在仿真中,首先进行求出反解,然后运行如下程序:
5 M% V( W* s c( t- R; m6 v" M* on=50;rou=300;lamt=2*pi;
# I) ^$ j- y! C& }# W5 ^ SZz=[300 400 500];
: j9 A. k4 L9 X9 l4 M( V: v4 }Rou=rou*(0:n)/n;3 k0 b6 X, P3 @. v- r+ _
Lamt=lamt*(0:n)/n;
; ]) S7 s. G) p3 I[Rou1 Lamt1]=meshgrid(Rou,Lamt);$ V( D! D% h" ?; g# r. Q
Xx=Rou1.*cos(Lamt1);
! x; q3 W" s. q1 a& ?, W) h9 t0 m4 mYy=Rou1.*sin(Lamt1);
) ~) r5 e" s5 ffai1=subs(faii,b,bb);) Q9 r8 D+ U8 n* J# v7 T3 H8 y
for i=1:3
( y( w$ l7 ]5 R% X% R" U- r. g( x$ xz=Zz(i);9 S: [; O! _: p6 D
for j=0:n$ C. p# G2 O2 b' d6 F* G* z
for k=0:n" B, h7 [+ E, @
x=Xx(j+1,k+1);
" k0 u) B' q8 h7 H. T; Z8 k. {1 hy=Yy(j+1,k+1);7 K) S" ?6 X% P
sita1=double(subs(sita,{rx,rz},{x,z}));6 M% b: Y) S6 I R
c21=cos(sita1);
m/ o3 }# L. f4 y% {s21=sin(sita1); [! i0 k" j$ l! X1 ?8 _
fai2=double(subs(fai1,{rx,ry,rz,s2,c2},{x,y,z,s21,c21}));. X& H9 S, J$ N: K) \0 P
c31=cos(fai2);9 Z; h. N* Q* W- g: m
s31=sin(fai2);
: v) T$ W# e& T% ~2 zgang2{i,j+1,k+1}=subs(gang1,{rx,ry,rz,s2,c2,s3,c3},{x,y,z,s21,c21,s31,c31});2 b3 i+ Q: E) a
end( W- n. N% m$ T- T- O
end
) b) F7 Y9 x0 s/ x7 j# Send
2 A$ m) J/ M8 F/ X; [5 }7 z# B$ m! P. Y2 x
根据以上程序的计算结果,运行如下程序:
' ~& O5 T% V/ Afor i=1:3' D* d( D* D ?& ]5 ]) e! m
for j=0:n
! N( ]5 D# J5 D5 ?( a* V1 q, {) ufor k=0:n5 G4 _* c; k* c# V# [
gang11=eigs(gang2{i,j+1,k+1});
# X2 k' }) x, F2 [gang12(j+1,k+1,i)=gang11(6)/gang11(1);
' W8 ?) B. w) ]8 `. m0 n/ A; gend( d$ _1 o7 J) p% d
end' o g1 L7 t6 A
figure(i). Z* p* X, B& K+ P' s
gang12=double(gang12);5 j r/ S* t1 i e
mesh(Xx,Yy,gang12(:,:,i))( ~) c7 u; y! G
end" v7 S3 C2 t- s8 \. Y' g+ D
4 _1 S8 O4 J. ?7 _& X
该程序应该是绘制出三个图形,但是绘制一个图形以后就出现错误,错误如下:- h2 X6 P% J6 j) Q
??? Attempted to access gang11(6); index out of bounds because numel(gang11)=0.
0 h+ W7 U. o. y( n% _; k% h) q; u' a/ k, P% s* i' D
Error in ==> gangdutu at 5' w, T7 \ {( F6 k
6 K7 c: F5 ]8 B5 {! u+ {' p |
