查看: 439|回复: 2
Wallys / WiFi 6 learning dairy
    2023-1-9 15:31
    发表于 2023-1-12 14:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    Wi-Fi 6 is a further evolution and extension of the wireless LAN protocol itself after the Wi-Fi 5, and its initial naming code is HEW (High Efficiency WLAN). The design idea of Wi-Fi 6 is different from that of traditional Wi-Fi. In the past, the development of Wi-Fi protocol mainly focused on providing higher peak rates. As can be seen from the protocol name “High Efficiency”, Wi-Fi 6 pays more attention to efficiency, and hopes to use the current spectrum resources more efficiently, so as to provide higher actual network rate9 y' F# z$ ^& M& I. W7 f7 G
    1 S) x' c* j- E! Q: t1 ^) [
    To this end, Wi-Fi 6 introduces new technologies such as OFDMA, uplink MU-MIMO, TWT, target wake time, bss shader mechanism, and 1024-QAM.* U% B2 A9 \8 j& H0 K, Q' W% w
    0FDMA
    0FDMA is an evolution from OFDM that was first used in cellular communications, and the Wi-Fi 6 standard has also adopted this technology to improve the efficiency of spectrum utilization. In the traditional approach, data sent by each user (regardless of packet size) consumes the entire channel. OFDMA divides a channel into multiple subcarriers and takes the smallest subchannel as a ResourceUnit (RU). In Wi-Fi 6, the minimum RU bandwidth is 2MHz, and users' data is carried on each RU. Taking 20MHz bandwidth as an example, up to 9 RU can be accommodated through OFDMA technology, and the remaining space is used as the protection interval. For example, a bus (20 MHz bandwidth) that previously carried only one passenger at a time can now carry up to nine passengers at a time (nine concurrent users).
      c# z3 B9 {# D. X6 T) A+ r* T
    * t+ _! F" R) L& G5 A# c
    Wallys communication (suzhou) co., LTD. (http://www.wallystech.com, which is a focus on wireless communications product design, manufacture, and provide high quality OEM/ODM/JDM professional service providers. As professional manufacturers and exporters of these products in China, we sincerely wish to establish business relations with you. Company main development Quacomm chip on the high power wireless products, such as ipq6000 / IPQ6018 IPQ6010 / IPQ4019 / IPQ4029 / IPQ8072 / IPQ8074 / QCN9074, etc.
    & m5 l, s2 t! r+ v+ y
    发表于 2023-1-12 15:17 | 只看该作者
    Wi-Fi 6主要使用了OFDMA、MU-MIMO等技术,MU-MIMO(多用户多入多出)技术允许路由器同时与多个设备通信,而不是依次进行通信。MU-MIMO允许路由器一次与四个设备通信,Wi-Fi 6将允许与多达8个设备通信。
    并不是和Wi-Fi 5相比的,而是和之前 SU-MIMO 相比的,写得仓促,请见谅  详情 回复 发表于 2023-1-14 13:48
    2023-1-9 15:31
     楼主| 发表于 2023-1-14 13:48 | 只看该作者
    big_gun 发表于 2023-1-12 15:17  G5 {$ q8 l9 s6 ?
    Wi-Fi 6主要使用了OFDMA、MU-MIMO等技术,MU-MIMO(多用户多入多出)技术允许路由器同时与多个设备通信,而 ...
    * w5 U: g$ b) O2 d并不是和Wi-Fi 5相比的,而是和之前 SU-MIMO 相比的,写得仓促,请见谅
    9 B9 t8 r; C+ I2 k# e
    GMT+8, 2025-9-30 03:09 , Processed in 0.125000 second(s), 27 queries , Gzip On.
