( k# l( | r9 e9 E0 H/ r% d" v1 T7 b/ s
我在坛里下载了altium Designer v21.6.1.37里面有破解放法不是很多明白,如1. 安装 Altium Designer 21
, Z3 E+ |$ E0 Z, M' l6 U2 T7 _2.将shfolder.dll复制到可执行模块所在的文件夹:X2.EXE
i/ a% [/ G( u2 U 通常在这里:C:\Program Files\Altium\AD21\
+ ]6 j: D3 q; A" g1 C6 o) @" b$ b8 _1 {
3. 运行应用程序并使用提供的“正确”许可证。, q) h( u7 q% Z. r. ]
当然,您可以生成/编辑您的许可证,
. L! l' G; A; b: R# R) J( V 使用附带的模板。) F, G2 k/ O* b% r
! x( Z4 b/ p- @1 w, e
使用生成器修复它们:) m7 e8 R8 B- `. [; J0 G' M
1. 加载许可证(加载...)。6 Q: J8 a1 R0 l& S }3 @
您可以将许可证文件拖到生成器窗口中。
( `3 } A, _5 u! i7 z2 t5 b: ]. {, ^; D- ?6 M! S) N7 Z3 c- }
2. 保存许可证(导出为...)
" I2 E" N- R- _( w) W! w$ [
5 q( S5 A# Y) Q( o- _/ Z享受!
$ t1 o; T9 i- m0 ~$ \
* m8 ?% J3 S, h& @7 \: q
p% h7 t% A* p: [% S5 U# t# u! J' p# d4 N6 | A
As previously reported, UniSoft has created a new crack for Altium.% v4 w: C5 r6 _/ c" r4 d
————————————————————————————————————————————————————— ———————. n# k* G2 k4 p
No original file changes!
. W* j: b" F- k7 J# E* ?4 [The crack is universal, works with:0 _, X. b6 O) P. n6 K. S/ z
■ Altium Designer (AD), version tested:+ d u% f# l0 ?! B& {
• 21.1.1 (Build 26) x646 s# ~$ w! ?8 [/ g; F
& E C% v; [: X: I
7 \( W9 @6 W1 I! KHow the crack works, on the fly substitution of a private RSA key for your own,
- v. X! c: U9 s/ btherefore it will only work with "correct" licenses,+ ~1 a) N! @) `. ^! e+ |9 ~& o
generated by the corresponding generator also created by UniSoft.. n6 o# Q! E5 v
————————————————————————————————————————————————————— ———————————————) R3 ^# b' ] K- x' L1 p9 I6 @" A
/ j9 X% _7 e9 L4 YArchive composition:
) J; A3 Q8 k2 L2 X, m1 O8 } shfolder.dll - the crack itself, a small dll that is placed in the folder
/ ?( r( z' q* @0 r8 I& B) q7 } with an executable module.
9 f0 x$ S+ |& e* P
8 J% h; k- A" ]0 S. P ADLicenseGen.exe - License Generator0 n h1 Q( h9 X' q' V: W+ u% G3 k3 @
( P9 Y2 l' n1 W# c Licenses - Sets of "correct" licenses for the AD19 Standalone
8 T' `8 ]' d* W$ o8 z6 j9 V i k# r! j' A1 ?& H( B0 D; I
———————————————————————————————————————————————7 c3 w! Z9 t" M$ \. |6 p
So:
" P4 v& f6 \8 D& u! }4 iFor a clean install:
: J j8 g" b0 v# g6 T/ l# t5 Y0 J———————————————————————————————————————————————
u0 Q. w( D5 V T; n* O1. Install Altium Designer 21 (x64).8 `& Z$ L; }4 }7 g* T
3 p Q* |- w; j9 f% z. x5 u
2. Copy shfolder.dll to the folder where the executable module is located: X2.EXE/ d! U: ?3 e/ v2 g/ @) V. N$ |- u
usually here: C:\Program Files\Altium\AD21\
1 n3 @- d$ s# Z/ N( n# p9 B( u: A; q1 d; t, G
3. Run the application and use the supplied “correct” licenses.; s' ^& t; R/ i) N( A
Naturally, you can generate / edit your licenses,% D! H4 E' e7 n* }; n' k
using the attached templates.% ~3 {% R X( f2 O. }5 k9 }
( t2 @9 W/ h, U9 V$ I5 S3 ^
W8 Q1 U [; D* @& KIf you already have your own "favorite" licenses,
6 d0 C+ y. a1 C. Y4 H; }———————————————————————————————————————————————( l2 p2 [% z4 w3 a
Fix them using a generator:
; M7 C6 c: ~# A5 x9 u1. Load the license (Load ...).
* D+ ]3 \6 p8 _ F1 D4 @! M$ S You can just drag the license file into the generator window.6 o, i N/ l6 U; S- L
$ c& b# f/ `2 Q# S' D. |2. Save the license (Export As ...)' [0 r, o7 l2 }
$ s, V+ D# U3 t8 {/ }—————————————————————————————————————————————6 J" K. t" l) a( y
In case the medicine needs to be removed:, ]# D4 S6 }) K# B) k9 ^$ n
6 e" F0 I* v6 X2 g1. Close the application (AD).
) p7 `2 w4 ]+ L6 T4 H2. Remove the crack: shfolder.dll# ]; p7 q% j7 W* W& I4 y) x5 B/ @
* j, V8 e V' ?- }
( @5 G0 r* H6 E4 {& o" {
Enjoy!( F/ _& y6 H$ G. h0 \% z( [0 ?
4 s9 s5 M: x [% V% R" U* {7 Z- c
