要把从pads2005导出的ASC文件导入POWER PCB5.0时,出现如下错误:: R. g; Z8 U# X9 M) b* I+ J
Fatal Data Base Error Number 1408 . W9 _8 Z& S) {# |& F* |Width is out of range ' i9 q* \+ c' G0 K
actual value:72835632 , `, z) v! x% aShould be between 0 and 1905000 7 M1 O. h F$ \ z; `- |
从PADS2005导出时也有警告:3 _% e+ I/ m" a; D
System font was skipped in one or more text objects because this property isn't supported in the selected ASCII format* B7 J3 k& q) P
各位高手怎么解决这个问题呀
