查看: 203|回复: 0
Wallys|DR7915 based on MT7915 + MT7975 Chipset|IEEE 802.11ac / ax |802.11ax/a...
发表于 2023-3-13 13:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Wallys|DR7915 based on MT7915 + MT7975 Chipset|IEEE 802.11ac / ax compliant & backward compatible with 802.11ax/ac/a/b/g/n
DR 7915 based on MT7915 + MT7975 Chipset is an enterprise wireless module integrated with 2x2 2.4G high power Radio module and 2x2 5G high power Radio module designed
specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment infactories, warehousese stablishment.
the MT7915+MT7975 chipset is a combination of two MediaTek chips.
The MT7915 is a Wi-Fi 6 (802.11ax) chip that is designed to provide high-speed wireless connectivity to devices. It supports multiple-input and multiple-output (MIMO) technology, which allows for faster data transfer rates, and it also features advanced security protocols to ensure secure wireless connections.
The MT7975, on the other hand, is a 5G modem chip that supports sub-6GHz and mmWave frequency bands. It is designed to provide high-speed 5G connectivity to devices, enabling faster download and upload speeds, low latency, and improved network reliability.
By combining these two chips, device manufacturers can create devices that offer both Wi-Fi 6 and 5G connectivity, which can provide a seamless wireless experience across multiple networks.
Are you in the market for a high-performance, reliable wireless networking solution? Look no further than our latest product, which supports IEEE 802.11ac / ax compliant and is backward compatible with 802.11ax/ac/a/b/g/n.
With this product, you can enjoy lightning-fast wireless connectivity that supports the latest networking standards, as well as older legacy devices. Whether you're streaming HD video, downloading large files, or just browsing the web, this product will provide you with a seamless wireless experience.
One of the standout features of our product is its support for IEEE 802.11ax, the latest wireless networking standard. This standard offers a host of benefits, including faster data transfer speeds, improved network efficiency, and better performance in high-density environments. And because our product is backward compatible with older standards, you won't have to worry about compatibility issues with older devices.
Installation and setup are a breeze with our product, thanks to its intuitive web-based interface and simple configuration options. And with robust security features like WPA3 encryption and a built-in firewall, you can rest assured that your network is protected from unauthorized access.
But that's not all - our product also includes advanced features like Quality of Service (QoS) and Beamforming technology, which ensures that your network is optimized for your specific needs. And with support for multiple SSIDs and VLANs, you can create separate networks for different purposes and users.
In short, if you're looking for a high-performance wireless networking solution that supports the latest standards and is backward compatible with older devices, look no further than our product. With its powerful features and ease of use, it's the perfect choice for businesses, homes, and anyone who demands reliable wireless connectivity.
Feature——
MT7915+MT7975 Chipset
2.4GHz max 23dBm & 5GHz max 20dBm output power
2×2 2.4G & 2×2 5G  MIMO Technology, up to 1.8Gbps Mini PCI Express edge connector
SupporttheFrequency2412MHz~2482MHz
SupporttheFrequency5180MHz~5825MHz
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing,Cyclic-Delay Diversity (CDD), Low-Density Parity Check  (LDPC) Codes,Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Supports Dynamic Frequency Selection (DFS)
CardsareindividuallycalibratedforQualityAssurance
Symbol
Parameter
Chipset
MT7915+MT7975
Host Interface
Mini PCI Express 2.1
Antenna Connector
2 x UF.L
Frequency Range
2.4GHz: 2.412GHz to 2.472GHz) [/ y- ?* [4 r/ h  R& M2 W
5GHz: 5.180GHz to 5.825GHz
Operating Voltage
3.3V DC
Power Consumption
TBD
Modulation Techniques
OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM
Environmental Temperature
Operating: -40°C to 70°C, Storage: -40°C to 90°C
Environmental Humidity, non-condensing
Operating: 5% to 95%, Storage: Max. 90%
ROHS Compliance
YES
Dimensions (W×H×D)
51mm × 30mm × 5.8mm
Wireless networking is essential for businesses and organizations to stay connected and communicate effectively in today's fast-paced world. Wallys Communications (SuZhou) Co., Ltd is a techno-innovation enterprise that specializes in wireless network products and solutions. With over a decade of experience, the company has established itself as a leading provider of wireless solutions that cater to various industries.
At Wallys Communications, the team of experts is dedicated to providing high-quality and innovative wireless network products that meet the needs of their clients. Their professional knowledge and top research and development team allow them to break through technological barriers and offer cutting-edge products that are both reliable and efficient.
Wallys Communications offers customized services, from design and testing to certification and production, to ensure that their clients receive the best possible solutions for their wireless networking needs. The company's wireless bridges, wireless APs, and frequency conversion equipment are used in various industries such as security, transportation, ports, oil fields, mines, logistics, electric power, tourism, forest fire prevention, and safe cities. Their products have received consistent high praise from customers, and the company has a good reputation in the industry.
In addition to their wireless products, Wallys Communications also offers comprehensive wireless solutions that include hardware, software, RF, antenna, enclosure, and more. Their solutions are tailored to meet the specific needs of their clients and are designed to provide maximum value for their investment.
Overall, Wallys Communications (SuZhou) Co., Ltd is a reliable and innovative provider of wireless networking products and solutions. Their commitment to quality, innovation, and customer satisfaction makes them a top choice for businesses and organizations looking for reliable and efficient wireless solutions.
MAIL:sales3@wallystech.com
WEB:https://www.wallystech.com/
" T, V9 k% I+ J* F" a# W# x9 N
GMT+8, 2025-7-3 11:16 , Processed in 0.078125 second(s), 24 queries , Gzip On.
