- }/ N' i" j1 t# F1 w5 O
The QCN9024 is the latest addition to the Qualcomm Networking Pro Series platform for Wi-Fi 6E access points. Designed to support high-peRFormance, low-latency wireless connectivity in dense environments, the QCN9024 is the perfect solution for offices, stadiums, and public venues that demand reliable, fast Wi-Fi connectivity. One of the most impressive features of the QCN9024 is its 4x4 MIMO and 160 MHz channel support, which allows for up to 5.9 Gbps peak theoretical throughput. This means that even with multiple users and devices connected to the network, you can expect lightning-fast speeds and reliable connectivity. But that's not all - the QCN9024 also supports advanced features such as MU-MIMO, OFDMA, and 1024 QAM modulation. These features work together to improve network efficiency and performance, resulting in a more stable, reliable network that can handle even the most demanding workloads. The QCN9024 also supports Qualcomm's Wi-Fi SON (Self-Organizing Network) technology. This advanced feature optimizes network performance and allows you to manage multiple access points from a centralized controller. This means that you can easily manage your network, even in large, complex environments. In addition, the QCN9024 offers enhanced security features to protect your network and your data. It supports WPA3, the latest Wi-Fi security protocol, which offers enhanced protection against brute-force attacks and other types of cyber threats. It also supports 802.1X authentication, which allows you to control access to your network and keep unauthorized users out. The QCN9024 is also designed with reliability in mind. It supports dual-band redundancy, which means that even if one band goes down, the other band will continue to provide connectivity. It also supports dynamic channel selection, which ensures that the access point is always using the best possible channel to provide the fastest and most reliable connectivity. In conclusion, the QCN9024 is a powerful, feature-packed Wi-Fi 6E access point that is ideal for dense environments that demand high-performance, low-latency wireless connectivity. With its impressive specs, advanced features, and enhanced security, it's the perfect choice for businesses and organizations that need a reliable, high-performance network. Are you looking for a reliable and experienced partner to help you develop and produce wireless communication products? Look no further than Wallys Communications. At Wallys, we specialize in the research and development, production, and OEM/ODM/JDM services of wireless communication products. Our team of skilled engineers has a proven track record in areas such as RF and embedded communications, network protocol, firmware, PCB design, and more. We use advanced equipment to ensure that our products are not only of the highest quality, but also meet the specific needs of our customers. Whether you're in need of custom-designed wireless communication products, or looking to optimize existing ones, Wallys Communications has the expertise to help. Contact us today to learn more about our services and how we can help you achieve your wireless communication goals. MAIL:sales3@wallystech.com WEB:https://www.wallystech.com/ 2 @2 t# ` q! x/ R
