Wallys||Single WIFI Router /IPQ5018 2.4G radio,up to 573Mbps QCN9074/QCN9024 M.2 card Industrial routers have been widely used in the M2M industry of the Internet of Things industry chain, such as smart power grid, intelligent transportation, smart home, finance, mobile POS terminals, supply chain automation, industrial automation, intelligent buildings, fire protection, public safety, environmental protection, meteorology, digital medical, remote sensing, space exploration, agriculture, forestry, water, coal mining, petrochemical and other fields. 1 f& i' F% m) F) C& e3 v
An industrial router is a durable device designed to connect two or more networks and transmit signals to the desired ports. The standard Ethernet and industrial Ethernet protocol, wireless and wired inteRFace or Ethernet and fieldbus communication protocol can be converted and forwarded.
- C, `+ l. Q2 a& Z% WIndustrial routers connect to the public Internet through 4G/5G modules, support multi-carrier networks, and connect to more industrial devices through Wi-Fi 5, Wi-Fi 6, and standard Ethernet. Typical application scenarios are as follows: Applications ■ Security Surveillance ■ Commercial radio coverage ■ Hotel Wireless application ■ Forest fire protection engineering ■ Country coverage ■ Some special scene application Wally is a professional R & D, production and design of industrial router ODM/OEM. DR5018 is a router mainly promoted by wallys. It uses a Qualcomm IPQ5018 chip. At the same time, wallys M.2 moudle is supported, which can better meet the needs of customers. Dual-core ARM 64bit A53@1.0GHz Processor 512MB DDRL3L System Memory 4MB NOR Flash, 128MB NAND Flash 2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate Support BT5.1 M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ; M.2 Card Slot for QCN9074 WIFI 6E Card https://www.wallystech.com/Routerboard/DR5018-wifi6-Qualcomm-IPQ5018-2T2R-2.5G-ETH-port-802.11AX-MU-MIMO-OFDMA-supporting-QCN9074-wifi-card.html The IPQ5018 supports Wi-Fi 6, which greatly improves the performance compared with W-iFi 5 and Wi-Fi 4 https://www.wallystech.com/Network_Card.html In terms of frequency bands, Wi-Fi 5 only covers 5GHz, while Wi-Fi 6 covers 2.4/5GHz, covering both low and high speed devices. In terms of modulation mode, Wi-Fi 6 supports 1024-QAM, which is higher than Wi-Fi 5's 256-QAM, and has a higher data capacity, which means higher data transmission speed. In addition, Wi-Fi 6 incorporates a new OFDMA technology that enables simultaneous transmission from multiple terminals, improving efficiency and reducing latency. 5 s1 r4 q9 y( ?) ~0 |
Wi-Fi 6 not only improves upload and download rates, it also dramatically improves network congestion, allowing more devices to connect to wireless networks and have a consistent high-speed connection experience, thanks to new MU-MIMO and OFDMA technologies that support both uplink and downlink. 2 n. W' H( F! {4 \8 G, l$ r& f
With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective router boards , wireless network cards,antenna ,enclosure and etc., Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win-win cooperation. Skype/EMAIL/Teams: sales@wallystech.com WEB:https://www.wallystech.com/ " D; G6 b6 P8 q Q1 k! r
9 V0 l" m$ I+ l* p: ]
: l/ I3 D9 K5 F( d# \% |
