请教一下各位大神,使用CR8000 的EDIF import 导入mentor格式的EDIF格式的文件,报错,输出报错信息如下:
/ n1 j7 ]9 m& x. ^: X3 N- ######################################################################
& Q5 r6 M# I" h, F0 e' R8 |$ N; S6 J - #
' S \( ]/ S7 c0 P# X - # Error Occurred !!!
" a( R: ~5 s; P0 |3 w* F! l/ n - #: n0 u2 D @# G( f; \' D! e; R& J
- # Sat Jul 22 10:43:00 2023
: ? I9 H+ J( w" y/ b0 z; j' ` \ - #" T6 a4 ~8 c+ |6 i$ j- A: u1 [
- ######################################################################8 s) E% b. k# ~# t
- 0 u0 m4 _8 I. c7 s4 v8 W
- <Mess.36818> Specified vender is different from the vender in EDIF file.
# v# `8 @* R* R8 y4 M3 Q - ' E8 C: ` k; C7 M- \# c* R
- <Mess.36756> Line[9]. Error Occurred: Stop in pre-check process.
4 x' X/ J# A3 f* H) @2 d
复制代码 看help文档,是支持 xDX Designer格式的。选择了对应项目还是报错,有啥解决方案吗,尝试修改EDIF文件内的 vender 标识,报其他的错误,有啥解决办法吗?
: k9 E u' D1 t" d: h
I1 |9 ~6 E% L: [$ p6 d2 H- N- n3 Y8 w% ?5 u, Q& R0 F7 v
p& M* O z; a9 T: n9 N
6 S: R( P( R0 J2 f类似于下面的报错。2 m: X& w6 }# p9 z( w
% u/ N4 }3 {: J# I
- ######################################################################- P& L! {+ U5 Y; L
+ [; x2 E1 h7 O/ m- V5 H - # Error Occurred !!! h) ?) h# C# E* m5 @& f
- #1 {% \ a! s1 V6 Q5 s
- # Sat Jul 22 11:23:50 2023
0 u. H1 z( B' ?% k; b& s! F; A - #
4 p7 v# c* _* s3 N& i - ######################################################################& [. N9 V+ Y3 f; Y5 u, L4 Z7 v2 e8 d
& r4 v1 \6 B4 v$ ^. |, @- <Mess.36704> Cell [] not found at [47526] line.Conversion proceeded.
5 ]+ }7 w; U X6 y* [: D - " m7 G" _8 z# h; p4 ~
- <Mess.36704> Cell [] not found at [47793] line.Conversion proceeded.
5 j6 o" y; v: O! F; c0 D3 [
/ g/ P1 b' ?4 D S x- <Mess.36704> Cell [] not found at [48245] line.Conversion proceeded.( A" d! I$ B& @& \
* h3 l$ y4 F! J+ T# `5 u) k+ g- <Mess.36704> Cell [] not found at [48763] line.Conversion proceeded.* `) _2 {- L# A8 B( d
5 m+ P' [9 ^, v0 E: o- <Mess.36704> Cell [] not found at [49030] line.Conversion proceeded.
: |: w: q# ? _& B- C8 e/ g - Q1 ^* t) [" ~
- <Mess.36704> Cell [] not found at [49297] line.Conversion proceeded." | d, @' s4 _! e4 ~* S O
3 q. N" t* I5 Q7 Q7 A8 \% ~9 _0 [- <Mess.36704> Cell [] not found at [49550] line.Conversion proceeded.
* l7 B4 ]8 a. Q) T/ F; W5 S
! D z3 v! ]9 V+ k* s+ R! W- <Mess.36717> Failed to connect net to a pin. Around line [50596] in * j& L; ?6 X. m! n: {! k1 I
- input file.! {# u. {% V S T3 u
- Library =CORPORATE) c- S; O$ D- o! d
- Cell =logic3 g6 f( ]: q2 J0 D2 Z7 |
- View =logic" x3 z9 d4 u) P+ N* Q/ ^
- Page =REUSE1-46 D0 `% Q; P* z8 _
- Net =GND
* _6 [5 b( u8 J- | - ) T6 Y7 Y+ ?( u1 q( f
- <Mess.36717> Failed to connect net to a pin. Around line [50597] in
2 N' G7 t# C1 J9 s) E - input file.
S& {& } ~+ g# b2 } - Library =CORPORATE% G' m* C( G# S. Y9 L1 ]) g7 R+ O
- Cell =logic7 q% t) z) W$ [* W+ L( ^
- View =logic& X) D' ]' V! m2 G: K
- Page =REUSE1-4
2 B0 n* b& y! Q; c- b8 Z0 ?8 r+ M - Net =GND
. F# J8 C4 C- }
! a7 n x3 T: Q! n C3 e- <Mess.36717> Failed to connect net to a pin. Around line [50598] in " {9 S6 e# ~, D% d
- input file.7 w4 T, D- `- k- o
- Library =CORPORATE4 `; _- E4 p3 q5 U/ e* h1 m% R
- Cell =logic1 ~2 S# }0 @ b% @
- View =logic
1 u" P2 `- V8 W - Page =REUSE1-4
! O( P2 d' O7 X& V - Net =GND
) N- ?' b7 ]1 R2 U1 A% l ^ - ' k9 Y& y& o, R: x
- <Mess.36717> Failed to connect net to a pin. Around line [50599] in
# b; K- H& g. k6 M5 x - input file.2 i5 _' v3 v% d. o
- Library =CORPORATE/ ~0 _" K$ T, N, y0 v
- Cell =logic' X2 \% { E8 @; S" I* {4 l8 y# ~
- View =logic. I" o5 A3 V+ x1 {' C5 H7 z: A8 Y
- Page =REUSE1-4
7 m$ a0 M* Z% @1 N; F% T - Net =GND
1 C8 z: P: P" L7 O/ n" }
% s' ?' {. T& W7 [0 ^$ W* Q- <Mess.36717> Failed to connect net to a pin. Around line [50600] in
3 ?! N0 T: W8 ?4 W9 b: P6 N* z - input file.6 r5 P1 W7 `( J0 ?" o
- Library =CORPORATE$ M4 |- E6 Z4 v' F8 E8 {
- Cell =logic( ]% @( g6 [) T) S+ N; n
- View =logic4 s) t2 J: F v3 X7 T
- Page =REUSE1-4
3 \2 Z3 ^6 W5 g - Net =GND& J; O0 [* Y! o& e9 X2 Z2 e
- # p0 b& y/ a1 i% Q8 J" b4 k- P( ~2 {
- <Mess.36717> Failed to connect net to a pin. Around line [50601] in ; k2 `& Q( {7 ^* T6 q
- input file.
7 ^6 _$ W: G' w6 u# Z. y - Library =CORPORATE! V" U9 l5 {# S. b/ l" p+ P- r2 P
- Cell =logic1 a8 N' R$ D. ?/ F f% O$ ]' H
- View =logic- Z4 |1 j* L& |1 [# I; v& t, Z
- Page =REUSE1-4$ ~- S$ |1 R4 @9 y
- Net =GND3 H( X" c$ \( Y+ R C2 V9 _
- . D! F6 x, t5 _
- <Mess.36717> Failed to connect net to a pin. Around line [50617] in
2 \+ _- \6 C o8 W - input file.
2 f% R7 U+ h- \ d- L - Library =CORPORATE4 I0 T1 _2 O2 i5 C
- Cell =logic% h1 e9 T$ U& v; D+ B
- View =logic
9 P4 n4 z1 j! E0 ~1 \; ?/ ?& ] - Page =REUSE1-4" \- G' N- R" S& i$ G5 `; B
- Net =$1N11* N& n1 s5 Z% n" p8 Y7 a
- 8 ?. W+ r4 F, j- W! n6 ?9 p
- <Mess.36717> Failed to connect net to a pin. Around line [50618] in / h. l$ [& C& K3 g+ b
- input file.3 u/ ~- j2 i1 } Q
/ G' T$ V$ x) ?# P0 W - Cell =logic
3 L, P$ R. f5 m+ N9 ^& F p - View =logic
7 |, W1 }+ c4 e! r! j, k5 |0 U+ L - Page =REUSE1-4- d, v; `- N: S# @) v+ p: Z
- Net =$1N11% n8 X5 S. K( e) l4 |( @
- - I H" l1 ^/ m; V( X k3 i
- <Mess.36717> Failed to connect net to a pin. Around line [50619] in 0 @+ I8 |# T: r3 r6 J% L2 `
- input file./ D/ `! v- X3 x
2 i+ g3 G1 `' Z! Y7 P - Cell =logic
* r& w5 ?" V$ F0 e3 k* f/ r: s - View =logic
- s* l u: S, q* c+ D& O9 ] - Page =REUSE1-48 k' @& K$ f8 W+ v' S) D
- Net =$1N11# e' Q$ T2 x/ i* @. P; j+ {
- & h3 \! d+ a- V" Y
- <Mess.36717> Failed to connect net to a pin. Around line [50688] in
0 Q# V. c2 M5 {) L* w! v! ^6 I - input file.) h* k: p) f: d
+ @' I! ^( S) }5 u* A- j7 E - Cell =logic! @" P5 f2 z. ]! t' x* Q
- View =logic
* C0 `6 w( Z1 v% z - Page =REUSE1-4
' H7 a* L1 t; d - Net =$1N27& B, K# g8 j5 P
- - Z Z5 }2 o% o3 V. \
- <Mess.36717> Failed to connect net to a pin. Around line [50689] in ( g! A+ Z( E0 e# G# B6 D
- input file.$ M5 |0 [8 Y" k1 w; y8 h
- Library =CORPORATE8 y+ _6 Y1 q) f) P- O8 L1 c
- Cell =logic5 _" W! z3 m j; M& b& `- P/ z
- View =logic
- Q6 f4 x6 I. N, D+ b% \ - Page =REUSE1-4
- u, l1 F' a& \6 L( E- m; Y - Net =$1N27
7 V9 M6 i5 o3 }3 W
: U: |/ l* u) E& J8 Y# A/ B4 B- <Mess.36717> Failed to connect net to a pin. Around line [50749] in ! m! ?( o' z( _2 }
- input file.
. [* x9 ~" ^. ~9 l L - Library =CORPORATE
& P- S, H3 t/ W - Cell =logic4 `( H( M- x* d0 l0 y
- View =logic% e* }+ B. s9 E& L+ J
- Page =REUSE1-4
5 w3 [3 s3 E5 o$ _. [" H - Net =$1N24
复制代码
# J7 Y' G5 B* L8 i8 x$ L6 z: z/ ]) B' u+ l. k% ^
