在Eric Bogatin(Signal Integrity - Simplified的作者)的博客上看到的,DC的挑战仍然巨大啊。
' M# K0 h" B5 ~. X
; Y$ \0 r7 [8 T- P0 R( d“That’s a pretty cool benefit,” Phil Warwick, CTO of R&D Circuits, a leading edge circuit board manufacturer said at the 5-TA3 session at DesignCon 2012. He was referring to the use of 0.4 mm pitch BGA packages.
$ g: @( Z- Q3 [
5 A8 \5 z: q! }, HOne advantage he’s identified is that differential vias with the typical drill hole size, on a 0.4 mm pitch, with surrounded return vias, results in a differential via impedance of about 85 to 120 Ohms. As long as the via stub is backdrilled, the thru part of the via will look pretty transparent, an advantage, Warwick says for 25 Gbps links.
B* K( @$ c* x& S: k! g! ~& O6 L) G7 _
But, the problem these higher density pitched create is narrow web for delivering the high currents required by large pin count ASICS and FPGAs. Some of the devices he builds boards for require 100 to 300 A at 0.85 v. In the narrow web between clearance holes in the power and ground planes, shoving 300 A causes hot spots which can burn out the board. “We will fry that web quickly,” Warwick said and backed up his comment with graphic images of splattered copper that used to be a narrow web.% O7 c8 ?; A2 H, c! C
9 x$ R% s/ j$ [
To manage a low DC IR drop from the planes to the center of the package, Warwick has worked with chip and package designers to implement a new ball topology he calls “slats”. Rather than scatter the power and ground balls in a checkerboard arrangement, typically recommended to reduce the inductance in the PDN feed to the package, he suggests using grouped rows of power balls and ground balls, as shown in the figure above. This enables wide channels in the power and ground planes and low IR drop.
. i, d2 z( [# x& C+ v; c, n* s4 D: J2 T+ C; S. ~' M
Temperature rise measurements on boards produced with this slat topology showed only a 20 degree rise with 200A of DC current.
. [( e4 X8 _ ^& t, n7 N" R* \' ]. {; T& j4 _
Warwick suggests that while it is important to pay careful attention to specific board features to enhance 28 Gbps data paths, there are still important design tradeoffs to manage all the way down to DC. Understanding all the design-peRFormance cost tradeoffs become increasingly important as the data rates, the pin counts and the power requirements all increase in leading edge designs. |
