SYM_NAME | COMP_DEVICE_TYPE | REFDES |
BATTERY-DM | BAT_2P_0_BATTERY-DM_GOLDEN_CAP | BT1 |
BGA96-32-1609G | NT5CC256M16CP_3_BGA96-32-1609G_ | U19;U26 |
C0402 | CAP NP_C0402_0.01UF | C5;C62;C73;C142;C143;C494;C495;C496;C497;C498;C500;C501;C502 |
C0402 | C_0_C0402_1UF | C7;C8;C9;C24;C25;C34;C59;C157;C158;C159;C160;C161;C162;C163;C164;
! K, @' p: t; YC165;C166;C167;C168;C169;C171;C174;C216;C462;C466 |
C0402 | CAP NP_C0402_1000PF | C15 |
C0402 | C_0_C0402_2.2UF | C17;C21 |
C0402 | C_0_C0402_1NF | C74;C137;C579 |
C0402 | CAP_C0402_0.1UF/25V/NC | C77 |
C0402 | C_2_C0402_10NF | C80 |
C0402 | CAP_C0402_4.7UF/6.3V | C83;C90;C95 |
C0402 | CAP_C0402_27PF/50V | C86;C91 |
C0402 | C_0_C0402_4.7UF | C87;C185;C311;C315;C316 |
C0402 | CAP_C0402_0.1UF/25V | C102;C524;C526 |
C0402 | CAP NP_C0402_100PF/25V-X7R | C108;C508;C584;C585;C586;C587 |
C0402 | C_0_C0402_12PF | C138;C139 |
C0402 | CAP_NP_C0402_1UF | C140 |
C0402 | CAP_NP_C0402_0.01UF | C141 |
C0402 | C_0_C0402_10NF | C211;C225;C227 |
C0402 | C_0_C0402_220PF | C212 |
C0402 | C_0_C0402_NC | C214 |
C0402 | C_0_C0402_100PF | C217 |
C0402 | C_0_C0402_18PF | C219;C220 |
C0402 | C_0_C0402_0.1UF | C226;C231 |
C0402 | C_0_C0402_0.1UF/25V | C232;C233 |
C0402 | CAP NP_C0402_0.1UF | C262;C499 |
C0402 | C_0_C0402_12PF/50V | C467;C488 |
C0402 | C_0_C0402_15PF | C489;C490;C491;C492;C493 |
C0402 | CAP NP_C0402_1UF | C505;C506;C507 |
C0402 | C_6_C0402_0.1UF/25V | C523 |
C0402 | CAP_C0402_1UF/10V | C525 |
C0402 | CAP_C0402_18PF/50V | C567 |
C0603 | C_0_C0603_330NF | C1;C4;C23;C85;C104 |
C0603 | CAP_C0603_4.7UF/25V | C2;C583 |
C0603 | C_0_C0603_10UF | C58;C229;C333 |
C0603 | C_2_C0603_100NF | C79 |
C0603 | C_0_C0603_2.2UF | C206;C207;C208;C209;C228;C581 |
C0603 | C_0_C0603_1UF | C213 |
C0603 | C_0_C0603_0.1UF | C215 |
C0603 | CAP NP_C0603_10UF | C261 |
C0603 | C_6_C0603_4.7UF/25V | C522 |
C0603 | CAP_NP_C0603_10UF | PIC1 IC6 |
C0805 | C_0_C0805_22UF | C66;C70;C72;C198;C199;C201 |
C0805 | C_2_C0805_10UF | C78;C81 |
C0805 | C_0_C0805_22UF/25V | C221;C580 |
C0805 | CAP NP_C0805_10UF | C503 |
C0805 | CAP_C0805_22UF/6.3V | C559;C565;C568 |
C1206 | C_0_C1206_1000PF/2000V | C224 |
C1206 | CAP_C1206_22UF/25V | C515;C553;C554;C557 |
C1206 | C_10_C1206_1NF/2KV | C548;C549;C550;C551 |
CAP6_6SMD | CAP_E_CAP6_6SMD_47UF/100V | C210 |
CAP6_6SMD | CAP_E_CAP6_6SMD_100UF/35V | C222 |
CAP6_6SMD | CAP_E_CAP6_6SMD_220UF | C230 |
CDH3B15 | INDUCTOR_2P_0_CDH3B15_2.2UH | L9 |
CDH4B18 | L_0_CDH4B18_10UH/2A | L12 |
CDH4B18S | L_0_CDH4B18S_2.2UH | L3;L5;L6;L7 |
CDH4B18S | INDUCTOR_2_CDH4B18S_2.2UH | L20 |
CDH5028 | INDUCTOR_2_CDH5028_4.7UH | L18;L19 |
CON-2P-SMD-1_25MM-S | CON-2P_0_CON-2P-SMD-1_25MM-S_CO | J4;J64 |
CON-3P-SMD-1_25MM-S | CON3_CON-3P-SMD-1_25MM-S_CON-3P | J10 |
CON-4P-SMD-1_25MM-S | CON-4P_0_CON-4P-SMD-1_25MM-S_CO | J9;J62 |
CON-8P-SMD-1_25MM-S | CON8_CON-8P-SMD-1_25MM-S_CON8 | J65 |
D1206 | SCH_X1_0_D1206_ZMM5246B | D15 |
DF80-50S-0_5V | CON50_0_DF80-50S-0_5V_DF80-50S- | J7 |
FPC-32P-0_5MM-LV | FPC-32P-0_2.5MM-UP_FPC-32P-0_5M | J1 |
FPC-38P-0_5MM-LV | FPC-38P-0_5MM-LH_FPC-38P-0_5MM- | J63 |
FPC-45P-0_5MM-LV | FPC-45P_FPC-45P-0_5MM-LV_FPC-45 | J6 |
HBGA524-16-2424 | HI3519V101_PER_4_HBGA524-16-242 | U3 |
HOLE_M2_2 | HOLE_HOLE_M2_2_HOLE_M2_2 | M4;M5;M8 |
HOLE_M2_2 | HOLE_HOLE_M2_2_HOLE_M2_2N | M7 |
HOLE_M3_5D2_3 | HOLE_HOLE_M3_5D2_3_HOLE_M3_5D2_ | M3;M6;M11;M12 |
HSC0201 | C_0_HSC0201_1U | C16;C18;C19;C20;C22;C31;C32;C57;C144;C145;C146;C147;C148;C149;
1 k1 K r; t$ \: X! L% F9 i1 CC150;C153;C154;C155;C156;C175;C183;C184;C306;C307;C308;C309;C310;
) n) l/ a$ A' D8 K1 f, NC312;C314;C340;C341;C349;C350;C351 |
HSC0201 | C_0_HSC0201_220NF | C26;C27;C343;C344;C345;C346;C347;C348 |
HSC0201 | C_0_HSC0201_100NF | C28;C29;C33;C38;C39;C40;C42;C55;C538 |
HSC0201 | C_0_HSC0201_2.2U | C30;C313 |
HSC0201 | C_0_HSC0201_1UF | C151 |
HSC0201 | CAP_HSC0201_0.1UF/25V | C234;C235 |
HSL0201-TB | LB_1_HSL0201-TB_LB | LB1;LB4;LB5;LB7;LB8;LB14;LB17;LB18;LB19;LB20;LB21;LB22 |
HSX4-0302 | X_B_3_HSX4-0302_24MHZ | X1 |
L2520 | L_0_L2520_0.47UH | L13 |
LED-0603 | LED_0_LED-0603_LED_GREEN | D12;D14 |
MB6S | MB101_0_MB6S_MB6S | D1;D55 |
MC-146 | CRYSTAL_MC-146_MC-146_32.768K | X4 |
MP8007 | MP8009 | U71 |
PDS5100H | PDS5100H_PDS5100H_PDS5100H | D13;D17;D21;D44;D50;D51 |
POWER_2BIT_5MM_4P | CON4_POWER_2BIT_5MM_4P_CON4 | J66 |
QFN76-BLADE | VRTL8363NB_QFN76_1_QFN76-BLADE_ | U4 |
R0402 | R_0_R0402_0/NC | R2 |
R0402 | R_0_R0402_0 | R4 |
R0402 | R_0_R0402_100 | R7 |
R0402 | R_R0402_NC-0/5% | R9 |
R0402 | R_R0402_24K/1% | R11 |
R0402 | R_R0402_12.7K/1% | R12 |
R0402 | R_0_R0402_28.7 | R13 |
R0402 | R_0_R0402_1K | R14;R108;R164;R183;R184;R187;R236;R239;R243 |
R0402 | R_0_R0402_100K | R16;R21;R40;R67;R1078;R1080 |
R0402 | R_0_R0402_11K | R17;R39 |
R0402 | R_1_R0402_9.09K | R18 |
R0402 | R_0_R0402_33 | R19;R22;R23;R29;R30 |
R0402 | R_0_R0402_1.5K | R20 |
R0402 | R_R0402_4.7K/5% | R28;R953 |
R0402 | R_0_R0402_4.7K | R33;R61;R82;R193;R208;R213;R244;R245;R265 |
R0402 | R_0_R0402_10K | R36;R582;R587;R1084 |
R0402 | R_0_R0402_1MEG | R37 |
R0402 | R_0_R0402_220K | R41 |
R0402 | R_R0402_75/5% | R52;R53;R54;R55;R56;R956;R959;R1094 |
R0402 | R_3_R0402_10K | R59;R68;R70;R75;R76;R78;R80;R155;R1010;R1060;R1065 |
R0402 | R_0_R0402_21.5K | R60 |
R0402 | R_0_R0402_16.9K | R64 |
R0402 | R_GENERIC_0_R0402_33R | R65;R963;R964;R1018;R1022 |
R0402 | R_1_R0402_16.9K | R66 |
R0402 | R_3_R0402_10K/NC | R69;R71;R72;R77;R79;R157;R1061;R1062 |
R0402 | R_0_R0402_15K | R74 |
R0402 | R_0_R0402_604K | R81 |
R0402 | RES_R0402_10R | R84 |
R0402 | R_R0402_100K/NC | R86 |
R0402 | RES_R0402_470K | R87 |
R0402 | R_0_R0402_75 | R89 |
R0402 | RES_R0402_1K | R91;R97;R970;R974 |
R0402 | R_0_R0402_301K | R100;R182 |
R0402 | R_0_R0402_61.9K | R105 |
R0402 | R_R0402_1.5K/5% | R116 |
R0402 | R_R0402_NC-1K/5% | R117;R125 |
R0402 | R_4_R0402_10K | R119 |
R0402 | R_3_R0402_100R | R122 |
R0402 | RES_R0402_0R/NC | R123;R128;R181;R979 |
R0402 | R_R0402_NC-4.7K/5% | R124 |
R0402 | R_0_R0402_12K | R136 |
R0402 | R_0_R0402_240 | R139;R140;R261 |
R0402 | RES_R0402_100R | R147;R150 |
R0402 | R_R0402_10K | R148 |
R0402 | R_0_R0402_200K | R163 |
R0402 | R_6_R0402_680R | R176 |
R0402 | RES_R0402_4.7K | R177;R178;R180 |
R0402 | R_3_R0402_33R | R185 |
R0402 | R_0_R0402_4.7K/NC | R189;R203 |
R0402 | RES_R0402_2.2R | R190;R1023;R1024;R1025;R1026;R1027;R1028;R1029;R1030;R1031;R1032;
A& Q8 R6 X: B4 y. w8 f1 QR1033;R1034;R1035;R1036;R1037 |
R0402 | R_0_R0402_10 | R578;R583 |
R0402 | R_0_R0402_47K | R579;R584 |
R0402 | R_R0402_2.49K/1% | R599 |
R0402 | R_R0402_NC4.7K/5% | R600 |
R0402 | R_R0402_33R | R601;R952;R1015;R1019 |
R0402 | R_R0402_4.7K/NC | R948 |
R0402 | R_R0402_1K/NC | R949;R951 |
R0402 | R_R0402_4.7K | R950;R1059 |
R0402 | R_R0402_4.7K/5%/NC | R954 |
R0402 | R_R0402_100K/5% | R955 |
R0402 | R_GENERIC_0_R0402_33R/NC | R962;R965 |
R0402 | RESISTOR_R0402_100R | R966;R967;R976;R977;R1066;R1067;R1068 |
R0402 | RES_R0402_0R | R980;R981;R982 |
R0402 | R_3_R0402_100R/NC | R991 |
R0402 | R_4_R0402_33R | R992;R993;R994;R995;R996;R997;R998;R999;R1000;R1001;R1002;R1003;% ^4 F" J; e3 M1 g/ t/ `# e
R1004;R1005;R1006;R1007;R1008 |
R0402 | RES_R0402_10K/NC | R1009 |
R0402 | R_R0402_1K | R1016;R1020 |
R0402 | R_GENERIC_0_R0402_1K | R1017;R1021 |
R0402 | R_GENERIC_0_R0402_1K/NC | R1045 |
R0402 | R_R0402_33R/NC | R1057 |
R0402 | R_0_R0402_20 | R1075 |
R0402 | R_0_R0402_24.9K | R1076 |
R0402 | R_0_R0402_1K/NC | R1077 |
R0402 | R_0_R0402_7.5K | R1079 |
R0402 | R_0_R0402_30K | R1081 |
R0402 | R_0_R0402_3K | R1082 |
R0402 | R_0_R0402_NC | R1083 |
R0402 | R_0_R0402_20R | R1085 |
R0402 | R_0_R0402_20K | R1086 |
R0402 | R_0_R0402_100R | R1087 |
R0402 | R_0_R0402_6.8K | R1088 |
R0402 | R_0_R0402_4.99 | R1090 |
R0603 | LED_0_R0603_NC | D47 |
R0603 | R_R0603_470K | R1 |
R0603 | R_R0603_4.7K | R5 |
R0603 | R_0_R0603_300K | R42 |
R0603 | R_R0603_10K | R83 |
R0603 | R_0_R0603_270 | R241 |
R0603 | R_0_R0603_40.2K | R580;R585 |
R0603 | R_0_R0603_13K | R581 |
R0603 | R_0_R0603_7.68K | R586 |
R0603 | R_3_R0603_10K | R1095 |
R0805 | R_R0805_0R | R1058 |
R0805 | R_0_R0805_20K | R1092;R1093 |
R1206 | R_0_R1206_0.1 | R24;R25 |
R1206 | R_R1206_0R/NC | R73;R1096 |
R1206 | RESISTOR_R1206_0R/NC | R179 |
RELAY-G6S-2 | G6S-2_OMRON_12VDC_RELAY-G6S-2_G | RL1 |
RJ45-DIP-LED | RJ45-14P_RJ45-DIP-LED_JACK_RJ45 | J60;J61 |
SMA | DIODE TAZ_1_SMA_SMBJ58A | D52 |
SMB | DIODE TAZ_1_SMB_JT58SB | D10 |
SMB | T2802_0_SMB_JT58SBC | F5 |
SMBF | ESD PGB2010402_SMBF_SM1K40CF | F6;F7;F42 |
SOD123 | DIODE TAZ_1_SOD123_BAV21 | D6 |
SOD123 | DIODE TAZ_1_SOD123_BZT52C20V-7 | D48 |
SOD123 | DIODE TAZ_1_SOD123_BAT46W | D49 |
SOD-323 | DIODE_0_SOD-323_B5817WS | D23;D26 |
SOD-323 | IN4148 | D53;D54 |
SOD-323 | SCH_X1_0_SOD-323_1SS355 | D56 |
SOD-323 | JEB03CX_SOD-323_JEB03CX | F29;F30;F31;F32;F33;F34;F35;F36 |
SOIC8-150_300MIL | NMOS_3_SOIC8-150_300MIL_SI4848D | Q5 |
SOIC8-150_300MIL | ATSHA204A_SOIC8-150_300MIL_ATSH | U8 |
SOIC8-150_300MIL | 24C04A/SO8_0_SOIC8-150_300MIL_E | U65 |
SOT23-5 | STM6825_SOT23-5_STM6825RWY6F/NC | U6 |
SOT23-5 | TPS79301_10_SOT23-5_TPS73615 | U7 |
SOT23-8 | MP2143_SOT23-8_MP2143DJ | U1 |
SOT563 | MP1605_1_SOT563_MP1657 | U63;U64 |
SOT-23 | NMOS-SOT23_0_SOT-23_2N7002 | Q2 |
SOT-23 | 2N1132A_3_SOT-23_2N1132A | Q3 |
SOT-323 | L14P1/TO_0_SOT-323_KTC4075 | Q4 |
STFM24-40-280 | GIGABIT TRANSFORMER_STFM24-40-2 | U68;U69 |
T6PKE-A050BRT01A | T6PKE-A050BRT01A_T6PKE-A050BRT0 | SW1 |
TF0501 | POE13P-12L_3_TF0501_TF0501-2 | T2 |
TSOT23-8 | MP2122 | U5 |
TSOT23-8 | MP2122_1_TSOT23-8_MP2122 | U29 |
TVS0402 | ESD PGB2010402_TVS0402_RLSD92Q0 | F10;F41 |
TVS0402 | ESD PGB2010402_TVS0402_ESD PGB2 | F27;F28;F37;F38 |
TVS0402 | ESD PGB2010402_TVS0402_ESD PG_1 | F43 |
WSON-8L | MX25L25635_6_WSON-8L_W25Q256FVE | U66 |
