[allegro16.6][8层]HI3518E高清摄像机(AP6214A+ACT8945A)pcb文件
$ k7 g `6 h* @) G7 c. f文件描述: 1. 作品用途:HI3518E高清摄像机 2. 软件版本:allegro16.6 3. 层数:8层 4. 用到的主要芯片: AP6214A+ACT8945A 5. PCB尺寸:1985*1206.77mil
C' y+ T, y5 I* s作品截图如下: 4 Q; z( N+ z4 b; e$ U9 i4 n) _ K
顶层截图: - U! k2 F' H* J+ I: M
' S A1 q9 }1 o9 v
底层截图:
4 w" r- Z& k, ^% Y, f% e
" o2 x* U2 R3 X9 K. R9 y
全部截图: / I- T# n( |/ Y7 V
, Z0 u- L, K/ E7 U: T" Z) h
PCB文件: U# ?5 T" l4 @- g) x. p
* G; Y: Q+ ?' ?+ x" e) _" c
BOM: 8 y; e$ r- S) a: i5 u5 @2 Y3 V$ p$ J
SYM_NAME | COMP_VALUE | REFDES | ACT8945A | ACT8946AQJ202 | U5 | AP6214A | AP6214A | U10 | BATTERY-T01 | BATTERY | U6 | BGA153-20-1414 | H26M78103CCR | U2 | BGA192-26-1515 | HI3518EV200 | U12 | BUZ3-SM-050025F-0304 | BUZZER-5X5 | SP1 | FH26-23S-0_3SHW | FH26-23S-03S | U15 | FPC20_0_5MM | FPC-20 | J1 | HSC0201 | 100nF | C1;C20;C21;C22;C23;C24;C25;C26;C27;C28;C29;C30;C31;C32;C33;C34;C35;C37;C39;C43;C44;C47;C48;C49;C80;C84;C94 | HSC0201 | 100NF | C17;C41;C42;C53;C70;C71;C75;C77;C81;C83;C85;C92;C93;C96;C100;C102;R46;R85 | HSC0201-TA | 1n | C78;C79 | HSC0201-TA | 15p | C87;C88 | HSC0201-TA | 12p | C106;C107 | HSC0201-TA | 10p/NC | C108 | HSC0201-TA | 10p | C110 | HSC0201-TA | 33p | C113 | HSC0201-TB | 1u | C2;C4;C18;C19;C36;C54;C55;C56;C57;C58;C59;C60;C61;C62;C63;C64;C65;C66;C67 | HSC0201-TC | 2.2u | C6;C7;C8;C9;C10;C11;C12;C13;C14;C16;C38;C40;C45;C50;C52;C72;C73;C111;C115;C116;C120 | HSC0402-TC | 4.7u | C3;C5;C15;C46;C74;C76;C117;C118 | HSC0402-TD | 10u | C68;C90;C97;C98;C99;C101 | HSC0603-TC | 22u | C82;C86;C89;C91 | HSCOX-I-PEX | ANT_CON_4 | J3 | HSL1008 | 2.2uH | L1 | HSOT-SC70 | NPN-BEC | Q1 | HSPL0202A | 1u | L2;L4;L5;L6 | HSPL0202B | 2.2u | L3 | HSR0201 | 20K | R44;R59;R124;R125 | HSR0201-TA | 30K | R1;R4;R5;R27;R31;R37;R42 | HSR0201-TA | 100 | R2;R39;R52;R53;R68;R82;R87;R88 | HSR0201-TA | 15K | R3 | HSR0201-TA | 1.5K | R6;R26 | HSR0201-TA | 47K | R7;R8;R9;R10;R11;R12;R13;R14;R15 | HSR0201-TA | 1K | R17;R33;R77;R78;R79;R80;R91;R93;R94;R99;R100;R101 | HSR0201-TA | 33 | R19;R35;R38;R41;R50 | HSR0201-TA | 10 | R22 | HSR0201-TA | 4.7K | R25;R40;R43;R47;R48;R63;R64;R65 | HSR0201-TA | 0 | R28;R30;R32;R36;R51;R84;R90;R106;R107;R108;R109;R110;R112;R114;R117;R118;R119;R120;R121 | HSR0201-TA | 100K | R29 | HSR0201-TA | 10K | R34;R45;R72;R73;R76;R95;R96;R97;R98 | HSR0201-TA | 510 | R49 | HSR0201-TA | 22 | R54;R55;R56;R75;R111;R113;R115;R116;R122 | HSR0201-TA | 0/NC | R57 | HSR0201-TA | 1K/NC | R60 | HSR0201-TA | 10K/NC | R61 | HSR0201-TA | 4.7K/NC | R62;R69 | HSR0201-TA | 1.1K | R92;R102 | LED-2-0603 | BL-BEG301-AB | LED1;LED4 | LED-0402 | LED | LED2;LED3 | MLF6-040-0202L | ESD7184_04D4 | D6 | MLF12A-040-0202L | NLSX5014MUTAG | U7;U8;U9 | MLF12A-050-0302L | TPS62740DSSR | U4 | MLF20-050-0504-MV | SN74CB3Q3245RGY | U3;U13 | RUSB5-065-0805D | 32010181 | J2 | SF2-0101 | 0435003KRHF | F1 | SHEAD-4P-49 | 53398_0471 | J5;J6 | SIP-2P | TSW_102_23_F_S | J4 | SL0402 | BLM15HG102SN1D | LB1;LB2;LB3;LB4;LB5;LB9 | SR0402 | 470K | R16 | SR0402 | 0 | R18;R21;R67 | SR0402 | 1MEG | R20 | SR0402 | 680K | R66 | SR0603 | 270 | R23;R24 | SR0805 | MIC2_A | MIC1 | SRN8-0804 | 33/NC | RN1;RN2;RN3 | STC3528 | 220uF | C95 | STM8L151F3 | STM8L151F3_QFPN20 | U14 | SW4 | 1188E_1K3_V_T_R | S1;S_BT;S_SYS;S_WIFI | SX2-0201B | 32.77K | X4 | SX4-0202 | 24MEG | X2 | SX4-3215 | SG-3030CM-32D768KHZ | X3 | TDFN_8_0_5 | CW2015 | U1 | TP24-SMD | TESTPOINT_SMD_B | RST;TP2;TP3;TP4;TP5;TP6;TP7;TS1 |
* Y4 z) Y' q) h2 g( j2 e |
