第一部分 应用...................................................................................1
" v3 a6 U! p. U. rLDO 的分析与设计............................................................................................................................................ 1
u8 R# Z+ h' y3 l. I. eLDO 芯片的特点................................................................................................................................................ 1" F/ [% s) L5 ?% Q! K: ?9 F" ^
LDO 芯片的详细性能参数................................................................................................................................ 1) g% R8 G/ [) p; a$ q
第二部分 电路设计报告...................................................................5
) s( b4 ?; p" A9 U& O4 U整体电路上电启动模块 ..................................................................................................................................... 5
- R x1 H- `% X* l* c C+ G1 m电流偏置模块 ..................................................................................................................................................... 7' w5 x- b% _2 ~$ ^
带有修调功能的基准模块 ................................................................................................................................114 N, z3 d* U% }% E
带隙基准源的修调电路设计 ........................................................................................................................... 21" D, s, w3 \" M% Q$ Z$ e( g
预调整放大器模块 ........................................................................................................................................... 23& _( p2 e5 C+ O. ]3 B$ u* K! P
低通滤波器模块 ............................................................................................................................................... 27; M5 K1 N, _" K/ S
保护电路模块 ................................................................................................................................................... 31
" U- S: ^$ z8 U9 I% T5 k电压跟随器模块 ............................................................................................................................................... 398 W0 E( B$ C, A0 j S( c6 ]
第三部分 总体电路的仿真 ............................................................43+ x9 a/ }2 } e3 N7 z
直流参数........................................................................................................................................................... 441 G& u! ?* k5 R8 D% m
线性调整率....................................................................................................................................................... 45
3 s1 P W. h/ {& ]$ X0 b& W1 g; X负载调整率....................................................................................................................................................... 46
( W2 x1 `2 U; ^7 v9 @静态电流........................................................................................................................................................... 46
% ~4 q. O. Y$ C+ w6 V3 T瞬态仿真........................................................................................................................................................... 47& J6 _! U$ _# m% p9 S4 `9 m! R
噪声仿真........................................................................................................................................................... 480 F. r, g7 W3 n+ A1 @
交流特性仿真 ................................................................................................................................................... 493 E9 q$ Z3 P) w- P! H
PSRR 特性仿真 ................................................................................................................................................ 52
0 X* O7 Z$ m* n第四部分 LDO 芯片版图设计.......................................................56
4 h$ b D) U% J& t# g
3 I4 e6 b" m( V- Q8 \第一部分 应用: Y' q9 T G; M! b7 z: M
LDO 的分析与设计
' m) Y8 _, @; h5 M; i! S; ~4 O( s本论文完成了一种应用于集成于射频芯片的LDO的分析与设计。本文主要从稳定性、负载瞬态响应、电源抑制比和噪声四个方面进行了分析。然后,采用SMIC 0.18μm CMOS工艺完成了包括功率调整管、电阻反馈网络和误差放大器三个部分的电路设计,并用cadence SPECtre对设计的整体电路进行了仿真和优化,最终实现电路的设计要求,而且可以在片内集成。可在0.1mA~300mA的负载电流范围内稳定工作,电路正常工作时温度范围:-55℃~+125℃,该电路工作电压范围为2.1~3.6V,输出电压1.8V,输出电压在全范围的波动:≤4mV,输出电压准精度:≤10mV,最小压差在300mV以下,静态电流≤60uA;在10Hz~100KHz范围内的内部输出噪声积分约为,≤20μVRMS@20mA、≤50μVRMS@80mA、≤100μVRMS @300mA;电源抑制比(PSRR,在10KHZ以下):≥60dB@20mA、≥60dB@80mA、≥60dB@300mA;线性调整率:≤0.1%;负载调整率:≤1%;启动时间:≤100us;电压瞬态响应:≤30us;负载瞬态响应:≤50us;输出启动电压过冲:≤100mV;集成输入欠压过压保护、输出断路保护。另外集成过温保护以及输入软启动电路。' q& l' H) {9 G
& L; L. w& M f( U ~LDO 芯片的特点
6 m: {$ n1 p/ v. j. X. i* G4 _●低静态电流
# _; z5 g" M6 h5 P" d5 x/ C. t●0.1mA~300mA的负载电流范围内稳定工作,带载能力强
+ d2 ~% F, y' Q6 u1 V●在10Hz~100KHz范围内的内部输出噪声小5 B/ n% } C* J2 e8 P
●高电源抑制比(PSRR,在100KHZ以下)' S* H% {9 w+ ^
●可全片内集成; _+ R( g9 H$ U9 v1 `- [; Y
+ v2 Y3 ~1 k C. O0 S! u6 bLDO 芯片的详细性能参数/ p# ]1 i2 v0 c' N
下面将集中讲述一下此次芯片电路设计应该满足的条件,以便于在电路设计过程中有一个总体的设计框架和设计思路。
% y- t; Y+ \" b' x( C衡量LDO的性能参数较多,下面介绍主要的几种性能参数。从对这些性能的分析过程中,可以看到各个性能之间不是独立的,性能和性能之间会相互影响和制约。因此,在设计时,要根据具体要求来具体分析。" Q/ p5 V7 J7 _
1)电压差(Dropout Voltage) 1 ^4 N# @0 w' n$ ]+ a6 ]7 i
当输入电压下降时,输出电压不能再恒定在预定的值,这时的输入电压与预定的输出电压的差值就是电压差。在实际设计LDO时,为了达到更高的效率,常常希望电压差越小越好。一般通过增大功率调整管的尺寸,就可以使电压差减小。但是调整管尺寸的增大,会对稳定性、负载瞬态响应及电源抑制等性能有很大影响。因此,在设计时,需要根据具体要求来具体分析。. X. f5 _3 @$ Q' w+ H. M
2)静态电流(Quiescent current) $ g! F: [4 q. W: m* v+ N! z0 R$ [
静态电流也叫接地电流,是LDO内部电路所消耗的电流,等于输入电流与负载电流的差值"低的静态电流能提高LDO的效率,延长电池的使用时间。静态电流包括带隙基准电压源和误差放大器消耗的电流,及调整管通过采样电阻网络到地的漏电流。对于用MOS晶体管做功率调整管的LDO,由于MOS是电压控制器件,因此它的静态电流与负载电流无关。
/ _$ L. W b1 N' D: p9 |9 A' L' X* @
. q; W4 M+ C# T# B" Z
