查看: 191|回复: 0
ZCC1001E 100V 1.5A降压芯片
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-9-5 17:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    Features
    . E) `3 R& ]8 p5 T6 P( P 9V to 100V input voltage range' M$ }0 O, l# K1 V  @+ f
     1.5A current limit
    ; w2 H, a4 p, @  z 1A continuous load current
    " K4 Q! T# d) y  Q/ Z3 y 95% Peak Efficiency
    ) |. j. l5 {3 d 400μA operating quiescent current
    6 L9 n8 c) o  {9 G) e6 ^& z% e; V4 h 120V 400-mΩ high-side MOSFET
    " X% b0 r3 g% F, m( k Peak Current mode control4 ~3 P3 Q8 j# j" t2 R' X
     150 kHz Fixed Frequency: b0 r; C# G, @* Y' w! A
     Internal compensation for ease of use+ q- j- F& n7 C/ V5 \$ i& S" n4 e
     Up to 92% duty cycle& q! |8 a% f& }' H, y
     0.8V voltage reference
    ! R4 M+ A$ b9 H$ ^& A 1μA shutdown current
    * J' G! d+ G1 S* J" J- K' c" E0 Q1 f 150ms Hiccup mode short circuit protection5 E: `0 M2 E3 [% G
    Function& t! L1 I0 y" d" w; \
     Thermal shutdown Function
    0 s  W: T* ?, Y" O ESOP-8 package% z# |, I0 q( y# B% \* ^& J) @4 |
    Applications: s: R/ B# l5 s  @1 t, x5 s
     Charger in vehicle
    $ F6 N# L# ~6 {- a$ S, [. R Battery Chargers
    6 _* t4 g; `; } Power adapter) d4 |& v6 ]- u: u3 ~* O* m
    5 ~  w# Z) K& ]) v) `  @/ u3 A, v7 @
    Description
    1 x) h# x, s" A/ k& O& ]The ZCC1001E is a high voltage, non-synchronous: ~5 r9 c  d2 c6 n. z6 ~0 r; Y0 y
    step-down converter operates over a wide range- x+ ^# L; v* V( J' f" ]: m9 V8 l: g
    input voltage 9V to 100V. The ZCC1001E+ r5 T* p. y0 P4 B& ^, B5 _
    integrates a 120-V 400-mΩ high-side MOSFET.
    + j" v  J2 l5 S; x$ VThe ZCC1001E delivers 1A continuous load
    ( E" u; ~3 a$ q7 T4 X' D  P" xcurrent with up to 95% efficiency. The ZCC1001E0 w( U& V% O" U8 v+ b6 @
    operates with fixed frequency peak current control$ J3 ]! x7 W* w% e( L2 e9 t% u
    with built-in compensation eliminates the need for. i' h3 q( A% w
    external components.8 l0 f3 Y3 n' Y) X
    Cycle-by-cycle current limit in high-side MOSFET! q* }! ~6 P7 }
    protects the converter in an overload condition.! D, Q5 C7 X+ D% u0 O
    Hiccup mode protection is triggered if the over
    1 o. P6 e- y% @/ ?/ ]6 bcurrent condition has persisted for longer than the5 Z' p" K1 ]9 r- C! ^
    present time.
    . H9 k+ U3 l. e; R! d/ M, E5 P( z& @  EThe ZCC1001E exhibits protection features that
    6 ]: n& H# p" C* ^protect the load from faults like under-voltage,9 F  t4 m: k8 T( K. ]
    over-current and over-temperature.
    & _) ?& U8 C/ c- c  E6 }$ HThe ZCC1001E is available in an ESOP-8 package.
    2 t6 P9 ?* P4 D! B7 p% _Typical Application
    3 C+ a& y; }# I0 h" I0 v5 ~- ?
    GMT+8, 2025-7-5 23:44 , Processed in 0.109375 second(s), 24 queries , Gzip On.
