查看: 153|回复: 0
ZCC1001E 100V 1.5A降压芯片(1)
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-8-4 18:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    Features
    / @  A! V2 F9 `1 `& q3 b# T7 z 9V to 100V input voltage range
      b/ u3 k) V% E& l7 H2 w; \, p 1.5A current limit  j$ [" r% t5 m- A
     1A continuous load current
    : {7 m. t* u. {$ E$ c 95% Peak Efficiency/ z& p! P0 H4 V0 V
     400μA operating quiescent current
    7 q! H, }/ j4 F% B( Q1 L& x6 V 120V 400-mΩ high-side MOSFET
    / X- {$ S) a$ T Peak Current mode control) `- o" a% ]. i3 e2 R+ \& g
     150 kHz Fixed Frequency
      {* H, _9 j7 ]  |/ h3 F5 p Internal compensation for ease of use/ }2 G# M( `" N  J( X- a6 P" d% |
     Up to 92% duty cycle
    . @# _+ {8 i7 ]6 Z, Z 0.8V voltage reference: }- y& C5 ]" D" i# y
     1μA shutdown current
    1 j/ `  h: L  O2 Z/ {7 I# v) ~ 150ms Hiccup mode short circuit protection 8 J) m/ G: v, E
    Function! G7 W, T0 ~! D- m% ~. ~. [
     Thermal shutdown Function
    # k% l# A$ u/ Y3 b% Z9 n3 V7 O- r- S ESOP-8 package
    , ]# [. s% V) L0 SApplications6 ^& m, R7 c* I, Z2 Z+ D4 a
     Charger in vehicle
    , _) ], }0 B! m% z$ {6 p9 b# n Battery Chargers
    , u1 j( a0 s! _: M5 E  A Power adapter
    $ N: }, b" m0 z6 A1 n- TTypical Application2 I% G6 ~# H  o, c+ F$ B
    Description: _6 A& I, w' M. P; Z( k
    The ZCC1001E is a high voltage, non-synchronous
    + V& b6 j: Z1 C- C4 ^1 Pstep-down converter operates over a wide range
    4 T, X% K/ A# {3 w1 y1 Binput voltage 9V to 100V. The ZCC1001E , ?5 B5 t% A% g4 r* U# A3 C) t
    integrates a 120-V 400-mΩ high-side MOSFET.
    + P# L  a  e8 ?, C, v  mThe ZCC1001E delivers 1A continuous load : G: ^  P; z/ z1 J$ B# V# ^! a2 e  ^
    current with up to 95% efficiency. The ZCC1001E
    6 I! o1 M6 f% K: E& X" H- Moperates with fixed frequency peak current control % I. {& [" _; T# L; L
    with built-in compensation eliminates the need for
    / a" Q0 p7 a) U" m  H6 ~external components.
    ( O- ^2 [5 E; H( I& cCycle-by-cycle current limit in high-side MOSFET # g# w$ l7 D: q) Y, J
    protects the converter in an overload condition. % K4 v1 u4 s( ?. A
    Hiccup mode protection is triggered if the over9 P% _5 e' u9 ~
    current condition has persisted for longer than the , l, b$ z' F2 `2 T* w3 S8 K) }
    present time.  m5 }& b) v2 j) y3 I
    The ZCC1001E exhibits protection features that $ f( E* N2 n' z% g7 N5 f4 b! V( Q
    protect the load from faults like under-voltage,/ l1 x/ i$ k% i
    over-current and over-temperature.
    - U/ C$ d3 j6 o, GThe ZCC1001E is available in an ESOP-8 package" P% w- o" k5 c# K
    ' R. b  F+ `, t5 i8 e
    GMT+8, 2025-7-7 16:57 , Processed in 0.109375 second(s), 24 queries , Gzip On.
