要编写一个s函数,有两个输入,三个输出,输入为参考电流Is和电角度angle,输出为三相电流Ia,Ib,Ic,问:
4 G0 B6 v! V, B1、函数的外部使用MUX模块将Is和angle连接起来一同接入s-function函数模块吗?5 C# t1 C; B/ I, U, {; J1 l
2、此函数的s-function parameter怎么设置?(Is和angle外部的子系统计算结果给定)- X. r2 @# D# t3 K( V# I$ Y' Q
3、对于函数程序中的所涉及的五个参数如何声明?(我的这个老说我没定义Is)+ ~# G. W$ b- R9 _5 }# _
function [sys,x0,str,ts] = test_0105(t,x,u,flag,Is,angle)5 X( Z! ?% |; L. S4 ]- G) [8 u
switch flag,0 ~5 G. h$ k! l4 Q I. A6 D
case 0,
. A2 S+ L5 C0 J% y[sys,x0,str,ts,Ia,Ib,Ic]=mdlInitializeSizes;
9 A2 l9 J& U2 P: J# O# I, F% m; m% Scase 1,
9 c0 _ `. S1 j6 @4 wsys=mdlDerivatives(t,x,u);1 u1 f- }2 B, t) u+ D% ]
6 P7 {0 S8 g" T. rcase 2,
0 [7 o6 q/ f. e" X+ psys=mdlUpdate(t,x,u);
8 U% h1 j5 ?2 X2 _
) c0 [5 t$ E6 h9 b/ c/ D% O$ ]case 3,0 g: t$ b U: N
sys=mdlOutputs(t,x,u,Is,angle);
4 N, Y+ D5 p+ ]6 s* K
1 h# ^: K' i6 s2 Xcase 4,
4 L* d" O3 h6 }4 \3 c6 msys=mdlGetTimeOfNextVarHit(t,x,u);' |( H5 I3 f6 Y$ U8 s8 `, i# j' u
case 9,
* s2 ~5 f7 B/ b8 [ k: P) P+ Nsys=mdlTerminate(t,x,u);
; @6 E' j# O$ n$ R* U) {
% e( T! i1 o" [; V# @2 w) Ootherwise& j" X" G6 `; S1 M9 `
error(['Unhandled flag = ',num2str(flag)]);
+ v" B3 a; k$ [" uend7 R; r0 x# y4 N5 E, N2 \! C2 q
function [sys,x0,str,ts,Ia,Ib,Ic]=mdlInitializeSizes
- N9 q( ^; F1 p4 ysizes = simsizes;6 f. ~: H6 B2 b$ | }6 H; Y5 a
sizes.NumContStates = 0;
- j" n( j3 H! I! rsizes.NumDiscStates = 0;" G( d# }9 \7 c: D: n$ ~+ C
sizes.NumOutputs = 3;
0 ?! F" C% ` P! fsizes.NumInputs = 2;& z3 ?; a2 n* \; s1 v3 Y
sizes.DiRFeedthrough = 1;4 j+ U0 H; P, J
sizes.NumSampleTimes = 1; % at least one sample time is needed; h# P+ p3 C# a
sys = simsizes(sizes);6 x) @# b* f" V ^8 H$ U
function [Ia,Ib,Ic]=mdlOutputs(t,x,u,Is,angle)
. Y( ^4 H4 z* X! t. c8 z6 ]pos=angle-floor(angle/2/pi)*2*pi;
6 l2 u. b# j% u& F+ I/ U" ]6 Zif pos<pi/3
5 K0 F; ?- w/ _/ n+ A' U5 y* ?Ia=Is;Ib=-Is;Ic=0;
. M9 f8 Q. E( n9 m/ V" ^! Gelseif pos<2*pi/3& z' Q" ^7 v4 z; m
Ia=Is;Ib=0;Ic=-Is;
: m* \3 K1 |, d( ]8 r5 gelseif pos<pi
, s3 L5 ~; F' @7 f- UIa=0;Ib=Is;Ic=-Is;4 U8 A& l7 w( C" C% c; X {
elseif pos<4*pi/34 y" a$ Z/ M. A z
Ia=-Is;Ib=Is;Ic=0;
9 r( h! Q) I% c& `& Welseif pos<5*pi/37 q' k0 O& `* Y9 I
Ia=-Is;Ib=0;Ic=Is;: x8 {7 r4 A7 I4 T" N. O$ N- `: M
else
2 G, ?, k" g1 u4 z# W3 kIa=0;Ib=-Is;Ic=Is;
) t5 g; z Y4 pend
6 i- |8 W; E V1 u |
