查看: 214|回复: 0
ZCC5160 Synchronous Step-Down 60V 3A V2.0
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-11-4 17:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    Features
    5 m" @5 ~7 a3 i" s& i& a
      u; H2 E0 e$ R. Q6 t20-μA Quiescent current in regulation6 X# n3 k  \4 s, _( ]' }/ X3 H
    & X, k8 }/ A) C8 z/ k1 q5 Y& ~
    Input voltage range: 4V-60V
    $ Y: X$ Z9 Y" @9 y0 M1 T4 J$ t7 E/ t5 D; K, G( B* y
    Output voltage range: 1V-VIN2 f& W" i; Y0 W$ Q! P8 O8 B+ Y
    6 q7 i( B; Z9 I! }
    Integrated upper and lower power MOSFET' K3 R0 B0 Z. U0 h  [* k% w
    maximum current: 5A
    " Y0 c9 l! X: Z1 F) }! v" v7 I9 {
    Adjustable frequency range: 200KHz~2MHz
    2 N, p) c- Q6 u( [9 }
    " m5 v3 N( u' G: E  o6 DAutomatic switching of CCM/DCM/PFM mode
    3 J1 a( p5 K7 ^7 }5 _/ X7 y
    0 L  W% ^' ~1 t2 P; HAdjustable soft-start time and Output voltage2 b. K* K& ~6 n6 V5 g
    tracking capability
    9 X' o) N/ J; m+ \; l$ }+ k( t+ a
    / H  K& L" B: C$ P1 p$ Y/ r* X$ }Automatically switched bypass linear power7 ]: ^, ~; S5 O' g
    supply
    & P4 v5 _& z3 b4 i& J; N' T' H/ v0 j$ e
    Provides ultra-low input and output dropout& q+ C% r. O6 b' K9 z: u
    voltage close to 100% duty cycle6 Y0 h" I3 h$ z: l$ Z: F
    $ }( u/ M2 V+ \7 vInternal Compensation2 c8 j2 ?0 X: W0 ?5 v# s* u
    7 ~6 N# Q5 a9 z' r. `Power-good flag, q0 G) [* f% w7 R  @5 C3 n
    7 R! q% W- q$ V9 O' V
    Dynamic Frequency Stretch Technology0 k- o& A: X+ q+ f  Y4 ^
    ' ^& {6 O* W8 u* I" L6 X
    Support large capacitive load start-up
    " Y5 r% T# Y3 ]5 t0 K& M( x$ m7 `4 Q
    & Z! u; a# }* g8 E& r" i, iProtection function: UVLO/OCP/SCP/OTP/OVP+ {: l9 x2 v- x: i3 t
    % m% J3 V' x8 V# I$ iOperating junction temperature range: -40℃ to
    + M2 t" m5 k' |( Q9 {+125℃" ^+ s1 N+ c5 a
    ( \- g2 L) Z& K; x% GAll pins have ±2000V (HBM) ESD protection
    3 I4 B: A; x% C: Z/ L" K5 ^; S! I0 H8 Q  D9 `
    ETSSOP 16-Pin Exposed Pad Package
    " R3 ^- N/ U0 _# KApplications
    6 o. [9 C, q2 }* j/ X7 m7 ^
    1 v4 r  u3 a* W3 {+ u+ b; K2 k6 IIndustrial power supply) Z) D% M5 x, ], ~3 l
    ( O' y; @# I9 n1 Z5 Z( H
    Wide voltage input range power supply
    " _% b& b8 B  t. ^* \" ]& U% V8 S
    Low ripple low noise power supply  w# g0 B4 y# Y, s9 r6 N  b
    , U& \: Q- a8 ~- a  H  c4 U( ~- S
    Automotive electronic power supply
    2 \: g. i  ?$ L, }/ O$ h4 x- uFigure. 1 Typical Application Circuit
    4 ?/ ^; e! @- ?! Q# b) a, f; QDescription' {' P; c- I/ [4 N
    ZCC5160 is a step-down DC/DC regulator with an: ^, l& y+ l# N+ z/ S
    internal switch, featuring SKIP control mode, which0 e0 J) G0 g& ?5 o; \* W- V
    combines low quiescent current with high switching
    " t; }2 d( A# d- Q, Nfrequency to achieve high-efficiency regulation over a3 t% N2 N" k" B- _1 G
    wide range of load currents. SKIP mode uses a short$ r3 \/ G& `) n0 X4 }9 x- U
    "burst" cycle to switch the inductor current through+ Q7 B4 P9 x: x
    the internal power MOSFET, followed by a sleep
    2 ]' R% ~) V0 g3 [/ X/ bcycle in which the power switch is turned off and the
    ; J" Q" q' @' C4 Aload current is provided by the output capacitor. At
    ' k. s3 L* x8 l/ ?light loads, burst cycles are a small fraction of the* p# o3 L& ~0 W0 K% Q
    total cycle time, minimizing average supply current6 w1 s! W) o" Q
    and greatly improving efficiency at light loads.0 E; p/ ?" f2 W+ ~8 ~' G
    ZCC5160 has a wide input voltage range of 4V-60V,( Y% c( r4 z6 j7 H4 T- }5 f
    thus minimizing the need for external surge7 j3 x6 Q# ~+ p8 q- W
    suppression components. Making it the best choice
    6 `. z* O% t: q  t. |4 p* |3 Afor wide input power range industrial and high cell8 t7 p, p- O- ], P
    count battery pack applications. ZCC5160 is ideal for
    " T3 h# X: E! r9 l- yuse in the 48V automotive power bus range.
    : k$ @9 ~1 Y' F8 I  F; rZCC5160 features low-value 100mΩ high-side and
    + `7 i: Z/ }  b. Y; M; o80mΩ low-side MOSFET that provide at least 3A
    : U# _& u2 n  G5 w) voutput current capability with excellent load and line. M' @! m, J/ F; \8 D# V
    transient response.& _4 I& J0 [5 P3 K, f/ q8 P4 I
    Additional features include: soft-start, thermal% h  C( y5 Q8 {# W/ A7 {
    shutdown, UVLO undervoltage lockout, gate driver
    ! y' l9 m# M  u  F6 {undervoltage lockout, maximum duty cycle limit timer,
    5 t1 u  x, A; X8 Q) x( ?and current limit shutdown timer. It also integrates
    ; E7 H/ J: M$ x- m. q5 D0 toutput short-circuit protection, providing HICCUP
    3 |7 ?# u, L' T* h8 A' R5 emode when the FB voltage is low to avoid3 V8 W; S: U& k& g0 ~, w
    overheating during short-circuit.
    1 F6 [; u1 C7 @$ ?8 n
    GMT+8, 2025-7-5 07:21 , Processed in 0.125000 second(s), 24 queries , Gzip On.
