_WPN_16866872
5 t m0 u* A% K) F. p; f L, p0 M4 K*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DO0_168663252 b1 ]6 {" D+ M: j3 j! t
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SD_CDN_16866872
$ _) \6 P# t: H! q! B' r; ~/ A*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_RXD2_168663254 U, A+ W. q5 w
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_TXD1_168663258 V5 ^4 }4 o$ N7 v- j5 h
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_TXD3_16866325% ?1 G' I8 A) D
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal S3_TXD_16866971' ?! C2 n; I4 s0 m2 b
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_TX_EN_16866325# m4 C) p- H" L5 T! c# V
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal S1_RXD_16866971
2 B: p7 ^; s* ^: l' v2 J*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal S4_RXD_16866971
2 q. C( j. V: r* X$ o. `: W*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DI7_16866325- I4 A8 r6 m) E
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal S3_RXD* L I, G- c" c8 c$ R
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_DI1_16866325. Q9 W4 k+ n; B, P4 z7 a
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal S2_RXD_16866971
5 r) n u' b) E) T8 b# {. A, o% P*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal S1_TXD
+ Z d+ r* y: [" l) @- V# B4 r*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_TX_EN- c8 C; W# A0 o/ X, G
& w% c! c$ G, V, ~*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal S1_RXD
' s) g6 l/ H- j) c$ G*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MAC_TX_CLK, ^1 B/ [% \! O5 l. x7 X; e
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal ICE_TDI3 B* Z% N c' p
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal ICE_TDIO8 n+ Y8 S( C/ I4 A6 V! R3 \
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal V_CLKOUT
" k% o! C! _! m! U3 LWarning: deleting signal ARMICESEL; f( T# o& J9 i/ M1 P D
Warning: deleting signal ICE_GOICE& D$ a6 E/ \1 j! Z7 V
Warning: deleting signal ICE_TCK
7 A# K# [ w* }$ eWarning: deleting signal ICE_DBGACK/ u! k: p8 |( v3 z% h, A' _
Warning: deleting signal MAC_PHY_LINKSTS$ c" A6 _2 n1 i4 S9 S+ j0 `$ l
Warning: deleting signal ICE_TMS8 x: t1 [% {2 u8 Q7 D' I
Warning: deleting signal MAC_RX_DV6 z( w; }$ {/ h, y
Warning: deleting signal MAC_RX_ER3 Q" o- S* a+ ]" s% B% D' L
Warning: deleting signal S4_TXD6 C. _7 T$ B! [) p, j) M
Warning: deleting signal MAC_RX_CLK! X2 B) l. U' {/ ^8 O0 ^
Warning: deleting signal ICE_TRSTN
& V3 k$ h/ F* |1 PWarning: deleting signal MAC_MDC
9 P/ \( G( ?- v" @+ N+ LWarning: deleting signal S4_RXD
9 _( U6 ?( D7 A' uWarning: deleting signal MAC_TXD03 B9 d) v1 D( ?% _# }' p
Warning: deleting signal MAC_TXD1* V& V8 P5 a8 T: }
Warning: deleting signal MAC_TXD2
4 X# Q1 f- ^1 L7 J; a7 kWarning: deleting signal MAC_TXD3/ R% g. S* N8 }+ G2 F9 s
Warning: deleting signal S2_TXD_16866971# C) {0 F* z/ N& d; q
Warning: deleting signal V_DO6_16866325
; ]6 ]! {. `! TWarning: deleting signal V_DO7_16866325- `7 J+ D) ~& q# w8 j2 ]
Warning: deleting signal V_PCLKIN_16866325
# S, n" X8 z" F: S# TWarning: deleting signal MAC_RXD0
- R* l, I3 T1 I# vWarning: deleting signal V_DO5_16866325( X }! p6 V' c" T
Warning: deleting signal MAC_RXD1
+ v3 X8 D' \/ z* Z9 Z0 L# N2 DWarning: deleting signal U_VBUS_16866872
& }; d. U$ N, J% uWarning: deleting signal MAC_RXD2
! M" d/ L5 ^$ p2 U7 J$ A% AWarning: deleting signal V_DI5_16866325+ P6 K3 a( H: ~0 Z u
Warning: deleting signal MAC_RXD3
& U6 i5 I, x0 z. h& L3 _) e* PWarning: deleting signal MAC_PHY_LINKSTS_16866325
( `, ^7 H$ |8 i. [) q0 s/ ?Warning: deleting signal S1_TXD_168669712 F4 R2 `$ e; n5 R: j% e# _. i
Warning: deleting signal S3_RXD_16866971% W; I5 |0 y% }, Q( K4 z
Warning: deleting signal U_PWM_EXT_16866872
# X8 T+ M) N c/ T2 b; V. HWarning: deleting signal V_DI3_16866325
6 Z( ^# T3 m! OWarning: deleting signal V_DI2_16866325, y& V1 d, V" R
Warning: deleting signal U_PWM_OUT_16866872
Q+ ^# \! q* C+ g0 AWarning: deleting signal V_DI0_16866325 d, N) \7 h y
4 o6 E3 E( K9 [4 V4 h/ C" x" E$ bWarning: deleting signal V_DO0
8 P1 b: A6 A# y# b& J2 gWarning: deleting signal V_DO1
. p$ @& \. r8 N% a; Q: c, o/ vWarning: deleting signal V_DO29 V! L6 ]: \3 p
Warning: deleting signal V_DO31 ]& B- Y8 t5 [- @, P' F8 x
Warning: deleting signal V_DO4
; d% B7 k, u8 R3 e2 vWarning: deleting signal V_DO57 L8 c& G, o1 ]+ q
Warning: deleting signal V_DO6% b7 m- R" Z+ U' T, `' H' z' N( t, Q; A
Warning: deleting signal N20752712
" r M! S: c. y4 dWarning: deleting signal U_PWM_PDMOS
f/ @: [9 n0 }' m6 P* _3 |4 \Warning: deleting signal N18528902
! M$ Y: i C0 C. X' K$ ^Warning: deleting signal A3.3VAUD
, x4 Q+ }( I1 W4 @' z5 `Warning: deleting signal S2_RXD
) i z; S# |; r% Y( q; Z$ M0 WWarning: deleting signal S2_TXD% q4 \8 J* V- l
Warning: deleting signal MAC_RXD1_16866325
4 G: f) Q% Q& z& @3 _$ {) QWarning: deleting signal MAC_RX_ER_16866325 ?" {+ x9 C6 u+ W) o0 ^, I
Warning: deleting signal MAC_MDC_16866325/ L" ]0 ^/ D& G4 r2 E
Warning: deleting signal MAC_RX_CLK_16866325
$ p2 l! k! K9 Q3 i: uWarning: deleting signal MAC_TX_CLK_16866325
5 _( o% a: H- d, W9 H) rWarning: deleting signal V_DO2_16866325' X/ \& ^* @ P/ X _
Warning: deleting signal MAC_CRS_16866325
1 Y' C0 q$ ^6 k2 |* U+ M qWarning: deleting signal MAC_COL_168663252 l: J, [! @! e
Warning: deleting signal MAC_RX_DV_168663253 p5 i- z/ Z$ {" k8 P1 G4 ]
Warning: deleting signal MAC_TXD0_16866325
+ ~, O" [: d9 x: u0 l dWarning: deleting signal MAC_RXD3_16866325
! S |6 E6 r$ t5 G Q( z9 s bWarning: deleting signal V_DO4_16866325
) K& F; h; `. p; p! d D( U( jWarning: deleting signal V_DO3_16866325$ C' t/ L1 g6 R( D
Warning: deleting signal V_DI6_16866325
' Q0 n/ k6 H0 CWarning: deleting signal V_DI4_168663255 b# C2 L& E' z2 N3 U/ ^
Warning: deleting signal S4_TXD_16866971
) Z/ A$ e$ |) z, R8 t- LWarning: deleting signal MAC_TXD2_16866325& x* E" {' y6 O9 ~& ~
Warning: deleting signal U_PWM_PDMOS_16866872
. W% K) E' r" s1 D) h/ lWarning: deleting signal MAC_RXD0_16866325, z) }! t% W' q* O/ Z9 N# \
Warning: deleting signal V_DO1_16866325( ]% @! t* x e) ^
Warning: deleting signal SD_WPN_16866872
' s+ e7 i' o/ D) zWarning: deleting signal V_DO0_16866325
3 Y2 K' M4 {6 A& H( H( l1 |8 BWarning: deleting signal SD_CDN_16866872; k* n& G' V% w2 y# w3 B1 X Y
Warning: deleting signal MAC_RXD2_168663252 ?1 a7 U3 b3 e( A7 X: V
Warning: deleting signal MAC_TXD1_16866325
2 l: J3 K1 O5 T% [) Z- MWarning: deleting signal MAC_TXD3_16866325" E6 D! c1 |; W8 ~( X
Warning: deleting signal S3_TXD_16866971; r( Z3 u% g2 X2 i+ [( c
Warning: deleting signal MAC_TX_EN_16866325+ x% r; D8 a% U$ R) }! F( }
Warning: deleting signal S1_RXD_16866971) r) `( o( t8 R2 D5 m
Warning: deleting signal S4_RXD_16866971
" J- L/ P- k* o) t! F, z% _+ MWarning: deleting signal V_DI7_16866325# M0 J( _2 \+ j+ B0 ]
Warning: deleting signal S3_RXD0 \: R5 g* {; o+ k
Warning: deleting signal V_DI1_16866325
/ e" M" k4 s8 @! }5 tWarning: deleting signal S2_RXD_16866971 ?+ c+ j$ a& z" v9 ~' U; C
, l: r# C" H5 b) h( eWarning: deleting signal MAC_TX_EN
4 E1 e1 _; x4 E. w" g0 D* V/ D/ v. ?Warning: deleting signal S3_TXD
9 [ e7 i1 X2 o0 q8 z7 q% CWarning: deleting signal S1_RXD
+ I$ G' G" I% P) ~# k" c# MWarning: deleting signal MAC_TX_CLK
7 T4 d) c) x7 ~* |! \Warning: deleting signal ICE_TDI
! L4 |: R- ~. O+ |( NWarning: deleting signal ICE_TDIO
1 D0 a; \) i# a ~. B; }8 X' N+ ^; \Warning: deleting signal V_CLKOUT
9 f2 J' R1 I7 L. Z**INPUT WARNINGS FOUND** |
