查看: 4678|回复: 3
请教高手,关于Relative propagation delay中线的长度计算问题
发表于 2012-5-9 15:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
         各位大侠,在给DDR2做Relative propagation delay时,发现Constraint information中除了ETCH LENTH还有一个ZALL,请问ZALL是什么?是Via等的等效长度吗?谢谢……附对DDR2 NET的Show Element:8 r' M+ X1 e& h; f2 P5 y2 h
5 Z4 k  r4 m' Z& D2 U" U- u
LISTING: 1 element(s)4 }, F  i) x$ z. n' z! f  r
* j: E% l6 ]1 T- e/ @  m              < NET >
1 w1 w" W8 v. D& N+ K
% U: ]8 c( m) Z: _4 w) C  Net Name:            MFPGA1_DDRD23
4 [4 t; i2 w* P' `* O  Member of Bus:       MFPGA1_DDR_DATA2
5 ?, n$ @  H2 f* N+ k1 N: B
8 y( r5 t# O) o- r2 J. y: d% G8 q  Pin count:              2  j1 z' c+ j2 {5 G% ^9 J5 l* d
  Via count:              2& s. w( G( U* Y0 q# w, ?
  Total etch length:      1964.069 MIL
; q( j# r) S- z9 o( c' Z+ c  Total manhattan length: 1135.851 MIL
( \9 f3 ^3 l7 p% e7 l+ c% o$ X  Percent manhattan:      172.92%& X$ }! \7 M0 q+ Y$ i3 N' G
- ]2 v( a+ b3 Z* l/ x
  Pin                     Type      SigNoise Model        Location0 a6 o7 E( b! L/ }; D# s6 E9 C
! Z! _* }# l: i: ]  U801.F9                 UNSPEC                          (-1984.000 6603.717)
' ~& `! _# d! h  ^# Z+ K: _. x  U796.C18                UNSPEC                          (-2351.016 5834.882)5 \/ T: N% o$ @1 N) q
. p9 G6 \' U& n2 S. S; v" `& {: A
  No connections remaining# F" v; m" ~2 n8 x" _5 j0 R2 _0 M
  W# Y7 w9 A7 v, G3 v
  Properties attached to net3 H% Q; k6 }' l7 p" J3 L* x
    FIXED
' t# U: v' y& B$ {' H+ b3 y    LOGICAL_PATH      = @dw5vlx_all_20120504_1800.schematic1(sch_1):mf
! f1 t$ N8 p* c4 U: G                        pga1_ddrd23
% f9 s2 U. T* f+ Z    BUS_NAME          = MFPGA1_DDR_DATA2
0 b  @! t/ W' k. C$ \' q1 E7 C. |1 C& C: g8 A
  Electrical Constraints assigned to net4 `2 p0 Q+ l" a% G1 B( z
    relative prop delay: global group MFPGA1DDR_GROUP_DQ from AD to AR  delta=0.000 MIL  tol=10.000 MIL+ t$ Z0 r# j: n8 U( Y  q
7 `& M, p( y' n. s. W
  Constraint information:% k/ [; k) \: U1 y1 t3 P
    (RDly) U796.C18 to U801.F9  min= 1966.14 MIL  max= 1986.14 MIL  actual= 1980.741 MIL8 o4 |/ i& n  M( E
                   target=  (MFPGA1_DDRDQS3P) U796.G20 to U801.B73 ]8 x, u2 I% {- U3 f4 s
            (-2351.016,5834.882) pin U796.C18,UNSPEC,TOP/TOP
4 j5 A! f$ ^9 ]1 S, `$ a, x6 r, ^9 D      24.812 MIL cline TOP
! l7 }- v  a) y2 h            (-2333.471,5852.427) via TOP/BOTTOM. ~- g, d$ P4 _) `/ b$ d0 Y3 R
      1917.397 MIL cline 03IS01
0 h3 i2 r# _! t$ U* B# [2 {            (-1999.457,6588.260) via TOP/BOTTOM& i8 @. l9 R/ T4 D: ?/ g
      21.859 MIL cline TOP6 H5 Q; b( H% |8 q& A( W1 T8 Z) M
            (-1984.000,6603.717) pin U801.F9
,UNSPEC,TOP/TOP,Zall=16.672 MIL) j. X4 B1 J, ^% g$ G
9 @. K% h5 H- H9 G  B# R& f  Member of Groups:
4 {1 w4 Q- r7 E- G6 M0 a& q    MATCH_GROUP     : MFPGA1DDR_GROUP_DQ! c1 i6 |, X, g1 ^" N# T, o0 i
    BUS             : MFPGA1_DDR_DATA27 p& w7 u, {" F+ w+ O8 h
    2023-10-12 15:00
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    发表于 2012-5-9 18:29 | 只看该作者
    Zall指过孔在Z轴的所有延时!!
     楼主| 发表于 2012-5-11 15:16 | 只看该作者
    flyingc381 发表于 2012-5-9 18:29 - ?9 x# W1 g+ l$ C/ @, O
    Zall指过孔在Z轴的所有延时!!
    & @& r. L& X6 ^, {
    也就是说,在做Relative propegation delay时,delay time是包含此Zall的,是吧?delay time= Etch Length time delay + Zall time delay,是吗?
    2023-10-12 15:00
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    发表于 2012-5-11 18:25 | 只看该作者
    Yes
    GMT+8, 2025-10-27 03:14 , Processed in 0.156250 second(s), 24 queries , Gzip On.
