TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
FEATURES K( L$ `8 [* W" [4 \) L
The ZCC66099 is a synchronous step-up converter8 V3 l" Z, g0 J5 Q# V8 y
with 0.65μA ultra low quiescent current. It is designed& k. W b& f1 W7 `; R: a7 |
for products powered by alkaline battery, NiMH1 w# ?0 v7 u5 P
rechargeable battery, Li-Mn battery or rechargeable Li-# M& h: Z! Y/ o% w
Ion battery, for which high efficiency under light load( {) D0 T U$ [9 [' [/ C. A
condition is critical to achieve long battery life operation.
3 j0 C2 u0 i3 k% j6 E& c2 GThe ZCC66099 step-up converter only consumes
3 F7 j% I2 n1 K2 E0.65μA quiescent current under light load condition and
. b/ o5 l' { N5 Y6 h1 K0 Scan achieve up to 75% efficiency at 10μA load with
6 f& `# G0 ^& J2 ]6 s. I& sfixed output voltage version. It can also support up to
, V/ Z' n. M! _4 _ R, h300mA output current from 3.3V to 5V conversion, and* }; J: h& C F c
achieve up to 93% at 200mA load.- s. j3 r/ `4 L! Y3 ^! L
The ZCC66099 also offers both down mode and pass-
% S$ u. O6 P. _1 vthrough operation for different applications. In down( f0 c$ y1 Y- T: F
mode, the output voltage can still be regulated at target
( v+ g7 _$ J2 y1 }7 Nvalue even when input voltage is higher than output( _- m2 {4 ~' A. [3 X4 Z
voltage. In pass-through mode, the output voltage$ V) i0 Z7 d" t5 \9 I8 p/ y- R
follows input voltage. The ZCC66099 exits down mode+ H! X/ R$ ]4 U( k1 @/ o( c6 h! i
and enters into pass-through mode when VIN > VOUT +: E9 w. a9 U( F( z2 p
0.3V." y) j1 V- _ i, u5 L
The ZCC66099 supports true shutdown function when; N% F T4 r4 ~
it is disabled, which disconnects the load from the input
6 F- F3 B+ a) ?supply to reduce the current consumption.
3 V9 b9 z6 F3 i. `6 b. `The ZCC66099 offers both adjustable output voltage$ R' y( s% s3 q$ J- t
version and fixed output voltage versions. It is available. ^7 m1 J6 \1 H, Y8 U% k
in Green WLCSP-1.22×0.83-6B and TDFN-2×2-6AL$ a* s2 M2 O2 k, \: ]
packages.; {) w4 d& n( J9 o
TYPICAL APPLICATION" Z8 z: e$ w+ O0 I U
●Operating Input Voltage Range: 0.9V to 5.2V
8 F3 e, R3 Y: p9 _: I7 X●Ultra Low Quiescent Current6 y9 H4 U2 Q& ]! s8 {; M- P
0.6μA Ultra Low IQ into VOUT Pin( ^$ F: e8 w6 f/ f% V' j
0.05μA Ultra Low IQ into VIN Pin
. s$ M; q* n( K5 m/ V4 v, u# n●1.2MHz Fixed Frequency Operation. h/ j7 J# V( L6 o1 t
●Adjustable Output Voltage from 2.5V to 5.2V
) b" v0 u D6 {! Y1 U$ t" E' [- }" C●Fixed Output Voltage Versions Available
1 R' A! k/ I" u1 ~: m9 B●Power-Save Mode for Improved Efficiency at Low7 P* G: | N( ]) r0 E
Output Power4 `& q6 R5 ~! ?8 s
●Regulated Output Voltage in Down Mode- N9 r- O/ A/ _2 w& q# ^- p0 V; }
●True Disconnection During Shutdown
5 w! J) ?' M+ e3 c# J) M9 b9 P●Up to 75% Efficiency at 10μA Load with Fixed) p) }4 @4 `2 S5 }, N; v5 Q. J
* _- }4 K0 z7 G●Up to 93% Efficiency from 10mA to 300mALoad
. r( m' p: Q! Q$ b●-40℃ to +85℃ Operating Temperature Range) r* i5 y5 H0 ^; g$ J0 q
●Available in Green WLCSP-1.22×0.83-6B and
- i" {) }/ ~8 |4 R' t) tTDFN-2×2-6AL Packages9 w* E6 H- k" [ M3 M. ^; k
APPLICATIONS
$ u* c/ j, ?# y% ?" }Memory LCD Bias
$ p" n% \+ `9 u$ M( v( _Optical Heart Rate Monitor LED Bias
/ G9 O( _4 f4 O0 SWearable Applications
- A; h6 p/ y% }' j$ |& j1 oLow Power Wireless Applications
4 E, f3 `8 ~* p4 E. I( n* hPortable Products9 u1 ^( D$ U O1 G( ?. _6 E+ ^: F
Battery Powered Systems- Q" d+ h/ \3 B; g
3 }" w) L; Q0 v [" ]4 M
