查看: 181|回复: 0
[Allegro PCB设计] Wallys// 2×2.4GHz 2x5GHz MT7915 MT7975 WiFi6 MiniPCIe Module 2T2R
    2023-2-7 15:43
    发表于 2022-9-5 13:24 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    MT7915+MT7975 Chipset
    2.4GHz max 23dBm & 5GHz max 20dBm output power
    IEEE 802.11ac / ax compliant & backward compatible with 802.11ax/ac/a/b/g/n
    2×2 2.4G & 2×2 5G  MIMO Technology, up to 1.8Gbps Mini PCI Express edge connector
    SupporttheFrequency2412MHz~2482MHz
    SupporttheFrequency5180MHz~5825MHz
    RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
    Supports Spatial Multiplexing,Cyclic-Delay Diversity (CDD), Low-Density Parity Check  (LDPC) Codes,Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
    Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
    Supports Dynamic Frequency Selection (DFS)
    CardsareindividuallycalibratedforQualityAssurance
    <span]
      Product Description
      DR 7915 based on MT7915 + MT7975 Chipset is an enterprise wireless module integrated with 2x2 2.4G high power Radio module and 2x2 5G high power Radio module designed
      specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment infactories, warehousese stablishment.
      Specifications
      Symbol
      Parameter
      Chipset
      MT7915+MT7975
      Host Interface
      Mini PCI Express 2.1
      Antenna Connector
      2 x UF.L
      Frequency Range
      2.4GHz: 2.412GHz to 2.472GHz
      5GHz: 5.180GHz to 5.825GHz
      Operating Voltage
      3.3V DC
      Power Consumption
      TBD
      Modulation Techniques
      OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM
      Environmental Temperature
      Operating: -40°C to 70°C, Storage: -40°C to 90°C
      Environmental Humidity, non-condensing
      Operating: 5% to 95%, Storage: Max. 90%
      ROHS Compliance
      YES
      Dimensions (W×H×D)
      51mm × 30mm × 5.8mm
      RF Performance Table
      Operating Mode
      Data Rate
      TX Power
      Tolerance
      1 Chain
      2 Chains
      2.4 GHz
      802.11b
      11Mbps
      20dBm
      23dBm
      ±2dB
      2.4 GHz
      802.11g
      54Mbps
      17dBm
      20dBm
      ±2dB
      2.4 GHz
      802.11n HT20
      MCS7
      17dBm
      20dBm
      ±2dB
      2.4 GHz
      802.11n HT40
      MCS7
      14dBm
      17dBm
      ±2dB
      Operating Mode
      Data Rate
      RX Sensitivity
      Tolerance
      2.4 GHz
      802.11b
      11Mbps
      -96dBm
      ±2dB
      2.4 GHz
      802.11g
      54Mbps
      -93dBm
      ±2dB
      2.4 GHz
      802.11n HT20
      MCS7
      -89dBm
      ±2dB
      2.4 GHz
      802.11n HT40
      MCS7
      -86dBm
      ±2dB
      Operating Mode
      Data Rate
      TXPower
      Tolerance
      1 Chain
      2 Chain
         5 GHz
        802.11a
      54Mbps
      17dBm
      20dBm
      ±2dB
         5 GHz
        802.11n/ac HT20
      MCS8
      15dBm
      20dBm
      ±2dB
        5 GHz
        802.11n/ac HT40
      MCS9
      14dBm
      17dBm
      ±2dB
      5 GHz
        802.11n/ac HT80
      MCS9
      11.5dBm
      14.5dBm
      ±2dB
        5 GHz
        802.11n/ac HT20
      MCS9
      17dBm
      20dBm
      ±2dB
        5 GHz
        802.11n/ac HT40
      MCS9
      14dBm
      17dBm
      ±2dB
        5 GHz
        802.11n/ac HT80
      MCS11
      11dBm
      14dBm
      ±2dB
      Stable networks guarantee for the ongoing continuity of your video  surveillance. Our boards could establish a stable connected wireless  environment  which is critical for a security surveillance system.
      Wallys  has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.
      EMAIL:sales@wallystech.com
      WEB:
      https://www.wallystech.com/
      MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/IPQ4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/QCN6024/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882/AR9582/AR9531/AR9344 /AR9342/AX200NGW/QCA9531
    GMT+8, 2025-9-30 11:12 , Processed in 0.140625 second(s), 27 queries , Gzip On.
