TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
Features
. W+ q, i+ F4 Q% {■
6 W1 x" V( t* c, g% n20-μA Quiescent current in regulation1 H$ D3 |6 A) u. q+ T# s, d. s
■0 O' r# p+ w" Y4 G; Z- T
Input voltage range: 4V-60V
) d. g) g5 T$ J■
3 P$ }: _0 N$ Y7 |; F# @ {Output voltage range: 1V-VIN% X {. s8 n. u0 [2 I, J5 X- T# Q
9 \# V2 K! I# ~2 PIntegrated upper and lower power MOSFET
. O! d- O2 D+ E0 L% e" Wmaximum current: 5A1 q. h) W( k9 f/ m
■0 R6 J% B% E( Z
Adjustable frequency range: 200KHz~2MHz
( a4 T5 ~( @" p$ ]+ M6 t0 f) ~■* s$ k' _) s" l/ r" O
Automatic switching of CCM/DCM/PFM mode8 E/ ?8 r: i& n( U
■; d& I2 ]$ E2 |! |: n
Adjustable soft-start time and Output voltage" Y& f6 r: b2 _1 q
tracking capability
* ~6 r, M4 D& \2 I6 P■
6 T& M' v7 x& q. }( \Automatically switched bypass linear power$ E' ]* V2 \! z$ R. N& F6 M
supply# f$ J4 `( e, ~0 Q& u- e) U, C
3 B! e* [5 B6 fProvides ultra-low input and output dropout* f+ k+ ^; G$ g# g5 g7 N
voltage close to 100% duty cycle
9 ^# k$ G+ E2 }7 r1 H/ ~! s■3 f& ^! l, @: J1 i2 W
Internal Compensation
" g S% d C# P2 {) G) C+ Y■9 l' F# A2 @: O- C; a# H
Power-good flag( l5 ]8 p( g* y
■3 ]( x9 O' s$ I. Q s: g( I0 H
Dynamic Frequency Stretch Technology; L4 G0 b* |' t) a/ f. M( S; A
2 T6 r @8 O5 x. ]Support large capacitive load start-up2 H+ [; p$ z" h& \
% E8 {) A* n# A M" m0 s. S6 Y5 OProtection function: UVLO/OCP/SCP/OTP/OVP% z" w$ Q. Z: X4 x
% {, X8 o. g) i) COperating junction temperature range: -40℃ to7 |, o! Q& ^+ z' Z9 C8 R: L) R
+125℃& y7 V' V8 @' l- F! h1 W; h
■0 G9 F W u" G; T+ _/ M
All pins have ±2000V (HBM) ESD protection
& h6 }4 s$ L' T U/ Q6 h■. ?) J2 x9 G) ^3 E
ETSSOP 16-Pin Exposed Pad Package: H5 g9 l( N5 R! H* D( I
Applications
" U/ N: }) L3 h# C■1 a; o% ^+ _; t* v' y1 L- @
Industrial power supply* f4 T- A0 Z& q5 r3 a
■7 v Y/ C' H. F4 [. M
Wide voltage input range power supply
$ _8 e$ o& N& F m, C0 K) D+ o■4 \3 @# V! R8 d8 ]( Y
Low ripple low noise power supply( g# R7 p0 Y3 X \8 S1 E
) o) W( \; ?& hAutomotive electronic power supply
2 s9 P9 T/ ^3 H) [Description
' e2 T8 ]% \: SZCC5160 is a step-down DC/DC regulator with an
# z0 j- `2 q9 Z$ Winternal switch, featuring SKIP control mode, which* O+ p2 d$ p! ?. Y
combines low quiescent current with high switching' Z/ R; M9 u- x+ ^1 X
frequency to achieve high-efficiency regulation over a
% n0 \$ [, T1 l5 owide range of load currents. SKIP mode uses a short" ^6 y$ X- b. i: D8 ~; T) Y
"burst" cycle to switch the inductor current through8 M. P6 M* P( z* |
the internal power MOSFET, followed by a sleep5 C+ R' a" f, t
cycle in which the power switch is turned off and the: ^$ ^8 I3 L- l
load current is provided by the output capacitor. At
% e7 s2 b- j4 D* f1 D1 klight loads, burst cycles are a small fraction of the/ v( V% n8 E5 P+ @. ^& }3 N
total cycle time, minimizing average supply current
) r1 M6 l! m5 z; l+ F, t3 land greatly improving efficiency at light loads.
6 B0 S/ R# C* WZCC5160 has a wide input voltage range of 4V-60V,
5 P# O' K( C" l3 uthus minimizing the need for external surge4 q3 y2 a3 Q% c0 q! S2 D
suppression components. Making it the best choice
/ F' h U* _3 C* qfor wide input power range industrial and high cell
- b! K% c1 W7 [1 d7 B, Fcount battery pack applications. ZCC5160 is ideal for
6 ~ a* U& F/ k) Y6 D9 r2 u5 @use in the 48V automotive power bus range.
. I7 p8 k) c% N" b! ^ZCC5160 features low-value 100mΩ high-side and' l! @0 o, I" ^1 J
80mΩ low-side MOSFET that provide at least 3A
: P% P9 P7 W4 V+ J+ x& Moutput current capability with excellent load and line7 i2 H- R/ c; r( V% ~" k2 Y. J* Y" X
transient response.
9 @/ o% n/ m' a6 c+ h5 m# zAdditional features include: soft-start, thermal
: f" e; Q' D0 s4 @# g" _4 Bshutdown, UVLO undervoltage lockout, gate driver
' t8 G1 l/ R; W) Mundervoltage lockout, maximum duty cycle limit timer,
) ?' p; }; {' M0 `5 N0 s3 `and current limit shutdown timer. It also integrates" |2 T: Z, t9 \- N6 [9 e! f
output short-circuit protection, providing HICCUP! |1 R' s- A0 ~ |1 S
mode when the FB voltage is low to avoid+ C& h. n/ Q4 F/ S1 G# E
overheating during short-circuit.- X+ F( Y' q: I% o [ O/ a$ [
6 p7 _2 r5 U( a7 C
