TA的每日心情 | 开心 2023-2-7 15:43 |
签到天数: 1 天 [LV.1]初来乍到
Difference Dual Band 802.11ac Wave2 IPQ4019/IPQ4029 and industrial application7 n8 X/ e0 [( l: C3 ^; M+ l
Both IPQ4019 and IPQ4029 are Qualcomm network processors designed for smart homes, small and medium-sized enterprise networking, and industrial applications. Their main differences are as follows:' d6 M( r% `* v6 q( s8 S
Processor peRFormance: IPQ4029 provides higher data throughput and faster processing speed than IPQ4019.
9 Q3 m' }, n6 K" ?" dWireless network support: IPQ4029 supports the latest Wi-Fi 6E standard (802.11ax), while IPQ4019 supports only Wi-Fi 5 (802.11ac).
/ G3 }) K. k1 |Network interface: IPQ4029 supports multiple 1/2.5/5/10GbE interfaces, while IPQ4019 supports only one 1GbE interface.
0 H5 h: o2 R. tMemory and storage: The IPQ4029 has higher memory and storage capacity, supporting larger application scenarios.
8 E8 F0 s6 I# j, t O" tCost: The IPQ4029 is a higher-end processor than the IPQ4019, so it costs more.
! z! A& y$ g/ KOverall, IPQ4029 provides better performance, supports higher wireless network standards, provides more network interfaces, and provides more memory and storage capacity than IPQ4019, but also costs more. Select a processor based on actual application scenarios and requirements.
0 \7 t+ Q9 n* o* V2 J/ D( t3 O1 _IPQ4019:
9 H5 z' l: i* @, sIndustrial routers and switches: IPQ4019 can be used in industrial routers and switches to provide reliable data transmission and network connectivity.
+ f: R% H4 M/ L/ e" F$ R3 kIndustrial Automation: IPQ4019 can be used in industrial automation control systems to provide fast data processing and response capabilities.
/ E) i' A% L" g+ Y tInternet of Things (IoT) applications: IPQ4019 can be used in iot applications such as smart homes, smart cities and smart buildings to provide reliable network connectivity and data processing capabilities.
' p6 q2 l+ Y4 NIPQ4029:
6 n3 F$ f3 s3 f% q# h8 jIndustrial control systems: IPQ4029 can be used in industrial control systems, providing powerful data processing capabilities and high-speed network connections.& V3 J) e2 E- E$ F
Industrial routers and switches: IPQ4029 can be used in industrial routers and switches to provide high-speed, stable network connectivity and data transmission.- L* a/ p* t: F/ w% E6 t% i0 M) o T/ U1 n I
Video surveillance system: IPQ4029 can be used in video surveillance system, providing high-speed, stable video streaming transmission and data processing capabilities.; w6 }: |/ Y5 p
In short, both IPQ4019 and IPQ4029 can be applied to industrial applications such as industrial control systems, industrial routers and switches, and smart homes. However, IPQ4029 is more powerful in terms of performance, and can support higher network connection speed and faster data processing speed. Therefore, it is suitable for industrial application scenarios that require higher processing power.
; B: `2 b; k! X$ j1 b9 f& C# x+ UWallys wifi5 router based on Qualcomm's IPQ4029/IPQ4019 chip is trusted by many customers and is one of the best-selling products.5 V+ G3 S# ?" H; }/ F
Featuring with industrial-grade IPQ4019/IPQ4029 chipset* l, y. A% ]! m, a' P0 h! m! O
Integrated with 2x2 5G high power Radio module and 2x2 2.4G high power Radio module' ~) x d3 G, B
Support 4.940GHz to 5.825GHz Frequency Range
% j' h' ?4 Z0 gSupport 2.400GHz to 2.482GHz1 L0 K& v+ |6 q& q
Support 2x 5G MMCX Connectors and 2x2.4G MMCX
8 Q4 k/ K4 y# ]" pSupport 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
, M/ N. C5 k" V/ U1 ESupport 11ABGN/AC
1 r& w1 E2 ]7 _# t; N% u. Q% WSupport fixed data rate
1 ?( W7 Z0 |% s3 R8 yOur Firmware supports all the modules of Quectel
- @% G2 e$ V. \ wFor more information please contact: sales@wallystech.com
7 m3 b. {8 @# {( z8 _% m) ?2 hOr visit walllys' website:http://wallystech.com
4 } k1 {1 {7 VWallys has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.
0 A- |# U- u' A0 ^% G, o+ G
- V) K8 x6 Z6 I3 x( L m8 I9 _7 [! I1 E
/ l/ T4 f9 k$ ]) ~% \
" T3 ^! j! I" a$ w- I! X0 B. X9 s. t# u8 [3 o
