TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
Features, X- @! [* y- K" c2 N: k
9V to 100V input voltage range
* _* B! |+ j5 L, K6 s4 l' \/ j 1.5A/5A continuous output current
5 }; i# W g$ j) F0 B8 w! ~ 95% Peak Efficiency5 i1 t' p' |; p" l l
400µA operating quiescent current2 U' d: c5 T2 w
100V 400-mΩ high-side MOSFET
: e8 Q# u) i h: I8 H Peak Current mode control
! L8 o d6 k! ^& s1 ^/ s1 a 150 kHz Fixed Frequency
+ u' c1 ?( d7 o5 q Internal compensation for ease of use7 u& R' Q# d4 a& q$ A4 R! |
Up to 92% duty cycle
% O: x, I4 N6 J 0.8V voltage reference
! [- I8 D. c8 B0 `1 g4 l 1µA shutdown current& \+ q/ s }: [ E3 l/ w
3A/6A cycle-by-cycle current limit$ I: B$ s$ Y8 k
150ms Hiccup mode short circuit protection+ ^. H+ a; |9 h- |9 r
Function
6 b, U) f; a; F: N! G2 f( e Thermal shutdown Function) x; [, d( @# w* x, t
ESOP-8 package
$ w* }& i* h$ I; J0 PApplications
& x. h+ j+ L- [1 _# v$ ~ Charger in vehicle& k- N! M% N8 y
Battery Chargers* ^( ]6 \+ ^1 ]0 V8 o/ J
Power adapter
( R" O6 Z! Y" H0 BTypical Application5 h1 [/ n/ l. u1 f
Description
( e. X& U( K, ~% ?4 b3 m- WThe ZCC1005 is a high voltage, non-synchronous+ d2 j9 F" K b3 ]/ }
step-down converter operates over a wide range8 _- O( ~3 c. T& k6 ^) U& z
input voltage) L, d3 `1 |/ a- z* ?
9V to 100V. The ZCC1005
9 ^0 @& f) _" C0 T [integrates a 100-V 400-mΩ high-side MOSFET.
% v* r+ S9 `' ~7 WThe ZCC1005 delivers 1.5A continuous load
2 F* ~) d7 z' d8 H. [6 Scurrent with up to 95% efficiency. The ZCC1005
. F* _8 o( r- j% c2 ]operates with fixed frequency peak current control* Z4 ?, v6 t3 M; @; K# x+ V
with built-in compensation eliminates the need for
9 O, f* k0 \7 aexternal components.1 N; }6 V4 [' W5 [4 c
Cycle-by-cycle current limit in high-side MOSFET
. {1 w0 n5 D/ O6 D( Pprotects the converter in an overload condition.; m. z- k6 a0 ]8 H1 n
Hiccup mode protection is triggered if the- P; o" H7 Q/ v3 k: e
over-current condition has persisted for longer than
$ y0 s7 u: ~# n1 k4 |7 ethe present time.) n* h5 ^1 K# m) h+ y
The ZCC1005 exhibits protection features that W4 M0 S2 S% w( _
protect the load from faults like under-voltage,( G; G+ ~; Z" Y0 `
over-current and over-temperature.
) g1 v+ h5 u7 B; g- v3 i1 x8 NThe ZCC1005 is available in an ESOP-8 package.( c% O- B) f! ]5 [# G0 C% B
