楼主: chouqiu
自定义skill快捷功能菜单
    2025-8-8 15:00
  • 签到天数: 91 天
    [LV.6]常住居民II
    16#
     楼主| 发表于 2012-8-29 13:32 | 只看该作者
    longzhiming 发表于 2012-8-29 12:00
    不行就是不行,你们的也是windows7吗?
    XP 的不是wind7的    window7 的 没搞过
    17#
    发表于 2012-8-29 13:46 | 只看该作者
    謝謝分享資訊~
    試看看~~~
    2025-8-8 15:00
  • 签到天数: 91 天
    [LV.6]常住居民II
    18#
     楼主| 发表于 2012-8-29 14:44 | 只看该作者
    我的是 XP 的  window 7的 没有试过
    19#
    发表于 2012-8-30 09:33 | 只看该作者
    有的人写太少了,而楼主写太多了.............,改天我给它精简精简
    奋斗
    2021-5-18 15:19
  • 签到天数: 14 天
    [LV.3]偶尔看看II
    20#
    发表于 2012-8-30 09:38 | 只看该作者
    權限不夠,看不到圖片
    21#
    发表于 2012-11-26 10:31 | 只看该作者
    非常感谢
    22#
    发表于 2012-11-26 10:33 | 只看该作者
    拜求!为什么按楼主的进行操作,我的allegro文件打不开呀?
    23#
    发表于 2012-11-26 10:49 | 只看该作者
    Error* load: can't access file - "build_ver.il"
    E- *Error* load: can't access file - "conv.il"
    E- *Error* load: can't access file - "draw_targets.il"
    E- *Error* load: can't access file - "drc_walk.il"
    E- *Error* load: can't access file - "height_check.il"
    E- *Error* load: can't access file - "hl_ntp.il"
    E- *Error* load: can't access file - "mot_find_stubs.il"
    E- *Error* load: can't access file - "no_drc.il"
    E- *Error* load: can't access file - "pdi_vis.il"
    E- *Error* load: can't access file - "replace_update_via.il"
    E- *Error* load: can't access file - "replace_via.il"
    E- *Error* load: can't access file - "rm_nc_via.il"
    E- *Error* load: can't access file - "shape_push.il"
    E- *Error* load: can't access file - "0MeasureEtchLength.il"
    E- *Error* load: can't access file - "a1.il"
    E- *Error* load: can't access file - "add_symbol.il"
    E- *Error* load: can't access file - "addpinuse.il"
    E- *Error* load: can't access file - "align_sym.il"
    E- *Error* load: can't access file - "assembly.il"
    E- *Error* load: can't access file - "cal_start.il"
    E- *Error* load: can't access file - "cal_start_name.il"
    E- *Error* load: can't access file - "checkdis3.il"
    E- *Error* load: can't access file - "checkMax.il"
    E- *Error* load: can't access file - "checkminimus.il"
    E- *Error* load: can't access file - "checknpth.il"
    E- *Error* load: can't access file - "checkpadsmt.il"
    E- *Error* load: can't access file - "checkWidth.il"
    E- *Error* load: can't access file - "clinecut.il"
    E- *Error* load: can't access file - "cnv_height.il"
    E- *Error* load: can't access file - "cPickSelectVia.klc"
    E- *Error* load: can't access file - "Create_Thermal_Flash.il"
    E- *Error* load: can't access file - "CreateRefCompLine.klc"
    E- *Error* load: can't access file - "cutshape.il"
    E- *Error* load: can't access file - "cwidth.il"
    E- *Error* load: can't access file - "dummy_via.il"
    E- *Error* load: can't access file - "etch_visibility.il"
    E- *Error* load: can't access file - "Find_DRC.il"
    E- *Error* load: can't access file - "flare_conn.il"
    E- *Error* load: can't access file - "foxAllegroCmpCenterRep.lmc"
    E- *Error* load: can't access file - "foxAllegroComponentCentroidReport.il"
    E- *Error* load: can't access file - "foxEtchLayerView2.lmc"
    E- *Error* load: can't access file - "foxLineWidthOnOff.lmc"
    E- *Error* load: can't access file - "foxRepTestPoint.il"
    E- *Error* load: can't access file - "hl_npe.il"
    E- *Error* load: can't access file - "ipc_356.il"
    E- *Error* load: can't access file - "killallxdrc.il"
    E- *Error* load: can't access file - "listratt.il"
    E- *Error* load: can't access file - "op.il"
    E- *Error* load: can't access file - "place_symbols.il"
    E- *Error* load: can't access file - "qfp_pitch.il"
    E- *Error* load: can't access file - "Rename_Ref_Des.il"
    E- *Error* load: can't access file - "rep_ucshape.il"
    E- *Error* load: can't access file - "ruler.il"
    E- *Error* load: can't access file - "save_shape_drc.il"
    E- *Error* load: can't access file - "show_height.il"
    E- *Error* load: can't access file - "show_library.il"
    E- *Error* load: can't access file - "solder_paste.il"
    E- *Error* load: can't access file - "Symbol_Check.il"
    E- *Error* load: can't access file - "testpad.il"
    E- *Error* load: can't access file - "testpaddis.il"
    E- *Error* load: can't access file - "viasolder.il"
    E- *Error* load: can't access file - "xmoat.il"
    E- *Error* load: can't access file - "C:\\Cadence\\SPB_16.3\\pcbenv\\DstCxi.il"
    Starting new drawing...
    为什么不能打开skill文件?
    2025-8-8 15:00
  • 签到天数: 91 天
    [LV.6]常住居民II
    24#
     楼主| 发表于 2012-11-26 15:08 | 只看该作者
    E-  ...
    找不到 skill  路径  你应该是 没有添加到这里
    这个格式的标注allegro.ilinit 不对  里面要把 skill 的名称 填进去 还要设置 skill 放置路径
    setSkillPath(buildString(append1(getSkillPath() "D:/sutenv/skill")))
    load("x_mc_ro_text.il" "www.eda365.com")
    load("x_split_shape.il" "deargds")
    load("x_dump_lib.il" "deargds")
    load("x_silk_in_out.il" "deargds")
    25#
    发表于 2012-11-26 17:29 | 只看该作者
    这个格式的标注allegro.ilinit 不对  里面要把 skill 的 ...
    谢谢,我就是这样写的,还是不行
    26#
    发表于 2013-6-8 13:56 | 只看该作者
    求教学习Skill技巧
    2025-8-8 15:00
  • 签到天数: 91 天
    [LV.6]常住居民II
    27#
     楼主| 发表于 2013-6-13 10:20 | 只看该作者
    tllok 发表于 2012-11-26 17:29
    谢谢,我就是这样写的,还是不行
    里面的标点符号 空格都不也能少  这句你可以复制我的 setSkillPath(buildString(append1(getSkillPath() "D:/sutenv/skill")))
    后面的   最后面的 一个括号是  路径根据自己 点更改
    28#
    发表于 2013-6-17 14:56 | 只看该作者
    非常感谢
    29#
    发表于 2013-6-24 21:06 | 只看该作者
    学习
    30#
    发表于 2014-10-23 23:52 | 只看该作者
    好东西大家要分享
    GMT+8, 2025-8-20 07:52 , Processed in 0.109375 second(s), 20 queries , Gzip On.
