“标准”答案还没出来?
* `; V3 T4 w5 O* [. c记得LNK302的官方电路,整流电路前端也有这么一个大功率小阻值的电阻RF1,
# H4 ~6 u7 p* R0 e. e1 ]0 |2 QResistor RF1 is a flame proof, fusible, wire wound resistor. It accomplishes several functions:( F5 K2 _8 A! L! o
a) Inrush current limitation to safe levels for rectifiers D3 and D4;- l+ V! j7 g5 l6 W% m B8 ]& c
b) Differential mode noise attenuation;
; c0 K0 P$ U% x1 Y v c) Input fuse should any other component fail short-circuit (component fails safely open-circuit without emitting smoke, fire or incandescent material).5 ?" m3 D; v4 q, V
( w B2 n3 l" X& s& H+ {
3 [: g! p4 h$ A5 b u+ v8 {$ ] |
