TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
Features9 y+ G! o; ]( \: v% k' G
9V to 100V input voltage range
. m0 z# c0 Z1 u# w9 V: a Q( O 1.5A current limit
2 ^ {+ [( T' X- |! i4 p 1A continuous load current; f* U. t0 J& v! f6 O" n
95% Peak Efficiency
0 z) |+ M* R# {' h 400μA operating quiescent current
, Z" g3 a8 a( {& V. |3 G3 v" ^ 120V 400-mΩ high-side MOSFET
: F( S9 L$ h! x+ I c! _# i2 } e Peak Current mode control
( _& Y! R! R! m' v9 k5 B } 150 kHz Fixed Frequency
; N' Y6 W1 R* ]. l6 q- `! U+ f Internal compensation for ease of use& `- j. M2 r2 r
Up to 92% duty cycle& {) W" y' ?! h% v: _
0.8V voltage reference$ o6 H; \0 J. t/ Q2 f6 g
1μA shutdown current! C5 h- G: u/ W
150ms Hiccup mode short circuit protection. _& z0 f5 b! m; Y9 b* n, P
Function
$ e+ l5 y1 X+ I& ^ Thermal shutdown Function
9 T- k0 }( q6 |1 T4 n/ ~ ESOP-8 package
& H8 d- |. J; s: h4 F* LApplications: B( ^3 m' o( O4 R
Charger in vehicle
+ w* E& {. q d! ~ Battery Chargers
$ Y* T/ U+ `; e" w3 ]8 k) u Power adapter
3 B3 y7 ^0 i zDescription
6 r& h, g6 a4 X% Z' a+ uThe ZCC1001E is a high voltage, non-synchronous4 m: k8 u5 S$ E$ V0 o
step-down converter operates over a wide range
7 Y) R" ~" ^$ i. \; W* A" Sinput voltage 9V to 100V. The ZCC1001E
" f5 @; W8 W6 q- e, D, fintegrates a 120-V 400-mΩ high-side MOSFET.3 L& C$ `/ F. p/ }/ [ |
The ZCC1001E delivers 1A continuous load Z p1 W) l! ] \. E8 Y& B
current with up to 95% efficiency. The ZCC1001E
8 u0 [9 ~0 J2 V) uoperates with fixed frequency peak current control
8 h& W" a, X" P+ i0 a8 owith built-in compensation eliminates the need for6 c# B. z6 J; u
external components.
2 `- u I0 z" m# f8 u5 iCycle-by-cycle current limit in high-side MOSFET/ v: n! [2 p0 G
protects the converter in an overload condition.
) o2 [$ C8 L% n& J$ u8 I+ I+ h \Hiccup mode protection is triggered if the over7 j& u! l: z' G5 p
current condition has persisted for longer than the
& I7 x8 ?/ S. U. w' r3 q/ Lpresent time.
2 ^2 `* X/ G- j0 w% B) FThe ZCC1001E exhibits protection features that
2 Z) z- }& A: U# D- _' a" tprotect the load from faults like under-voltage,: y( L" y6 e6 `; M6 R0 a
over-current and over-temperature.' @* q8 ^+ _* C) _6 s/ a
The ZCC1001E is available in an ESOP-8 package.& w G {( x: x9 S! e( j% v
