查看: 665|回复: 2
老外skillcad_v451
    2024-3-26 15:26
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-10-19 14:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
              需要可自行下载
    Instructions of skillCAD Installation
    i) Download the latest software
    链接:https://pan.baidu.com/s/1koLzbHq1GNal0uIPWf09Qg
    提取码:ctae
    ii) Unpack SKILLCAD
    [size=1.25]%% tar -xvzf skillcad_version.tar.gz
    %% cd skillcad_version
    [size=1.25]You will get four dirs: doc, lic, source, bin.
    iii) Update SKILLCAD_PATH environment variable
    [size=1.25]%% setenv SKILLCAD_PATH $realPath$/skillcad_version
    [size=1.25]This line should be defined in a global .cshrc file.
    If you use a link to the installation dir, update the link to the new dir.
    iv) License
    [size=1.25]Follow the instructions in the license file to activate the SKILLCAD licenses.
    v) Test installation
    [size=1.25]Add the following lines at the end of the .cdsinit file (if they have not been added):
    [size=1.25];******loading SKILLCAD software ******
    when( getShellEnvVar("SKILLCAD_PATH") &&
    isReadable(strcat( getShellEnvVar("SKILLCAD_PATH") "/source/skillcad.il"))
    ick one of the following SKILLCAD Packages for installation
    ;SKILLCAD_PACKAGES = list( "IC Layout" ) ;;Default, for IC Layout Automation Suite
    ;SKILLCAD_PACKAGES = list( "Flat Panel Layout" ) ; for Flat Panel Layout Editor
    ;SKILLCAD_PACKAGES = list( "All" ) ;; all SKILLCAD modules
    load( strcat( getShellEnvVar("SKILLCAD_PATH") "/source/skillcad.il"))
    );when
    [size=1.25]Then start icfb, open any layout cellview, you should see the “SKILLCAD” pulldown menu. Click the “About…” item from this menu, you can see the version information of the skillcad software. Your SKILLCAD software is updated(installed).
    [size=1.25]No extra setup is needed for Flat Panel Layout Editor. For 1st time users of IC Layout Automation Suite, you are encouraged to do SKILLCAD rule setup through pulldown menu “SKILLCAD” “Setup”. Click the “Help” button on the setup form, SKILLCAD reference menu has step by step instructions on setup.
    发表于 2022-10-19 15:25 | 只看该作者
    都有啥功能
    奋斗
    2025-7-7 15:38
  • 签到天数: 83 天
    [LV.6]常住居民II
    发表于 2022-10-19 18:25 | 只看该作者
    这是IC用的SKILL。只画PCB的可以不用下载。
    GMT+8, 2025-8-11 13:37 , Processed in 0.109375 second(s), 23 queries , Gzip On.
