TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
Features
% B0 k! D! v* V: x5 x 9V to 100V input voltage range
- Y3 n6 D5 h- @& o, P 1.5A current limit
* S( ` y8 Y! u. Q+ O$ { 1A continuous load current
. b! V Y9 ` a+ v5 o7 J 95% Peak Efficiency( Y q+ \$ _% K4 P3 P7 K$ u/ e
400μA operating quiescent current$ k0 [7 n4 u/ C! X9 z3 i" T
120V 400-mΩ high-side MOSFET, ?+ b4 Q7 o: F
Peak Current mode control
9 {2 [/ m" t: O z 150 kHz Fixed Frequency9 ^' i. k5 N! R& o% `* R9 c
Internal compensation for ease of use
+ h! `& X, F9 d1 Y F: [' @ A Up to 92% duty cycle4 }. n! S% O' D6 _
0.8V voltage reference
2 W* `* j+ M* A% z0 u 1μA shutdown current
$ `6 Y( g. A$ O/ [& \ 150ms Hiccup mode short circuit protection
6 K: w1 s6 H; {1 hFunction
8 Z q* k: z; |- @ Thermal shutdown Function
9 I0 S [$ L" r ESOP-8 package
$ [2 W& l! O1 z& u4 U3 n8 {Applications) G3 S# b. M& l5 f( I/ O/ P! F5 l
Charger in vehicle
2 r, ~- i7 M$ [7 }' @. L% \ Battery Chargers
4 t& I0 H) a( d6 c& o0 t Power adapter
1 @/ k1 [( O3 a$ J) K& K! Q7 m: i) c* g. R
Description2 i: q) e2 A* h1 m0 _
The ZCC1001E is a high voltage, non-synchronous
; `3 m x0 W4 d8 j5 zstep-down converter operates over a wide range) W& ]! ~# I6 l1 j0 `6 T/ f, e
input voltage 9V to 100V. The ZCC1001E# ~+ s, V& V( G3 y6 F
integrates a 120-V 400-mΩ high-side MOSFET.
( Z* ^% _; ^+ [" e& c1 ^5 i6 Q# {The ZCC1001E delivers 1A continuous load3 b }0 y* F9 S
current with up to 95% efficiency. The ZCC1001E( Z, x; I+ J+ H
operates with fixed frequency peak current control: W# L$ i. |$ T8 E7 M- i
with built-in compensation eliminates the need for
; {6 d5 a6 K' d9 pexternal components.' t0 Q7 q- J$ V3 y5 W
Cycle-by-cycle current limit in high-side MOSFET- O: r- N! O& D. N8 x( H; l
protects the converter in an overload condition.9 h7 Y6 u! F1 O# K( W
Hiccup mode protection is triggered if the over8 @( y, ~8 f2 k y. m C
current condition has persisted for longer than the; O. ?/ D4 k6 K [. k4 x
present time.1 O: H( D3 Q; c# o. r" O8 P+ |. e7 F, G
The ZCC1001E exhibits protection features that! N# z$ i5 T5 ^6 s. W
protect the load from faults like under-voltage,
! A3 B( K: K5 x7 O1 Rover-current and over-temperature.! v& I' m( b( O# t- h8 G& ?
The ZCC1001E is available in an ESOP-8 package.
5 b5 L: |) |* U! u; ]% x8 bTypical Application& A7 A% V4 l9 H
$ G0 ?! b! |2 N! K, k4 n ]2 Q
