查看: 4583|回复: 3
求助!急!!!关于DRC报错问题
发表于 2008-7-3 17:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教各位高手,我在原理图进行DRC检查时出现如下错误:9 }" x' }- D6 f) q& [$ ^9 w
ERROR [DRC0003]   Port has a type which is inconsistent with other ports on the net DM_ADDR[0..23]:  SCHEMATIC1, 01_FIC8120  (18.88, 0.80) 3 Q* m' S' k7 O( ?
ERROR [DRC0003]   Port has a type which is inconsistent with other ports on the net DM_ADDR[0..23]:  SCHEMATIC1, 01_FIC8120  (18.88, 0.80) ) `6 N7 W  }# B
ERROR [DRC0003]   Port has a type which is inconsistent with other ports on the net DM_ADDR[0..23]:  SCHEMATIC1, 01_FIC8120  (18.88, 0.80) ) ?5 n# ]$ a6 n- c3 A( Q; x2 k7 N( C$ z$ O1 h
ERROR [DRC0003]   Port has a type which is inconsistent with other ports on the net DM_ADDR[0..23]:  SCHEMATIC1, 01_FIC8120  (18.88, 0.80) ; W; H6 B& r, Y1 ]0 L6 K+ g6 M
ERROR [DRC0003]   Port has a type which is inconsistent with other ports on the net MAC_MDC:  SCHEMATIC1, 03_Mac_Phy  (2.98, 4.45) 4 W$ q8 w4 B. x" D! _
ERROR [DRC0003]   Port has a type which is inconsistent with other ports on the net MAC_RXD[0..3]:  SCHEMATIC1, 03_Mac_Phy  (2.98, 2.35)
/ v$ N$ A& v/ B+ v( bERROR [DRC0004]   Possible pin type conflict U7,RXD1 Output Connected to Input Port:  SCHEMATIC1, 03_Mac_Phy  (6.48, 3.75)
$ q! y6 Y- s4 N" Z7 _! O/ _1 G3 rERROR [DRC0003]   Port has a type which is inconsistent with other ports on the net MAC_COL:  SCHEMATIC1, 03_Mac_Phy  (2.98, 3.55)
3 O$ C) C4 t+ ?) {& B6 D) k* D! B( mERROR [DRC0004]   Possible pin type conflict U7,COL Output Connected to Input Port:  SCHEMATIC1, 03_Mac_Phy  (6.48, 4.15)
1 A3 u; H+ G3 }1 k. [ERROR [DRC0003]   Port has a type which is inconsistent with other ports on the net MAC_RX_DV:  SCHEMATIC1, 03_Mac_Phy  (2.98, 2.95)
" A9 h1 w( _) C& @7 J/ \& J2 ]$ TERROR [DRC0004]   Possible pin type conflict U7,RX_DV Output Connected to Input Port:  SCHEMATIC1, 03_Mac_Phy  (6.48, 3.55) 8 u& p. k& Z+ `
ERROR [DRC0003]   Port has a type which is inconsistent with other ports on the net MAC_RX_ER:  SCHEMATIC1, 03_Mac_Phy  (2.98, 3.15)
, w. K5 t, {0 m* Y5 G* J( OERROR [DRC0004]   Possible pin type conflict U7,RX_ER/FIBMOD Output Connected to Input Port:  SCHEMATIC1, 03_Mac_Phy  (6.48, 4.35) : ], P" T& ^" c4 k
ERROR [DRC0003]   Port has a type which is inconsistent with other ports on the net MAC_RXD[0..3]:  SCHEMATIC1, 03_Mac_Phy  (2.98, 2.35) # t6 H9 c( U# D6 T2 _9 x
3 j/ @% X7 j3 r# {3 N* h% @! p
这些错误要怎么改?不知道是不是平坦式时端口连接有问题啊!急啊!
发表于 2008-7-4 09:00 | 只看该作者
原帖由 kris_2008 于 2008-7-3 17:09 发表 9 Y) ^, n/ N( J0 I2 u
, P$ v( p: y+ [- B! cERROR [DRC0003]   Port has a type which is inconsistent with other ports on the net DM_ADDR[0..23]:  SCHEMATIC1, 01_FIC8120  (18.88, 0.80)
2 S- ?3 o0 _* E% p# K8 VERROR [D ...
% y: l" _8 s0 B# `  J
如果是平坦式原理图的话 都改成offpage connector看看
发表于 2008-7-4 10:07 | 只看该作者
原帖由 kris_2008 于 2008-7-3 17:09 发表 & c( Q4 Y0 ^) E  n
请教各位高手,我在原理图进行DRC检查时出现如下错误:% ?. p/ k1 @; q! K; M6 y% S6 G! K2 ~
4 S! B- i7 d- pERROR [D ...
) h1 x" N5 ~6 lI think it's related to 'Port Type'.' {7 d+ B: v) z  N/ o* \# B
Try it pls. ' [" C1 Y$ B, E0 u8 l6 }6 p
发表于 2009-1-19 17:18 | 只看该作者
3# datao1225
GMT+8, 2025-8-23 23:44 , Processed in 0.125000 second(s), 28 queries , Gzip On.
