查看: 130|回复: 0
ZCC4200三通道PMU 带线性充电器的Buck和Boost变换器替代ETA9073
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2023-1-30 18:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    FEATURES' r$ r1 \1 U% W" m; o* K4 R
    ■ Three-channel PMU:Buck,Boost
    3 ~8 D9 X8 F2 _- Z  @+ Z$ ?+ kand5 c' M/ t$ {) Z$ C; b& \# h
    Super
    & T0 ~/ X8 }. V7 `2 q7 t  J" Ocapacitor charger
    4 i6 D6 ^) A$ Q2 F. D% X; Q* R# e- K2 s* i* t
    wide working range: 5V-40V: b2 y5 F, T5 j$ a
    ■ 3.3V 450mA Output Power for Buck
    ) n$ ^% o6 }" R9 j' |
    " P( Z  B. f8 H5 [( r# S$ q. m12V 500mA Output Power for Boost at 2.7V
    : l+ ~% s0 o% ]. p  x2 @Input
    / v3 K* s* ?# A9 K- x+ \
    8 V, O* c3 j' ]2 g1% accuracy for Charger CV voltage and up
    / z$ c2 H2 u8 D1 G: Kto 150mA constant charge current4 U  l3 C1 R4 t5 f
      L2 J. P7 C, o1 ^High Efficiency PFM mode at light load for, R5 ]( S, W) T# ?
    Buck. y& t1 H) H' t9 J  n2 q+ c8 Y
    ■ Enable pin to auto-switch boost and charger  @( W6 \' t$ H" T5 s4 O
    5 J2 ?# a6 `. n" U; c, o0 O( w* P
    Available in ES0P8 and QFN3x4-24 Package, h2 |/ D9 L( D3 t
    APPLICATIONS3 _3 `, c0 f6 m$ L, k
    ■ PLC modules
    + \* [% @( Q- ?$ @2 W' N% h  l■ Power Meters3 A% C/ y7 U1 B, }- _9 Z5 M
    ■ Any system that needs super capacitor as a
    4 i" ]- k7 U5 R2 |. r; Kbackup power/ E; s3 ]0 c- u& X7 H
    DESCRIPTION2 J1 q' Q# d4 h# I# Y, O
    ZCC4200 is a three-channel PMU that includes a
    6 E6 W4 B6 \7 Q( ?, p) O9 t( W! ]1 Q40V input, a high efficiency synchronous buck, a% }% X$ [9 j
    converter, a low startup, high efficiency 18V# {' y! D; C4 E
    boost converter and a super capacitor Charger.
    8 ]5 C3 g& R8 n6 M$ g5 iThe buck converter withstands input voltage up& v+ x+ Y' a5 P) H
    to 40V and delivers a 3.3V output with up to 450mA) o2 j( c5 j/ o  l1 F+ @  F& p8 u
    current. The boost converter is capable of( [! t' a* I# M& P
    providing up to 500mA to 12V output from a single
    5 G; D+ r  i# G% k" Z; ~" v. gcell super capacitor or a battery at 2.7V. A
    5 D7 Z& F( L) ?# }% w# Blinear supercapacitor charge is also integrated with a very high accuracy CV voltage.  k9 P% r9 M; U
    The output voltage of boost can be adjusted by' `& h) U7 D- [. B" V7 Z9 h
    external resistor divider. All three power
    . Q4 e% Q3 A$ \/ F5 Rmodules are packed into a single ES0P8 and
    * e! }5 M5 c( T- S( ~! yQFN3x4-24 package,beating the discrete
    6 U  P+ K& T- ^" h- E/ A3 |solution in features, peRFormance, size, PCB' p6 H4 ]0 y0 w+ Q
    layout and cost$ d& H7 E' @+ x) D
    GMT+8, 2025-7-3 11:04 , Processed in 0.078125 second(s), 24 queries , Gzip On.
