查看: 169|回复: 1
IPQ4019/IPQ4029 support Wallys| QCN9074/QCN9024 WiFi 6E Card mini pcie 2×2
    2023-2-7 15:43
    发表于 2022-12-13 14:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    WiFi6 and WiFi6E 4×4 MU-[color=rgb(68, 68, 68) !important]MIMO QCN90X4 Dual Band WiFi Module
    mini PCIe usually uses the PCIe x 1 bus. The speed varies according to the platform. The common PCIe 3.0 x 1 speed is 0.985 GB/s, and the conversion rule is 10 MBPS =1.25MB/s.
    mini PCIe to [color=rgb(68, 68, 68) !important]SATA
    A mini pcie inteRFace is defined with a SATA interface. Therefore, the mini pcie interface is not supported. However, only one SATA interface can be extended.
    There are two kinds of chip conversion: half-height size and full-height size. Xiangshuo ASM1061 chip is generally used. It supports mini PCIe to dual SATA3 interface.
    Industrial tablet computer or industrial computer, will be equipped with wireless device this interface. MiniPCIe is based on PCI-E bus, which can expand peripheral devices for industrial control all-in-ones, such as [color=rgb(68, 68, 68) !important]Bluetooth module, 4G module, and solid-state disk with MiniPCIe interface of wireless NIC module. However, the bandwidth of MiniPCIe interface is not high, so it is suitable for peripheral devices that do not have high data throughput requirements. Some motherboards have multiple MiniPCIe ports inside. In addition to the built-in wireless network card, at least one more is reserved for the 4G module (and the antenna is embedded). Although the two interfaces are common, but there are “half high card” and “full high card” difference.
    [color=rgb(68, 68, 68) !important]Qualcomm Atheros QCN90X4
    Maxim Tx power 20dBm per chain
    Data Rateup to 4949Mbps
    Support  5.180~5.825Ghz or 5.925GHz-7.125GHz or  5.180GHz- 7.125GHz
    MiniPCIe connector
    PCI Express 3.0 Interface
    Applications
    Security Surveillance
    Commercial radio coverage
    Hotel Wireless application
    Forest fire protection engineering
    Country coverage
    Some special scene application
    [color=rgb(68, 68, 68) !important]product Description
    DR9074E based on QCN90X4 Chipset is an enterprise wireless module integrated with 4×4 MU-MIMO Dual Band Wireless Module designed specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment in factories, warehouses establishment.
    PCIe, short for PCI Express, is a new-generation bus interface. It is a new technical specification jointly drafted and completed by more than 20 leading companies in the industry. By using point-to-point serial connection, it can increase the data transmission rate to a high frequency, so as to provide higher bandwidth.
    PCI Express interfaces can be classified into X1, X4, X8, and X16 according to the bus bit width. At present, PCIe X4 is widely used, and PCIe 2.0 and 3.0 versions are widely circulating in the market. The corresponding X4 bandwidth is 16Gbps/32Gbps, which translates into a transmission rate of about 2GB/s and 3.93GB/s. Compared with SATA interface, this is a very scary rate.
    On the other hand, solid-state drives with PCIe interfaces are relatively expensive.
    Commercial processes and communications are all managed utilising wireless technologies, and the number of users, devices and apps are only going to increase.  Therefore, it is essential to have a r[color=rgb(68, 68, 68) !important]OBUst, secure and high performing WiFi solution that is future-proofed, mobile, and scalable.  Not only is business WiFi vital for your workforce and organisation, it is now imperative for visitors to be able to access a secure guest wireless network.
    Wallys  has been specializing in product design & manufacturing and delivering superior OEM/ODM [color=rgb(68, 68, 68) !important]services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.
    Skype/EMAIL/Teams:sales@wallystech.com
    [color=rgb(68, 68, 68) !important]Web:https://www.wallystech.com/
    发表于 2022-12-13 18:28 | 只看该作者
    芯片转换有两种:半高尺寸和全高尺寸。支持迷你PCIe到双SATA3接口。
    GMT+8, 2025-7-24 10:54 , Processed in 0.109375 second(s), 23 queries , Gzip On.
