查看: 14560|回复: 95
发本SI方面的新书——Jitter, Noise, and Signal Integrity at High-Speed
发表于 2008-7-9 17:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
看看大家有没有需要哈 Jitter Noise and Signal Integrity at High-Speed[Jitter Noise and Signal Integrity at High-Speed (Prentice Hall Modern Semiconductor Design Series' Sub Series: PH Signal Integrity Library)5 m1 n& L8 G  {9 L+ W. j: G: f% O  A
By Mike Peng Li
- ~/ k7 b! M' o1 T# i! M7 r) J/ R' u
! u2 r+ S5 C8 e$ o
$ ~( P* ^- h% X+ B4 {Publisher: Prentice Hall PTR
9 `: A: w; v( i6 ]Number Of Pages: 400
5 N' m& E6 c. r5 H3 D; |Publication Date: 2007-11-29 0 M3 c8 |+ f, E
ISBN-10 / ASIN: 0132429616 ) R2 X( J0 U) C- W! H+ h7 f' X6 t
ISBN-13 / EAN: 9780132429610
2 I8 f: y& \# KBinding: Hardcover
$ E1 H* P: ~0 w6 j/ u/ e8 I1 o4 ?$ J3 t3 \
. n) W! w3 q( S) x  q6 oProduct Description: , P+ [0 F0 B7 A& j% {2 D% \
State-of-the-art JNB and SI Problem-Solving: Theory, Analysis, Methods, and Applications/ M0 Y. d. B. L% @
1 L9 d; p6 Z# E9 _Jitter, noise, and bit error (JNB) and signal integrity (SI) have become today‘s greatest challenges in high-speed digital design. Now, there’s a comprehensive and up-to-date guide to overcoming these challenges, direct from Dr. Mike Peng Li, cochair of the PCI Express jitter standard committee.
) H' @# F9 {) z/ _4 Q: p; q
3 }& P. ]' S! F% G  Y! }One of the field’s most respected experts, Li has brought together the latest theory, analysis, methods, and practical applications, demonstrating how to solve difficult JNB and SI problems in both link components and complete systems. Li introduces the fundamental terminology, definitions, and concepts associated with JNB and SI, as well as their sources and root causes. He guides readers from basic math, statistics, circuit and system models all the way through final applications. Emphasizing clock and serial data communications applications, he covers JNB and SI simulation, modeling, diagnostics, debugging, compliance testing, and much more.
& S1 I/ ~2 s3 m# A
: p* n7 s' h6 p& @' zCoverage includes . V$ r# V0 [0 @6 C! |1 ?8 {0 }' n
' X, y2 R) W' d  [
JNB component classification, interrelationships, measurement references, and transfer functions
. F9 _2 O% j3 `Statistical techniques and signal processing theory for quantitatively understanding and modeling JNB and related components
! H' X! {7 E: u' ]3 n1 S! U9 WJitter, noise, and BER: physical/mathematical foundations and statistical signal processing views
. S" u! @* S4 V# {( A1 nJitter separation methods in statistical distribution, time, and frequency domains
" L. J+ [9 \' V+ u# m, T0 bClock jitter in detail: phase, period, and cycle-to-cycle jitter, and key interrelationships among them
1 l1 k9 N) r; M0 s, {1 g! ^8 WPLL jitter in clock generation and clock recovery 4 T& g( _  D$ R* G, D( L/ n* `
Jitter, noise, and SI mechanisms in high-speed link systems
. w! l- [+ e6 D: nQuantitative modeling and analysis for jitter, noise, and SI ( |. d) f3 ]- Z5 n
Testing requirements and methods for links and systems
/ H3 s/ g) m; [Emerging trends in high-speed JNB and SI1 R) O. [: H" W; k
As data rates continue to accelerate, engineers encounter increasingly complex JNB and SI problems. In Jitter, Noise, and Signal Integrity at High-Speed, Dr. Li provides poweRFul new tools for solving these problems–quickly, efficiently, and reliably. 4 ?$ {/ T1 z' L# e5 I
: T' E: C; j# Y8 F; r
Preface xv
5 S5 Q  J7 _: x9 D5 j8 p* w/ `# l8 PAcknowledgements xxi
$ x$ z# H* z- N. h. `3 JAbout the Author xxiii* r0 a0 m- u! R7 ~7 P
% h* r$ O# N( O# KChapter 1: Introduction 19 X: `& G5 ]* r1 B
Chapter 2: Statistical Signal and Linear Theory for Jitter, Noise, and Signal Integrity 27+ M( D# h* d' i) a' E+ j, f+ g% v
Chapter 3: Source, Mechanism, and Math Model for Jitter and Noise 75
1 Z, a- A6 l, |$ \Chapter 4: Jitter, Noise, BER (JNB), and Interrelationships 109
3 [. u7 F! ~0 I' SChapter 5: Jitter and Noise Separation and Analysis in Statistical Domain 131
$ s9 b3 v, c1 P( V! W- dChapter 6: Jitter and Noise Separation and Analysis in the Time and Frequency Domains 163: q/ B5 L, C  J+ a% y1 h/ q
Chapter 7: Clock Jitter 1852 W, _4 {. o9 F3 C+ I+ g& O/ _
Chapter 8: PLL Jitter and Transfer Function Analysis 209; R# I/ E2 d: z3 ?! h* I
Chapter 9: Jitter and Signal Integrity Mechanisms for High-Speed Links 2537 u9 g- `  O" P- {9 t: ^5 S! X4 V
Chapter 10: Modeling and Analysis for Jitter and Signaling Integrity for High-Speed Links 281" J3 g2 o; C( \# J. o* G
Chapter 11: Testing and Analysis for Jitter and Signaling Integrity for High-Speed Links 309; l+ U8 u* A: A5 c/ A
Chapter 12: Book Summary and Future Challenges 345
8 D& x' |3 Q8 n  C$ s: N: [' {$ G4 U) G) d1 z# x9 _4 j$ G2 l
Index 353
5 c1 i4 K& V, A% A' `4 z% T
7 D/ _2 E/ P8 }. L  u5 J9 N  [; l7 l4 y; X" w" X5 v2 Y6 M
. ]  n0 T9 d3 b3 x5 v3 g
9 e/ R$ s1 ^# N# r3 S5 `0 E$ l" v% h" u3 h
Summary: New Base-Line Book
( C4 `( E( g: e7 c7 o# v- CRating: 5
( ]& ?4 B  G/ z; N3 J5 ?. aStatistical methods are being combined with signal integrity methods for high-speed, high data rate, lossy
% U$ W1 f6 S# m$ i- ochannel design. This book becomes a valuable resource for defining, classifying and providing the ' y/ P& p9 j8 k5 H& K1 K
mathematical basis and graphical insight for jitter and noise terminology and the related techniques that 1 k! T  \& W+ v; j6 l7 w3 v* g6 D% L
are now becoming commonplace in EDA tools, presentations, application notes, and used in several standards. 1 ]2 E; m2 R- p" R8 j8 M- w
Even IBIS is adding an algorithm modeling interface feature to help access propretary information provided ( K2 f; c% A0 }2 o
by semiconductor vendors for more efficient channel analysis and design optimization. 1 {) ?1 a; [7 P  E9 e% m1 y
* ^2 X- m1 |* x4 [2 f. q& RSome inconsistent font sizing within equations and elsewhere are annoying. However, the book's primary ) q) A1 Z* h$ X- B. Z, W. R
value is that it becomes a new base-line for general and reasonably comprehensive information on jitter
! I1 w7 U* a3 C* ?1 B: X, ?& T3 ~and noise methodology for today's needs and future advances.
1 Z0 d* N3 x% R* z2 c/ K  S4 E4 H( `$ ]
5 Z8 `. C8 X2 `; Q$ o. uSummary: Jitter, Noise, and Signal Integrity
5 K+ `, ]# N  |1 I1 ~; dRating: 54 f: [- i* g% q* ^" c, Y
In this book, Mike Li offers an experienced perspective of the role jitter and signal integrity play in modern high-speed communication. While incorporating his own contributions to the modeling and testing of jitter in systems, his book provides a broader basis of understanding to the student seeking to build a foundation on the complexities of signal integrity at high-speeds.
0 g: R9 i: H; ]6 U
8 q+ i0 g) `0 C8 {! c7 o  KThe material of this book is a significant departure from other texts that discuss high-speed signal integrity. It focuses on the fundamentals of how different phenomena lead to different source of jitter and ISI and how we, as system designers, can untangle these problems. The text seeks to clearly distinguish different definitions of jitter and how these variously used terms are interrelated. Most importantly, the flow of the book helps demonstrate how jitter propagates through the system and helps analyze jitter in different system blocks. ) _, }+ n8 v' p
* ^% q- g5 f" d5 @1 R
This an important and exciting are at the heart of future high-speed electrical and optical and this is one of the first books that deciphering the challenges facing engineers in maintaining communication reliability.
# f' H3 s; ]8 y' ~* `- q1 |
# g$ Q% R% G' d# b) V! P# V( C) ~9 ^* J
Summary: Jitter, Noise, and Signal Integrity at High-Speed
& o) C% Z7 D0 g5 z% U2 eRating: 5
$ E: x1 L4 u  T! B$ _This book covers the state-of-the-art knowledge in high-speed wireline communication, including jitter analysis, system architecture, clock and PLL fundamentals as well as many more critical and advanced topics. It addresses cutting edge technology in the fields of design, modeling, and verification. It is one of the best books and must have so far in this area. Dr. Li's instrumental book can provide students, engineers, or researchers solid knowledge to understand, design and test high-speed
3 q# B4 a- B% \! D' n* j9 R" \serial interfaces.
4 j; d" b" g. g) u) d
. {5 z: Z; z1 A! K( \5 p5 B7 K, k: `. D: {
9 D2 k; t9 r& ^, x$ ~2 BSummary: A good book for novice and experts on SerDes testing, e$ }+ n0 H. l, ~7 u4 Q3 k
Rating: 5
& l. L0 E2 l2 fThis book has introduced the new concepts and techniques on jitter and noise. In the first half of the book, I found all the upto date information not only on concepts and terminologies, but also the mathematical models behind them. That makes this book useful for both novice and experts. As an very active player in the SerDes testing world, I found myself interested in even some of the introduction sections because of the math and modeling in a graphical view.
1 Y& r- I" p0 C" q! E& ?8 ?# u4 e
In older books, you can NOT find the new jitter and noise separation/interaction described in this. In some new ones, it does NOT have this much of detail. The second half of the book is particularly helpful for people that are getting into the practical test and measurement of jitter and noise for high speed serial links. 8 [. N5 t( E! V
! w& g" i2 x% V3 eNear the end, the book dig into the design concept to give just enough concepts for a test engineer to understand why he is seeing what he is seeing.
2 N+ X- P, E. B6 `. c3 r+ N& |& r
Over all, this is a book that can be used by a novice to get started in this fast paced new field, and it can also serve as a good reference for experts to dig out just what you need - a equation for a rough estimate, or a plot to help visualize the trend in your mind.
! X2 }! d' z3 P+ @' _4 t3 b2 f2 a/ C: F. D
Yi Cai, Ph.D.
8 z% S: y5 B; HTechnical Manager
% _) [" L9 ?0 R! u+ g7 bRead-Channel & PHY Core IP Test Engineering and Characterization
( T& w( H' X; [( D5 K8 H* N( |, KStorage Peripherals Group, LSI & {: S  I# u" U# A( {1 C
& v, q: Q) [* V# K1 D5 w5 O
; L$ w. K# B4 B* W
Summary: building jitter theory to work on high speed serial link PHY layer performance
5 c' k* {& ]+ cRating: 59 L% _$ R! v- u
This is one of the best books available today for people who need to quantitatively deal with jitter/BER etc. in high speed serial communication though one book does not fit to all.
( F5 Y, i" Y: x6 j; M% f
( F) t9 `2 L. W( j2 OThis book is not a tutorial or a how-to book which helps us quickly obtain some basic knowledge and apply it to fix relatively simple problems we face. This book is not a collection of examples/practices in which we try to find similar problems and solutions to our own problems. : c- f, X  f+ T. T
) h$ M. l+ y* U
In order to tackle more difficult/complicated problems, we would need more sophisticated knowledge/tools or we may even need to develop them ourselves upon existing knowledge base. This book serves as a text book describing such knowledge base by arranging the development in the past decade in orderly manner so that we can learn them in shorter time than reading a lot of articles one by one.
. y8 ?( c% |. w- Y3 {
9 w& g- d' B2 f- k) P) b9 n6 tThe problem here is occasional bit error in a high speed serial link. In order to deal with the "occasional" error occurrence, statistical treatment is required. The problem occurs in a system. Most of actual systems can be approximated by linear systems, or linear approximation usually provides us with good insight. Thus the basics of statistics and linear system are reviewed at the beginning. Jitter discussion begins with categorizing jitter in various components, which are related to the bit error rate. These jitter components are to be obtained from actual measurements in practice (there are several methods), and used to estimate the possible bit error rate of a system. Then after discussing the jitter behavior in PLL and clock signal, modeling high speed serial link (Tx, channel and Rx) is discussed.
& a0 R7 x: w: |3 ^4 k8 V" }- g) L- E. @; q( J, ?: B; b0 V& q
If a reader is more interested in signal integrity than jitter/bit error rate, he/she may not be satisfied with the amount of the signal integrity discussion in this book. What matters in the end, however, is bit error rate not signal integrity. He/she has a good chance to be back to this book after learning more about signal integrity itself.- ~+ m. Q- X& N+ I
0 S+ w; Y9 ?7 k' [6 l  U9 Q[ 本帖最后由 snowwolfe 于 2008-7-30 13:56 编辑 ]
推荐
 楼主| 发表于 2008-7-9 17:23 | 只看该作者
Jitter, Noise, and Signal Integrity at High-Speed.part1.rar
1.91 MB, 下载次数: 1552, 下载积分: 威望 -5
Jitter, Noise, and Signal Integrity at High-Speed.part2.rar
1.91 MB, 下载次数: 1612, 下载积分: 威望 -5
Jitter, Noise, and Signal Integrity at High-Speed.part3.rar
519.79 KB, 下载次数: 1208, 下载积分: 威望 -5
参与人数 3贡献 +15 收起 理由
jemy + 2
infotech + 8 感谢分享
ray + 5 感谢分享
推荐
发表于 2016-5-1 22:22 | 只看该作者
' ]8 B4 k2 N1 B' s6 F- Y
. q: O. k) t: n
Jitter, Noise, and Signal Integrity at High-Speed.part1.rar  m- q/ f7 |+ L0 J
1.91 MB, 下载次数: 1504, 下载积分: 威望 -2
4 x+ r$ z* b9 a" G  ]/ v, O" r" J& _8 i5 U, {
Jitter, Noise, and Signal Integrity at High-Speed.part2.rar9 c+ E% O, L& W3 q, d
1.91 MB, 下载次数: 1559, 下载积分: 威望 -2
# s/ x% e0 S1 n1 ~. E& _2 `  h  E# N) |- ?6 K9 a
) ~0 a; Z+ s, |  e& p519.79 KB, 下载次数: 1167, 下载积分: 威望 -2
推荐
发表于 2016-5-1 22:21 | 只看该作者
4 w1 d, }. v, W: G; L
Jitter, Noise, and Signal Integrity at High-Speed.part1.rar( s, ^5 h8 w7 i( p) W0 z: d5 m
; G) Q; s; j. T. {% ^, t. v & }, M! [2 R( p% L8 v/ A
  t* ?% K$ H& Q1.91 MB, 下载次数: 1559, 下载积分: 威望 -2" C/ Z) e( V( b9 v
* @' L# s$ k: s# a( a$ O" ?Jitter, Noise, and Signal Integrity at High-Speed.part3.rar
# \6 `6 t- z& h519.79 KB, 下载次数: 1167, 下载积分: 威望 -2
发表于 2008-7-26 21:06 | 只看该作者
正在整理这方面的资料。多谢楼主了!
发表于 2008-7-30 18:08 | 只看该作者
很有用阿,谢谢搂主!
    2019-11-18 15:02
    发表于 2008-8-1 21:15 | 只看该作者
    好贴阿,有时间一定要看看
    发表于 2008-8-2 09:22 | 只看该作者
    LZ很强大,2007年出的都有了电子版
    发表于 2008-8-18 20:32 | 只看该作者
    thanks
    发表于 2008-8-21 09:40 | 只看该作者
    Thanks
    发表于 2008-8-23 08:36 | 只看该作者
    顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶
    参与人数 1贡献 -5 收起 理由
    infotech -5 恶意灌水
    发表于 2008-8-27 09:10 | 只看该作者
    回复 1# 的帖子
    真是好书啊
      [) E; V4 b( h, n5 e% p  A7 N正在找呢
    13#
    发表于 2008-9-3 18:33 | 只看该作者
    参与人数 1贡献 -5 收起 理由
    infotech -5 恶意灌水
    14#
    发表于 2008-9-8 20:18 | 只看该作者
    hao 非常感谢楼主
    15#
    发表于 2008-9-12 11:50 | 只看该作者
    very good ~
    16#
    发表于 2008-10-1 21:45 | 只看该作者
    刚前几天看到 有这本书,想去下的,没想到这里就有了,非常感谢
    17#
    发表于 2008-10-29 17:02 | 只看该作者
    嗯,非常不错.呵呵,受教了.
    GMT+8, 2025-6-23 23:38 , Processed in 0.109375 second(s), 29 queries , Gzip On.
