查看: 1756|回复: 3
SPB 16.5 Hotfix 030
发表于 2012-9-29 11:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
cadence最新版软件SPB 16.5  Hotfix 030
' n1 |8 ^. s$ Z: _0 Y' ?. y& phttp://www.pspice.com.cn/read.php?tid=5951
( E6 f! v7 L4 \! v* ~: \8 J& o% n4 k' E; H& o, b4 v
6 K+ _+ a# ^$ f$ i9 q. UHotfix030对以下项目做了修正:3 [* M2 w* N4 r+ g$ a
DATE: 09-21-2012   HOTFIX VERSION: 030! k1 F- }; b- o( U' ]
==============================================================================( |8 B* h0 Y  l, U. s& V& Z
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE6 ?1 \" X. r. f' U" a  S
  @% `3 ]/ y' F1008113 FSP            VIRTUAL_INTERFAC importing Altera constraints verilog to make virtual interface only small percentage of nets have IO standard
6 j  V5 G6 f; }  Z( p) S1042199 SIG_INTEGRITY  SIMULATION       Waveform list was not refreshed by switching tab.3 ]5 T8 D  H; [
1042348 SIP_LAYOUT     STREAM_IF        GDSII export includes the full refernce path, breaks CATS flow
" r3 I& y+ _! I3 ~7 ?* g5 `1046527 allegro_EDITOR INTERACTIV       Display Segment Over Void not working correctly.
$ B7 J4 C# Q7 {. \( q1047590 ALLEGRO_EDITOR SCHEM_FTB        Buses created in Allegro-CM are deleted by netrev in traditional flow* R4 `$ C6 L- `8 W6 v9 A
1047969 ALLEGRO_EDITOR NC               Some route path missed in .rou file./ ^! j2 C! ]1 y! N
1048907 ALLEGRO_EDITOR OTHER            PDF_OUT is very slow; X: b$ I; {. `2 I
1049262 ALLEGRO_EDITOR OTHER            APD and extracta crash owing to Wirebond.# ?8 j& S4 ~: g+ u8 U- Y
1050408 APD            DXF_IF           Symbol has 45 degrees rotation  in mcm but DXF doesn縯.
+ W2 n( A, w% [" p' i% F7 Y/ h1052045 ALLEGRO_EDITOR OTHER            Bug - Thermal relief connects not sustaining 15 degrees component spin in version 16.5 unlike v16.3
; R- f4 j* r9 }* y* N7 b) W# H1052600 ALLEGRO_EDITOR SHAPE            Adding a specific cline causing shape errors4 V3 C/ @$ r( o& Q
1053065 MODEL_EDITOR   GUI              The About ModelEditor form indicates an incorrect version.) S) A6 p# ^2 U' t% J% E! k
1054008 concept_HDL    CONSTRAINT_MGR   Out of memory error while launching CM within DEHDL+ D1 K& ]! h  o+ y, O
1054269 ALLEGRO_EDITOR MANUFACT         Backdrill Setup and Analysis crashes on attached design
7 Q6 c" S- g7 c- C8 t' S1055273 ALLEGRO_EDITOR INTERFACES       DXF exported from Allegro has an offset in pad location for Y- direction.
    2021-10-7 15:18
    发表于 2012-9-29 22:22 | 只看该作者
    谢谢lz!
    发表于 2012-10-2 09:33 | 只看该作者
    thanks for you information
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    发表于 2012-10-15 11:21 | 只看该作者
    感謝大大分享提供..
    GMT+8, 2025-9-10 21:50 , Processed in 0.109375 second(s), 24 queries , Gzip On.
