SYM_NAME | COMP_DEVICE_TYPE | REFDES |
BATTHOLD-VL1220-1VC | BATTERY_BATTHOLD-VL1220-1VC _BA | BT1 |
BGA5X5-4MM | USB3319_0_BGA5X5-4MM_USB3322 (C | U7 |
BGA515-CBB | OMAP3430_ES2_5.0_BGA515-CBB_OMA | U3 |
BGA-ZXN-209 | TWL4030_6_BGA-ZXN-209_FBGA209_1 | U5 |
C402-25 | CAP_0402_0R1UF_X7R_10V_C402-25_ | C1;C3;C4;C9;C10;C11;C12;C13;C14;C15;C16;C17;C18;C19;C20;C21;
" J& h9 C1 r/ P. c1 D. y1 n7 I6 Y0 p- GC22;C23;C24;C25;C26;C27;C28;C29;C30;C31;C32;C33;C34;C35;C36;
4 X1 Y5 J8 k$ U7 H X8 R$ y! zC37;C38;C39;C40;C41;C42;C43;C46;C50;C64;C65;C73;C78;C84;C99;, a2 Z \6 P0 Y* m4 n7 p
C103;C105;C107;C109;C110;C111;C113;C114;C115;C116;C117;C118;7 ?2 o9 x$ y& z# v, u; o0 u
C119;C120;C121;C122;C123;C124;C125;C126;C129 |
C402-25 | 100NF-16V X7R_2_C402-25_DISCRET | C7;C8 |
C402-25 | CAP_0402_0R1UF_X7R_10V_C402-2_3 | C44;C45 |
C402-25 | 0402_0R01UF_X7R_16V_10_C402-2_1 | C47;C48;C49 |
C402-25 | CAP_207-0009-000_C402-25_DISCRE | C51;C60;C61;C62;C63;C70 |
C402-25 | 0402_0R01UF_X7R_16V_10_C402-25_ | C52;C131;C132 |
C402-25 | 207-0000-075_1UF_C402-25_DISCRE | C55 |
C402-25 | CAPACITOR NON-POL_C402-25_100PF | C58;C59 |
C402-25 | CAP_207-0009-000_C402-25_DISC_1 | C68;C69 |
C402-25 | 207-0000-075_0_C402-25_DISCRETE | C71 |
C402-25 | CAP_0402_0R1UF_X7R_10V_C402-2_1 | C74;C75;C79;C80;C81;C82;C86;C88;C89;C90;C91;C92;C93;C94;C96;C98;C100 |
C402-25 | CAP_0402_0R1UF_X7R_10V_C402-2_4 | C87 |
C402-25 | CAP_0402_0R1UF_X7R_10V_C402-2_2 | C102;C104;C106;C108;C127;C133;C134;C135;C136;C137;C138;C139 |
C402-25RD | 0402C-47P_1_C402-25RD_47PF | C56;C57;C66;C67;C130;C140 |
C0805 | CAP_0402_0R1UF_X7R_10V_C0805_10 | C76;C77;C83;C85;C95;C97 |
C1210-70X102 | 1812-X5R-10V-47UF_C1210-70X102_ | C53;C54 |
C3216-35X55 | 10UF-10V-293D-C_1_C3216-35X55_D | C2;C112;C128 |
C3216-35X55 | 0603C-2U2_0_C3216-35X55_2.2UF,0 | C72 |
C3528-64X112 | CAPCAN | C101 |
CONN2X10-4028 | HEADER 10X2_0_CONN2X10-4028_HEA | J4;J5 |
CONN3-PWR-PJ102A | CONN JACK PWR_1_CONN3-PWR-PJ102 | J1 |
CONN4-DIN-RT | SVIDEOCONN_0_CONN4-DIN-RT_SVIDE | P4 |
CONN-6N1-MMC-SD | MMC4_2.0_CONN_CONN-6N1-MMC-SD_M | P8 |
CUI-SJ1-3513-SMT | PHONOJACK STEREO-R_CUI-SJ1-3513 | P5 6 |
DBV6-27X39-6 | SN74LVC2G07DCKR_DBV6-27X39-6_IC | U4 |
DCU8-10X50 | TXB0102_2_DCU8-10X50_TXS0102 (D | U9;U11 |
DGN-16X60 | TPS2061_2_DGN-16X60_TPS2061 (DG | U6 |
DRB8-14X33-PAD | TPS73701_0_DRB8-14X33-PAD_TPS73 | U2 |
F603-41X39 | DIODE BI-DIR TRIG_F603-41X39_PG | D1 |
F603-41X39 | DIO_V5.5MLA0603_F603-41X39_PGB0 | D2;D3;D4 |
F603-41X39 | DIO_V5.5MLA0603_F603-41X39_DIO_ | D8;D9;D10;D11 |
HDMI-SMT-W-FLANGE | HDMI_CONN_3_HDMI-SMT-W-FLANGE_H | P10 |
IND603-24X32 | INDUCTOR_IND603-24X32_FERRITE, | L4;L5;L6 |
IND-LPS3010 | INDUCTOR 1.0UH_IND-LPS3010_1UH | L2 |
IND-LPS3015 | INDUCTOR 1.0UH_IND-LPS3015_1UH, | L1;L3 |
JUMP2-6040 | JUMPER_0_JUMP2-6040_JUMPER,DNI | J2 |
JUMP2X5-6040 | HEADER 5X2_1_JUMP2X5-6040_HEADE | P9 |
JUMP2X7-6040-K6 | JUMP_0_JUMP2X7-6040-K6_IO_76385 | P2 |
JUMP2X14-6040-1 | HEADER 14X2_JUMP2X14-6040-1_HEA | J3 |
LED1206-59X59 | LED_LTST-C150GKT_0_LED1206-59X5 | D5;D6;D7;D12 |
MH230-156 | TESTPT1_0_MH230-156_MOUNTING HO | MH1;MH2;MH3;MH4 |
PAP64-12X70 | TFP513_1_PAP64-12X70_TFP410 | U8 |
POLYSW200-5638-310 | PTC_POLYSW200-5638-310_RXEF010 | RT1 |
PWP14-12X70 | TPS21XX_1_PWP14-12X70_TPS2141 | U1 |
R402-25RD | RES_0_R402-25RD_DISCRETE_56.2K, | R7 |
R402-25RD | RES_272-0065-000_R402-25RD_DISC | R10;R53 |
R402-25RD | RES_0_R402-25RD_DISCRETE_4.7K_1 | R11;R12;R13;R14;R97;R100 |
R402-25RD | RESISTOR_R402-25RD_10K | R15;R16;R22;R37;R111 |
R402-25RD | RESISTOR_R402-25RD_100K | R17;R18;R19;R20;R21 |
R402-25RD | RES_272-0065-000_R402-25RD__1.6 | R27;R28 |
R402-25RD | RES_0_R402-25RD_DISCRETE_10K_1% | R36;R49;R54;R55;R56;R57;R58;R59;R60;R61;R62;R63;R82;R98;R101;R102;R109 |
R402-25RD | RES_0_R402-25RD_DISCRETE_33_1% | R38;R40;R42 |
R402-25RD | R_R402-25RD_10K | R39 |
R402-25RD | 0402_4R7K_1_R402-25RD_DISCRETE_ | R41;R45;R47 |
R402-25RD | 272-0067-000_0_R402-25RD_DISCRE | R44;R46 |
R402-25RD | RES_0_R402-25RD_DISCRETE_0_1% | R51 |
R402-25RD | RES_0_R402-25RD_DISCRETE_1K_1% | R96;R99 |
R603-35X45 | INDUCTOR_R603-35X45_3.3UH | L7;L8 |
R603-35X45 | RESISTOR_1_R603-35X45_620K,1%,0 | R3 |
R603-35X45 | RESISTOR_2_R603-35X45_200K,1%,0 | R4 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_10K,0 | R5;R30;R31;R112 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_22.6K | R8 |
R603-35X45 | 0805_200_1_V_R603-35X45_330,060 | R9;R34;R35 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_10K_1 | R29;R32;R33;R64;R65;R71;R73;R113 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_0,060 | R43;R66 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_330,0 | R48 |
R603-35X45 | R_R603-35X45_10K,0603 | R50 |
R603-35X45 | 0402_10K_1_R603-35X45_DISCRETE_ | R52 |
R603-35X45 | R_R603-35X45_12K,0603 | R70;R72 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_510_1 | R95 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_1K,06 | R103;R104;R105 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_0,DNI | R106;R107;R108 |
R603-35X45 | RES_0_R603-35X45_DISCRETE_1K,_1 | R110 |
R805-35X60 | RES_0_R805-35X60_DISCRETE_0.1,0 | R6 |
RPAK16-10X25-2HV | RPAK_RPAK16-10X25-2HV_DISCRETE_ | RP1;RP2;RP3;RP4 |
SC88 | RN1907_SC88_RN1907 | Q1 |
SHORT-PAD-SMT | JUMPER_0_SHORT-PAD-SMT_JUMPER,D | J6 |
SW4-6040-PUSH | SW_KT11P2JM_4_SW4-6040-PUSH_DIS | S1;S2 |
TP1-20SMT | TESTPT1_0_TP1-20SMT_TESTPT1 | TP3;TP4;TP7;TP8;TP9;TP10;TP11;TP12;TP13;TP14;TP19;TP20;TP21;TP22;TP23 |
TP1-20SMT | TESTPT1_0_TP1-20SMT_TESTPT2 | TP5;TP6 |
TP1-8040 | TESTPT1_0_TP1-8040_TESTPT1 | TP1;TP2 |
TSSOP16-14X70 | MAX3221_1_TSSOP16-14X70_SN65C32 | U10 |
USB-MINI-SMT-NUM | MINI-USB-AB-SOCKET_1_USB-MINI-S | P1 |
USB_A_SH | CONN_54819-0578_2_USB_A_SH_IO_U | P7 |
XTAL2_FX135 | QUARTZ-32KHZ-CM200S_0_XTAL2_FX1 | Y2 |
XTAL4-47X51-ECXO | OSC_230-0067-000_0_XTAL4-47X5_1 | Y1A |
XTAL4-47X51-ECXO | OSC_230-0067-000_0_XTAL4-47X51- | Y1 |
