查看: 998|回复: 0
Summer Fashion Dress visual remarkable thin variable S-shaped
发表于 2012-4-9 15:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
believe a lot of mm are pear-shaped body ,christian louboutin sneakers mens, and confusion on how to match in order to make themselves look more fresh and slim . pear-shaped figure, the name suggests is the upper body is relatively slender lower body slightly obese ,christian louboutin suede sandals, especially in the thighs and buttocks,christian louboutin flat, the appropriate mix allows you to avoid weaknesses . here is xiao bian collected pear-shaped figure how to dress with the summer season even
, u9 f8 P! ]4 z+ Z classic shanghai stripes stitching the skirt of the same color , rich woman demeanor , it also contains a playful nature . the upper body is super good , waist bow strap , the more apparent the peRFect waist , classic unbeaten was thin models .
GMT+8, 2025-8-20 10:38 , Processed in 0.109375 second(s), 25 queries , Gzip On.
