错误提示如下:
! t! B7 z: b) jChecking Electrical Rules
. [& d2 w, \0 V1 F0 IWARNING [DRC0004] Possible pin type conflict VDD_DDR Passive Port Connected to Passive Port: Digital board, 1 C10P RAM (3.96, 7.39)
7 x0 ^9 ]( s' o' j: V' u* X. v) U9 SWARNING [DRC0004] Possible pin type conflict DVDD Passive Port Connected to Passive Port: Digital board, 1 C10P IO (9.47, 1.38) $ R, u& z: S( Z" o1 B
WARNING [DRC0004] Possible pin type conflict DVDD Passive Port Connected to Passive Port: Digital board, 1 C10P IO (10.20, 7.50)
4 ?7 ?: Y; R0 Y' |) F' ?( }, SWARNING [DRC0004] Possible pin type conflict DVDD Passive Port Connected to Passive Port: Digital board, 1 C10P POWER (2.78, 5.38) ( k% N) Y! T6 `- a
ERROR [DRC0003] Port has a type which is inconsistent with other ports on the net LGPIO14: Digital board, 1 Motor (4.70, 5.60)
. Z8 t6 M. F: E4 FERROR [DRC0003] Port has a type which is inconsistent with other ports on the net LGPIO14: Digital board, 1 C10P IO (21.50, 8.30) : c" R" O7 R5 z9 u, ~
Checking for Unconnected Nets
) J K* E7 Y6 H/ l; ~4 VWARNING [DRC0006] Net has fewer than two connections EJTDI: Digital board, 1 C10P IO (2.84, 11.40)
& ~( o3 y; u; t: k1 [7 U0 RWARNING [DRC0006] Net has fewer than two connections EJTDO: Digital board, 1 C10P IO (2.84, 11.30) |
