楼主: maoyide
PADS9.4.1全自动破解文件(用于安装版)
16#
发表于 2012-5-24 20:49 | 只看该作者
是不是真滴可以啊?
  T' {: Y9 g2 |2 |3 f# ~
17#
发表于 2012-5-29 08:42 | 只看该作者
win7可以吗
18#
发表于 2012-5-29 09:09 | 只看该作者
谢谢,证明可以使用,非常感谢
19#
发表于 2012-6-1 15:48 | 只看该作者
怎么提示有木马呢,一下子就给我删了
20#
发表于 2012-6-8 22:15 | 只看该作者
和谐了,但不成功,提示如下:e following FLEXlm errors were found:
7 G. f2 w( t8 e* }- F% A    Server c:\flexlm\License.dat: Invalid (inconsistent) license key.
  {, [0 ~; F, Y3 P7 W- }* }1 B  s The license key and data for the feature do not match.7 R6 g. C$ i! ?/ q
This usually happens when a license file has been altered.( N5 p" v& V$ l9 j% e$ y' ?
Feature:       mgc_s. K# c9 R$ e, q  i* t/ i
License path:  c:\flexlm\License.dat;, |. I( U1 f2 x" q
FLEXnet Licensing error:-8,523: B, R9 g/ {2 H# S- ?1 R% u; r& j7 h
For further information, refer to the FLEXnet Licensing documentation,. J, Q" r: N0 F
available at "www.acresso.com".2 C! ?. b1 c" Q8 Z, K( R/ ?% }
( H" C; R/ U0 c1 _3 L! }  Y- Y6 D    Server c:\flexlm\License.dat: Invalid (inconsistent) license key.
7 N( g* d, U$ ?4 A6 k2 |8 t' y The license key and data for the feature do not match.; _" D6 n' u- H4 l; i
This usually happens when a license file has been altered.8 {6 v: D/ ]  X% j* L7 v* F
Feature:       mentorall_s" K& a% \2 a7 ~, J* Q: U# _, i
License path:  c:\flexlm\License.dat;+ _3 a8 F+ |$ L6 g1 d$ |! L
FLEXnet Licensing error:-8,5236 k. W# ~% ]6 D3 `- r+ h
For further information, refer to the FLEXnet Licensing documentation,! `7 H1 `9 @; ~& U
0 ~, b2 S  O1 M' P; c3 K7 m7 K% t7 d7 X5 R! W
- k4 Z8 b6 g$ [2 |/ t% y The license key and data for the feature do not match.4 A- k5 _+ T: `' E
This usually happens when a license file has been altered.# C/ ^/ h. @$ m; k
Feature:       bsdall_c
& L( `. f& b7 W. C; I, `License path:  c:\flexlm\License.dat;+ ]) y3 `* W. ~! o1 j
FLEXnet Licensing error:-8,523' {! e' g" O3 s$ D# E! S
For further information, refer to the FLEXnet Licensing documentation,  s" y/ c. Y( ?: K- T" k1 D: U7 M
available at "www.acresso.com".. O4 g8 `+ U& Z5 x+ |) C
3 T2 W" S8 K: Z9 V
    Server c:\flexlm\License.dat: Invalid (inconsistent) license key.0 M9 S; |+ e( a4 N2 a
/ Z4 [0 l9 f" o1 P: o* n$ m" C This usually happens when a license file has been altered.
( a$ w" e; K3 c  F( h3 ^Feature:       padspe_c
- t! H; b' ]" \# ZLicense path:  c:\flexlm\License.dat;
9 k) k0 {5 ]' |& E4 [' {4 j! tFLEXnet Licensing error:-8,523$ _/ I- E& N$ _! }$ y5 P# ]3 _0 l
For further information, refer to the FLEXnet Licensing documentation,4 C$ N* r3 K! U
available at "www.acresso.com".: n! h# U! l; p; Z
( M; J+ h7 @7 E+ Q( e/ S    Server c:\flexlm\License.dat: Invalid (inconsistent) license key.
3 N7 g9 H8 B( @3 \8 ]9 T( } The license key and data for the feature do not match.8 f( ~. m5 ~0 c. _% c/ j
This usually happens when a license file has been altered.2 S! Z5 p* e7 k& C  }: m% _; P
Feature:       padsxe_c, {2 D+ y# H) J. O( C' I# l' J
License path:  c:\flexlm\License.dat;, p; \1 F$ V0 M: m2 Q2 [
FLEXnet Licensing error:-8,5237 x( s$ ]1 B2 K$ u8 y
For further information, refer to the FLEXnet Licensing documentation,9 S/ e3 y3 X7 `3 u, [
available at "www.acresso.com".( J  A( t5 u2 G; ]% ?
4 s# N: y2 q2 V0 P
    Server c:\flexlm\License.dat: Invalid (inconsistent) license key.) {  ?6 X1 c/ }  ~6 Y9 z8 u. R
The license key and data for the feature do not match.. v- r1 m" S* \" h5 V
; z, [% N' t" |: E! k4 ~Feature:       padsse_c
: s, Y  Y! I- z2 Q8 G9 xLicense path:  c:\flexlm\License.dat;9 F1 _5 M. c3 E! A- G6 M
, T' w# O7 `1 U) b& {  JFor further information, refer to the FLEXnet Licensing documentation,
& H- [$ N. a1 z; m% M8 Eavailable at "www.acresso.com".
* n, Q, i0 `* r6 D+ n
2 i: `' }$ |/ E1 D8 X    Server c:\flexlm\License.dat: Invalid (inconsistent) license key.* F- o2 u, j; T0 E* @
The license key and data for the feature do not match.5 H" e4 n$ q8 C# C! Q6 \0 y
This usually happens when a license file has been altered.. i6 |7 n/ r$ z- v6 y
Feature:       padsped_c
/ r5 C! B( V4 b. l  n0 N5 I3 ULicense path:  c:\flexlm\License.dat;' q, A& O& [8 u, {" `: P( ?+ }
. w* _0 Z5 e! {) d: ?* z0 H- w7 x4 h' JFor further information, refer to the FLEXnet Licensing documentation,
2 j) R% o) Y" p5 z' @: qavailable at "www.acresso.com".# E, @0 G4 Y; ?: ~5 S5 b3 @1 r! D
) C) u5 @; ^, b, R* m
2 v7 r9 g" U( m The license key and data for the feature do not match.2 B* t4 g! M* v5 o& ?# o, r+ L
This usually happens when a license file has been altered.; z- \6 [* A% H
Feature:       padsxed_c, ^/ f4 S7 _( Z5 r7 c" v
License path:  c:\flexlm\License.dat;  q. b( j* A' Z. a9 G
0 Q0 e. {2 A4 [+ k( I; X" V. BFor further information, refer to the FLEXnet Licensing documentation,
8 \1 q) H; j3 j9 ~" o" favailable at "www.acresso.com".! F& s1 D3 a$ p% f0 `/ o
) p: ]& X0 s( Q    Server c:\flexlm\License.dat: Invalid (inconsistent) license key.2 r5 R4 t" U8 @- `: c  v$ u/ ~
$ [4 k* W) j/ b% q! Z This usually happens when a license file has been altered.3 w9 B( _1 ], S
Feature:       padssed_c
5 a& O- ~7 J" \9 t8 FLicense path:  c:\flexlm\License.dat;
* j7 Z- p! T) H: ^FLEXnet Licensing error:-8,523
& G1 m2 N& q0 T3 FFor further information, refer to the FLEXnet Licensing documentation,. g& n8 Y4 L, X! Z  l6 N  r
available at "www.acresso.com".$ c8 x0 [' A3 v* ~! }9 B: }3 P
7 Y: ^0 J( g) g6 l    Server c:\flexlm\License.dat: Invalid (inconsistent) license key.5 G6 C9 J4 Q& S& k
' x" C+ V$ P  n1 G This usually happens when a license file has been altered.
5 s! }( ^* f5 D1 ^Feature:       padsxedars_c% _4 K4 |: H% U+ ]  c
$ ~$ Z0 ^$ V. w& zFLEXnet Licensing error:-8,523
5 c3 \8 ]0 x* k9 SFor further information, refer to the FLEXnet Licensing documentation,
: I3 Y5 X: `" ?( Y" N- C+ E: [% davailable at "www.acresso.com".
- ~* K2 h; `) l, F
2 N8 Y7 Y. ], m7 Z* a6 t3 h: m/ y( U    Server c:\flexlm\License.dat: Invalid (inconsistent) license key.# d6 L% F0 _) a- L# U% I- h
4 w0 _) R/ i9 [* Y( y. i* {% \& L This usually happens when a license file has been altered.
3 R. q& x% Q- _0 b1 bFeature:       padspel_c
, `% ^7 g* d$ XLicense path:  c:\flexlm\License.dat;
* d, Y" M# Y6 y' n, iFLEXnet Licensing error:-8,523
% ~; s& |* Q, C9 Q( s' c( M4 p( lFor further information, refer to the FLEXnet Licensing documentation,' p8 f+ S$ {3 ?
available at "www.acresso.com".6 v. I3 c- n; S% I  v* H
$ i/ F' }3 Z( c
; J. Z5 n2 a) C3 m% f- y The license key and data for the feature do not match.5 h2 N. d8 }2 X; `) R6 p, w
This usually happens when a license file has been altered.& R6 C: @: h8 E& j0 d' {! @
Feature:       padsxelars_c
' v* i9 c  a) M+ tLicense path:  c:\flexlm\License.dat;
# F3 I0 l& G  kFLEXnet Licensing error:-8,523
/ _) D( V. z! YFor further information, refer to the FLEXnet Licensing documentation,+ n) |: F8 L, @& ?4 k  z' x
21#
发表于 2012-6-10 18:53 | 只看该作者
很好,很强大。
22#
发表于 2012-6-19 16:49 | 只看该作者
谢谢分享!!!
23#
发表于 2012-7-3 16:26 | 只看该作者
貌似 不成功 ,不知道什么原因
24#
发表于 2012-7-3 18:12 | 只看该作者
谢谢!
25#
发表于 2012-7-4 15:07 | 只看该作者
好好,我来支持楼主!
26#
发表于 2012-7-24 20:06 | 只看该作者
这么好,我下载来试试,谢谢分享
27#
发表于 2012-7-31 23:49 | 只看该作者
我的怎么和谐不了啊,我是安装在D盘的,是这个原因吗?请高人指点
28#
发表于 2012-8-10 09:05 | 只看该作者
谢谢分享
29#
发表于 2012-8-10 10:50 | 只看该作者
谢谢
30#
发表于 2012-9-14 11:47 | 只看该作者
牛人,谢谢!
GMT+8, 2025-11-5 18:24 , Processed in 0.125000 second(s), 20 queries , Gzip On.
