pcb_mingchuang 发表于 2012-11-16 18:10
" P; ?8 D" y* y/ T% C5 n' s转换过程中,提示如下错误,请问如何解决。
( f4 B4 d- V3 o4 r; y3 g: r5 Q8 r---------------------- Al2Exp summary -------------------- ...
4 {3 ~: w# c- o7 hERROR: Techfile conversion failed!
4 \5 B& X- I5 o p$ l4 ?5 AWARNING: layer TOP not found in layer table. Check the Allegro cross-section!
, V- N0 D) c1 w" e; `& w+ m( ^WARNING: layer BOTTOM not found in layer table. Check the Allegro cross-section!9 u& ~% ]0 S2 k5 {
WARNING: layer ART04 not found in layer table. Check the Allegro cross-section!
) e8 U; s6 N9 g# X, i8 |WARNING: layer POWER05 not found in layer table. Check the Allegro cross-section!
7 j, {1 S# W1 L! L! B9 zWARNING: layer ART03 not found in layer table. Check the Allegro cross-section!
( ^" v& D* ]0 R+ l7 E! E3 dWARNING: layer GND02 not found in layer table. Check the Allegro cross-section!
1 q; K5 j, ~, D6 Y7 p F0 ^ERROR: no data issued for clearance DEFAULT
( T* |% u- }# y( \# cWARNING: layer SOLDERMASK_TOP not found in layer table. Check the Allegro cross-section!
4 r/ ~ x! M9 F1 vWARNING: layer SOLDERMASK_BOTTOM not found in layer table. Check the Allegro cross-section!# w- X5 A9 N) l3 G# X
WARNING: layer PASTEMASK_TOP not found in layer table. Check the Allegro cross-section!
; H/ p: b7 o& h0 }) b P' IWARNING: layer PASTEMASK_BOTTOM not found in layer table. Check the Allegro cross-section!1 _- q; l# Y- [
WARNING: layer FILMMASKTOP not found in layer table. Check the Allegro cross-section!' p: \+ |+ L: y& J9 Z
WARNING: layer FILMMASKBOTTOM not found in layer table. Check the Allegro cross-section!
* K& A# ?" H, L, tERROR: Unable to issue shapes for padstack BALL14M2 - layer problems
* |' g4 f* J2 j7 N) jERROR: Unable to issue shapes for padstack BALL10M1_5 - layer problems3 Q Q$ Z7 D1 |
ERROR: Unable to issue shapes for padstack BALL40M20PN - layer problems
; ?/ k. {2 O% m0 D& ^" ?( zERROR: Unable to issue shapes for padstack RECT10X60 - layer problems
7 R" {4 n7 e5 S2 n$ GERROR: Unable to issue shapes for padstack SMD_SQ12M2 - layer problems
1 E7 N% ~) j$ h& b _ERROR: Unable to issue shapes for padstack RECT103X138PN - layer problems
X, l+ T0 q5 O# }ERROR: Unable to issue shapes for padstack SMD_OV63X24 - layer problems
5 N% |+ ]* l, G; L+ r$ F" vERROR: Unable to issue shapes for padstack SMD_OV12X36M2 - layer problems$ A# N# u) C* p k6 I9 o
ERROR: Unable to issue shapes for padstack RECT25X70 - layer problems- k2 @% c5 g$ ~+ s; U) _
ERROR: Unable to issue shapes for padstack RECT24X60 - layer problems
8 N9 V1 u2 l1 [3 U% B0 B6 q/ F1 `ERROR: Unable to issue shapes for padstack SMD_OV24X74 - layer problems; c# z9 l" x/ R# g* `+ F6 F
ERROR: Unable to issue shapes for padstack SMD_OV24X52 - layer problems
9 k! I. j: U4 q2 }' V: ]( U9 ?. YERROR: Unable to issue shapes for padstack SMD_RE47X55 - layer problems6 `: }( `0 v" y
/ H; `) ]0 n+ m----我的出这种错误,请问你们的问题解决了么?% [+ T6 }2 L/ Q9 c* q! I; y
, k% a4 V/ W( ~8 e0 V" [' U
