查看: 143|回复: 0
Wallys\\wifi6 routerboard/IPQ6010 openwrt QSDK QCN9074/QCN9024 M.2 moudles
    2023-2-7 15:43
    发表于 2023-2-8 16:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    QCN9074 WiFi 6E Card OpenWRT, IPQ6010,802.11ax,
    2x2 2.4G&5G 2.5Gbps Ethernet Port Support OpenWRT SupportUECTEL RM500Q-GL&Support:
    Qualcomm-Atheros IPQ6010
    Quad-core ARM 64bit A53 @1.8GHz Processor
    1GB DDRL3L System Memory
    32MB NOR Flash, 256MB NAND Flash
    Supports Dynamic Frequency Selection (DFS)
    2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
    2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
    Support: QUECTEL RM500Q-GL
    Support: QCN9074 WiFi 6E Card
    % Q) Y  m% H4 R) P6 h7 @. x
      $ M! |$ X. D- e) l  t) `& C
      ' d' A$ E$ m' @9 b" j
      1 H$ \6 \8 @8 c# T1 n* B
      Absolute Maximum Rating
      ' p6 Y' {. b$ n/ N0 K0 c' P+ Y! B5 f7 t3 n- @% J% Y8 _# d; s! X& I4 d8 e
      Parameter
      Rating
      Unit
      Supply Voltage
      24V~48
      V
      Operating Temperature Range
      -40 to +70
      oC
      Storage Temperature Range
      -45 to +105
      oC
      Operating Humidity Range
      5 to +95 (non-condensing)
      3 n" t) Q! R/ h& V/ l
      . M. T  `) M: Y- E
      Hardware Specifications
      % D4 K7 a0 c# _- \2 T' U
      Symbol
      Parameter
      CPU
      CPU Frequency
      Quad-core ARM 64 bit A53 @1.8 GHz processor
      System Memory
      1GB (2x 512MB) DDR3L 16-bit inteRFace with 32-bit memory bus design
      Ethernet Port
      1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
      NGFF Slot
      M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
      SD Card Slot
      1x SD Card Slot
      USB /header
      1x USB 2.0 Port
      POE
      24V~48V passive POE/Active POE(Suport 802.3bt)
      DC Jack
      24V power supply
      LED header
      FFC/FPC Connector
      Serial Port
      1x Serial Port 4 Pin Connector
      Wireless
      On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain& e- E' n1 Z4 |
      On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
      4 x MMCX Connectors
      Bluetoothoptional
      Nor Flash
      8-32MB(normally is 8MB)
      Nand Flash
      256MB
      DDR
      1GB- F+ j; I* u7 ?( \- n0 Q
      Dimension
      185mm x 116mm
      % W. V% r7 Y# i, _
      , Q! |! Y  P5 J! A/ D6 E1 S
      Boot Config Switch
      ' o$ P: w( X: E# V" D) P
      Boot_Config Switch1(S7)
      Boot_Config
      Boot up InterfaceSelect
      S7A
      S7B
      S7C
      : v3 |8 ^5 O. |/ f
      0
      0
      0
      SPI NOR. (Default)
      0
      0
      eMMC
      0
      QPIC, Parallel NAND
      0
      USB2.0
      0
      SPI-NOR-GPT
      S7D
      0
      Boot from code ram.(Default)
      Boot from ROM
      Boot_Config Switch2(S9)
      Boot_Config
      0
      No auth.(Default)
      Auth is required
      , |3 T) Q5 t7 L; [, A, x" {: F
        U$ r' W1 g/ g5 i% C# C
      Interface MAP
      # ^' Y! Q* t- h  G; J* g) f
      " @! N2 P- q" e6 h2 F2 `
    APPLICATIONS
    + Profi WiFi hotspot coverage
    + Commercial radio coverage
    + Hotel Wireless application
    + Country coverage
    + Internet for passengers (bus, train, plane, …)
    + Security Surveillance
    + Some special scene application
    + Heavy-duty industrial environment use
    With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective router boards , wireless network cards,antenna ,enclosure and etc., Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win-win cooperation.
    Skype/EMAIL/Teams:sales@wallystech.com
    WEB:https://www.wallystech.com/
    4 Z- f1 c2 u( j
    * D; x# j9 O6 e& j) Y  c
    GMT+8, 2025-7-2 04:20 , Processed in 0.078125 second(s), 24 queries , Gzip On.
