TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
Features0 s4 q- K+ _, W) @2 n/ [9 R
SMALL VOLTAGE OFFSET: SiD2296: ±0.5mV (MAX) WIDE COMMON MODE VOLTAGE: SiD2296: -0.1V to +85V±0.5% Gain Error (Max, -40°C ~125°C) 0.6μV/°C Offset Drift (Max, -40°C ~125°C)WIDE CMRR THROUGH COMMON VOLTAGE: 100dBSUPPLY VOLTAGE: 3.0V to +18VACCURACY and ZERO-DRIFT PERFORMANCE 5ppm/°C Gain Drift (Max, -40°C ~125°C) THREE GAIN OPTIONS for VOLTAGE OUTPUTSiD2296T: 20V/VSiD2296F: 50V/V SiD2296H: 100V/V
( Y* L( A P7 q! |4 u/ EDescription: x/ d1 Y+ x/ V) Y7 l: d8 j
The SiD2296 family is of high voltage, high side current sense amplifier with voltage output. The SiD2296 can sense drops across shunts at common-mode voltages from –0.1V up to 85 V. The SiD2296 are available with three output voltage scales: 20V/V, 50V/V, 100V/V, with up to 0.5MHz bandwidth.The SiD2296 operates from single 3.0V to 18V supply, offers breakthrough performance throughout the −40°C to +125°C temperature range. It features a zero-drift core, which leads to an offset drift of 0.6μV/°C throughout the operating temperature range and the common-mode voltage range. The SiD2296 is offered in 6-pin and 5-pin SOT23 package.
7 z* p, v/ T. r/ f8 dApplications3 t* O7 Z) z5 ]
CURRENT SENSING (High−Side/Low-Side) BATTERY CHARGERS & POWER MANAGEMENT
6 {, K' z2 a2 g6 |( J$ p7 jAUTOMOTIVE & INDUSTRIAL CONTROL BASE STATIONS & TELECOM EQUIPMENT
+ S O3 G' ` V# b: r8 f
. l! B" o4 v; _. V8 U" f. }. s7 O9 ?9 B$ s
