查看: 2651|回复: 14
AD23.01
    2023-2-9 15:41
  • 签到天数: 89 天
    [LV.6]常住居民II
    发表于 2022-12-16 18:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    AD23.01$ o1 b4 L' [/ @6 p& ~" G  p2 n! v
    magnet:?xt=urn:btih:A4FC292AA7AB5D7662DB2A1A709355B234DAFB4E&tr=http%3A%2F%2Fbt3.t-ru.org%2Fann%3Fmagnet&dn=altium%20Designer%2023.0.1%20Build%2038%20(x64)%20%5B%D0%94%D0%B0%D1%82%D0%B0%20%D0%B2%D1%8B%D0%BF%D1%83%D1%81%D0%BA%D0%B0%3A%2015%20%D0%B4%D0%B5%D0%BA%D0%B0%D0%B1%D1%80%D1%8F%202022%5D%20ISO
    ' I6 ~5 A& k) A, T  w! K( c& M- q: z
    Version 23.0.1
    Build: 38 Date: 15 December 2022
    Schematic
    51354
    In some cases, the "System.ArgumentOutOfRangeException" would be encountered.
    51839
    Brought back the autosizing feature for ports, enabled by default for a fresh installation (with no imported preferences) and only for newly-placed port objects. (BC:17706)
    52294
    In some cases, the EOleException "Object reference not set to an instance of an object" would be encountered.
    52782
    The error 'A given document's ID is invalid' was encountered when trying to add more than three Draftsman documents to a design project. (BC:19523)
    52942
    In some cases, the error "EOleException: The specified argument is outside the range of valid values" would be encountered.
    PCB
    47341
    The Dimmed Objects slider bar (View Options tab of View Configuration panel) was returning to the default position after closing and opening Altium Designer. (BC:10232)
    50376
    When generating ODB++ data, the pin data in the components file was incorrectly including the designator of the component, instead of just the pin number.
    51851
    When using the new Variant Manager, there were some cases where the error "Dispatcher processing has been suspended" would be encountered after clicking on the value for the Description parameter.
    52052
    Added a Silkscreen Preparation tool to the PCB/PCBLib editors providing silkscreen clipping, automated movement of silkscreen text and automated clipping or movement of fills/regions.
    52336
    Improved interactive routing peRFormance in the presence of complex layer stack regions.
    52425
    When exporting to AutoCAD, internal system layer names were being used and not the layer names defined through the Layer Stack Manager. (BC:18335)
    52426
    Clearances between polygon and track primitives were correct on the PCB, but incorrect in the generated Gerbers.
    52490
    In some cases, the error "E3DError: DXGI_ERROR_DEVICE_REMOVED" would be encountered. (BC:19905)
    52499
    An exception would occur when placing full stack vias in a PCB library, then switching to the Layer Stack Manager.
    52503
    In arc modes, the Interactive Differential Pair router would create unevenly spaced differential pairs if, in the rules, clearance > diff pair gap. (BC:19180)
    52507
    With the Component re-route option enabled, moving a component with attached primitives on the multi-layer would result in an Access Violation.
    52561
    For a specific design, removing unused pad/via templates from the Local Pad & Via Library would lead to a catastrophic failure.
    52581
    Component links were being broken at design import after having previously added a new variant or changed alternate part parameters using the new Variant Manager.
    52646
    A PCB panel document involving a high number of boards was taking around 15 minutes to open, compared to 30-40s in older versions of the software.
    52672
    ODB++ output for a panelized board was generating a separate folder for each stepped PCB instead of a single folder for all stepped PCBs.
    52725
    For specific designs, closing an open PCB document when the new Variant Manager was also open would result in an exception being encountered.
    52727
    The Collaborate, Compare and Merge panel has been removed from Public use. For the time being it is only available to Beta users as part of the set of Closed Beta features.
    52802
    The Net Information region of the Properties panel now has expandable sections to show all relevant class information. (BC:19422)
    52850
    For a specific design, moving a union of components and then attempting to Undo the action would result in Altium Designer closing unexpectedly. (BC:19714)
    52944
    When using the .VersionControl_RevNumber special string, the suffix "[no modification]" was being added for non-modified files. (BC:19797)
    53065
    For specific components, no Parasolid parts (*.x_t) were being created (from STEP models in the PCB design) when transferring the design from ECAD to MCAD.
    53130
    Generating ODB++ output from an embedded board array would result in wrongly named and missing layers. (BC:19887)
    Multi-board
    52438
    For a Module Entry using a Workspace Library component, the Properties panel now reflects the lifecycle and revision state, with the ability to quickly update to the latest revision.
    52439
    Single pin nets wired to a connector with a defined Net Label (in the child PCB project) would be named 'No Net' in the multi-board Schematic.
    Harness Design
    53252
    Added support for Harness Design through the creation of a Harness Project (*.PrjHar), which can be standalone or part of a multi-board project.
    Platform
    50633
    Support added for enhanced handling of projects with missing documents instead of automatic removal and flagging the project as 'modified' when opened. (BC:1243)
    50964
    In some cases, the error "EInvalidAccessToObject: Object accessed after being destroyed" would be encountered.
    52125
    Project is no longer modified if the stored printer for it is not available on a PC. Instead, that PC's default printer will be used, but can be explicitly changed thereafter.
    52374
    In some cases, the error "System.Net.Http.HttpRequestException: Response status code does not indicate success: 401 (Unauthorized)" would be encountered.
    52694
    In some cases an EAccessViolation (at address 000000016EC7C132 in module "ADVPCB.DLL") would be encountered.
    Data Management
    47275
    The control to open the Manufacturer Part Search panel from the Replace <Component> dialog (when choosing an alternate part for a variant) has been removed. (BC:17266)
    47488
    When acquiring a component from the Manufacturer Part Search panel into the Workspace, all datasheets were being added instead of just those selected in the Use Component Data dialog.
    51416
    With a Workspace project opened in two instances of Altium Designer, one instance (if closed and then opened) would need a manual refresh to see any changes made/saved in the other instance.
    51560
    Enhanced detection and resolution of duplicate project files, without the need to use an external VCS tool.
    51638
    Added the ability to export the project history into a PDF through an Output Job.
    51837
    Enhanced support added for admins to remove design repositories from Workspace (with validation). Also added auto-removal of repository after successful migration of external VCS project.
    52297
    It was not possible to add a Manufacturer Link to the ActiveBOM when the manual solution was from a custom part provider (synced to the Workspace using PrtSync).
    52339
    Added a warning dialog when attempting to rename the project file (or a source document) and that file is in the 'Out of date' or 'Conflict' state.
    52349
    Support added for layer-specific comments on the PCB (in 2D). Focusing a comment will auto-switch to the same view the reviewer had (visible layers, active layer, top/bottom view).
    52351
    A System.FormatException error would occur if attempting to set a non-numeric value for the Quantity field in a custom row of an ActiveBOM.
    52366
    The Project Releaser Item Naming Template settings are now stored in the project file, instead of the local Windows registry.
    52451
    The mention feature with comments does not pop a suggestion list when using the @ symbol and the local language keyboard is used (not EN).
    52474
    There were problems encountered with automatic task assignment when using the commenting feature.
    52555
    In some cases when working with comments, the error "System.InvalidCastException" would be encountered.
    52587
    In some cases, an EAccessViolation in module "EDMSInterface.dll" would be encountered.
    52615
    When adding an alternative item to the BOM, the Add Alternative Item dialog now remembers your used filters and values, just as the Components panel does.
    52616
    When removing an alternative group a confirmation dialog will now appear, alerting you that doing so will remove any alternate components assigned to that group from the BOM also.
    52656
    The active VCS status pop-up window was not displayed correctly if the Projects panel was docked in a position other than on the left. (BC:19688)
    52676
    For a specific project in an external SVN repository, the Open/Compare right-click commands in the Storage Manager panel would not function correctly. (BC:17509)
    52984
    In some cases, switching between Pro and Standard Workspaces would result in the Pro Workspace losing features/functionality.
    52986
    In some cases, it was not possible to add new components or edit existing components in a Workspace Library. (BC:19813)
    Import/Export
    49342
    When importing a specific mentor Expedition® design, holes/cutouts in copper were not being converted correctly.
    51388
    In some cases, the EStringListError "String list does not allow duplicates" would be encountered when importing a pads design using the Import Wizard.
    51790
    In some cases, an Access Violation in module "LoadPADS.IWZ" would be encountered when importing a PADS design using the Import Wizard.
    Simulation
    51212
    The text "Output Expression" had a typo in the DC Sweep and Transient areas of the Simulation Dashboard.
    52279
    Running an AC Sweep Analysis with an Output Expression of MAG(v(resistance))) would result in an incorrect value for the AC Voltage.
    52310
    In some cases, the EOleException "Index was outside the bounds of the array" would be encountered when performing the verification stage.
    52371
    The model description for the following components was incorrect - CCSW_Hysteresis, CCSW_Smooth_Trans, Switching Capacitor, Photodiode.
    52378
    Added support for additional Pspice digital model primitives including flip-flops, latches, Pullup, Pulldown, Delay Line and behavioral primitive LOGICEXP.
    52379
    The performance of the SimData editor has been enhanced with various optimizations, memory buffering and removal of redundant calls.
    52398
    Added PSpice standard gate components (AND, OR, XOR, NAND, NOR, NXOR, BUF and INV) to the Simulation Generic Components library.
    52399
    Added PSpice tristate gate components (AND3, OR3, XOR3, NAND3, NOR3, NXOR3, BUF3 and INV3) to the Simulation Generic Components library.
    52400
    Added the PSpice Digital Generator component to the Simulation Generic Components library.
    52403
    Ability to view the high-impedance state for digital waveforms in the SimData editor.
    52477
    There was a typo in the simulation error message "Operating Point Analysis: Failed to Calulate the Operating Point".
    52724
    For the STIM component, the incorrect starting value was being used for d(pre) in a transient analysis ('0' instead of '1').
    52754
    When running the verification stage, an error with model syntax was not presented in the Sim Model dialog, while an empty error message was presented in the Messages panel.
    52828
    The .IC and .NS components from the Simulation Generic Components library were not being added to the generated netlist.
      C% C( Y% Y5 Y/ O, A7 `" W
    2025-7-26 15:18
  • 签到天数: 1013 天
    [LV.10]以坛为家III
    发表于 2022-12-16 19:59 | 只看该作者
    又更新了!不愧是更新帝啊!
    无聊
    2025-7-26 15:00
  • 签到天数: 1679 天
    [LV.Master]伴坛终老
    发表于 2022-12-17 08:12 | 只看该作者
    感谢楼主无私分享,再过半个月就是23年了,AD发布23版,也是理所当然。
    ( j: Q' O$ s( e- L2 ~: P3 e不知道有没有令人惊艳的新功能?
    3 K0 m& G1 g8 g4 a
    2024-7-24 15:14
  • 签到天数: 229 天
    [LV.7]常住居民III
    发表于 2022-12-17 12:29 | 只看该作者
    谢谢楼主分享,已经在下载了
    发表于 2022-12-18 15:45 | 只看该作者
    有啥新东西?
    发表于 2022-12-19 19:36 | 只看该作者
    各位大大這要用什麼來下載呢?
    迅雷哦  详情 回复 发表于 2022-12-19 20:38
    2024-7-24 15:14
  • 签到天数: 229 天
    [LV.7]常住居民III
    发表于 2022-12-19 20:38 | 只看该作者
    steve1234 发表于 2022-12-19 19:36
    0 n, x' z9 c# h% c6 D8 M0 L6 T各位大大這要用什麼來下載呢?
    , D0 T' X! C0 ^5 S3 n. l/ E1 T迅雷哦
    # s  Q' N' J, Z2 e  G* d2 r  W
    发表于 2022-12-21 19:57 | 只看该作者
    迅雷搞不過,下載不了。可有網友提供其他下載位置?
    PCB论坛网-PCB论坛-PCB设计论坛 - Powered by Discuz! (pcbbbs.com)  详情 回复 发表于 2022-12-22 08:28
    2023-2-9 15:41
  • 签到天数: 89 天
    [LV.6]常住居民II
     楼主| 发表于 2022-12-22 08:28 | 只看该作者
    steve1234 发表于 2022-12-21 19:577 X" M) k2 h; K
    ( A& F9 Y& ~% t9 n/ ~" {0 jPCB论坛网-PCB论坛-PCB设计论坛 - Powered by Discuz! (pcbbbs.com)* d3 {2 p" E/ _3 g1 q3 u& r7 P
    发表于 2022-12-22 19:16 | 只看该作者
    謝謝樓主,可是一樣一點進去出現
    : O3 I+ ?+ k: y/ f, Z3 G$ b此頁面目前無法運作
    0 N7 c' W  s5 T- J6 ~6 Dwww.pcbbbs.com未傳送任何資料。5 g% _* t; i7 q3 v( T
    ERR_EMPTY_RESPONSE
    OfflineSetup_Altium_Designer_Public_23_0_1.zip | Altium China Secure Files Share  详情 回复 发表于 2022-12-23 07:31
    2023-2-9 15:41
  • 签到天数: 89 天
    [LV.6]常住居民II
     楼主| 发表于 2022-12-23 07:31 | 只看该作者
    steve1234 发表于 2022-12-22 19:16  Y  S2 r) M* l: w
    謝謝樓主,可是一樣一點進去出現
    5 I; Z% n; L5 m- M5 j' `4 I- c此頁面目前無法運作
    : e# T+ {8 U+ x) D6 D7 owww.pcbbbs.com未傳送任何資料。
    6 n7 Z& W- Z! q- ^4 x7 Q, QOfflineSetup_Altium_Designer_Public_23_0_1.zip | Altium China Secure Files Share3 d4 z' q& S' Z. p7 g
    发表于 2022-12-23 19:49 | 只看该作者
    謝謝樓主!可以下了。有您真好,謝謝!
    13#
    发表于 2022-12-26 09:42 | 只看该作者
    运行速度有没有变快?
    GMT+8, 2025-7-28 13:35 , Processed in 0.140625 second(s), 29 queries , Gzip On.
