查看: 147|回复: 0
ZCC4200三通道PMU 带线性充电器的Buck和Boost变换器替代ETA9073
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2023-2-7 17:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    FEATURES" t) o) V. g  ~5 e1 {
    ■ Three-channel PMU:Buck,Boost
    : P$ f# A% y5 H/ m+ X0 Jand
    8 q4 [# }/ c! c) |2 K) oSuper1 A) F9 X; q4 J
    capacitor charger) n; r+ f/ o( M) z) r
    - R7 T: o: O& v. N
    wide working range: 5V-40V
    & U- a. }4 I" F  \■ 3.3V 450mA Output Power for Buck
    # `# s  T/ G& _, N( J0 t/ s% f, A' h* \- o5 V' j
    12V 500mA Output Power for Boost at 2.7V3 d2 |# h- a1 D) a
    Input% L" g$ C: ^9 B5 K8 T7 w9 X6 @# u
      U) {0 I) [, ?/ `+ R9 O! B
    1% accuracy for Charger CV voltage and up
    : B0 U/ u) j; g9 M  A5 eto 150mA constant charge current0 m2 R: }' M5 v! I" [! a
    + ]) Y/ ]" t! Y3 V& h2 a' BHigh Efficiency PFM mode at light load for$ i  s) l! |5 p" I' M
    Buck
    / R# J) t! S5 w) E) C■ Enable pin to auto-switch boost and charger
    9 i& q# \9 g+ j5 s  ], L: O/ D" i; G* x7 E/ b' u5 I: T
    Available in ES0P8 and QFN3x4-24 Package
    5 u1 f9 r" H( L( O/ V& W5 XAPPLICATIONS- v2 o& l: ]- |6 U1 a* g
    ■ PLC modules& S! Y7 I. e$ p4 A& X6 _. L  j
    ■ Power Meters
    6 w- Y' N: Q- M1 R■ Any system that needs super capacitor as a
    ' \/ {  k7 A. X6 W# Ybackup power
    3 A; J$ \" d6 F$ I$ x+ K6 {( c" y- DDESCRIPTION
    # Y/ s/ r2 Z$ I, |+ kZCC4200 is a three-channel PMU that includes a9 T9 l: i1 q8 V5 K% i
    40V input, a high efficiency synchronous buck1 @2 q: H  J: u( J* q- \/ G# Y
    converter, a low startup, high efficiency 18V
    . |3 P! a5 F& }$ V- qboost converter and a super capacitor Charger.
    & r: E: G. S% S& P% V2 sThe buck converter withstands input voltage up7 H6 C2 v: O3 t& V2 `1 y7 \
    to 40V and delivers a 3.3V output with up to 450mA) U2 |, A9 J  n) F9 Z, y
    current. The boost converter is capable of
    " s0 Z' e, n% x7 T7 ]providing up to 500mA to 12V output from a single
    $ x4 P1 y$ _* D% z. r$ i4 U: z  `cell super capacitor or a battery at 2.7V. A# d$ E* B5 Z1 S& p! W/ t6 a- I
    linear supercapacitor charge is also integrated with a very high accuracy CV voltage.
    ! m% S+ o  ?( ^4 k6 s5 P) _' |, hThe output voltage of boost can be adjusted by
    5 A& z  H8 W4 qexternal resistor divider. All three power& v* G" I% B" ]6 ~& X4 F2 ~0 \0 U% {
    modules are packed into a single ES0P8 and  T, n: E) E  y& D7 E. x
    QFN3x4-24 package,beating the discrete0 n/ Z0 X8 h5 A: ~0 Y
    solution in features, peRFormance, size, PCB( f  A: t, d% y$ Q! O8 \) q- a9 p
    layout and cost
    GMT+8, 2025-7-3 04:18 , Processed in 0.078125 second(s), 24 queries , Gzip On.
