查看: 144|回复: 0
同步升压双节锂电池充电芯片ZCC6982
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-6-24 17:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    特性
    # g/ A  x4 `: S# }5 y7 b■ 3.0V to 5.5V Operating Input Voltage- F) K/ n) s! J! e9 ?; Q, f$ I
    ■ Up to 26V Sustainable Voltage
    9 K# m) Q4 ^, i4 F■ Up to 2A Configurable Charge Current for Battery
    ! @3 \1 C& E8 ?4 Pwith 2 Cells in Series
    # _, i/ o: u# ?# P: w) G$ b8 {$ X■ Configurable Input Voltage Limit4 O2 Z0 q; G- F! G) E
    ■ Charge Status Indication
    + w/ {% P5 Q. T4 y( l# r0 T■ Constant Voltage Selectable- o$ [  N& c# J$ J$ k5 t
    ■ Programmable Charge Timeout9 s, w3 G' R4 I7 k3 I/ n
    ■ Thermal Regulation Protection& T3 i9 X! A9 h/ L7 S
    ■ External Shutdown Function
    ) z+ R6 d2 D2 b■ Input Voltage UVLO and OVP
      r- S9 p0 k- e* k( z8 k$ E" n3 j■ Over Temperature Protection2 h# L0 i& A# x' B7 K0 P
    ■ Output Short Cir cuit Protec tion Normal
    ' e8 {$ s# ?# j  T& m( |/ m; {Synchronous Boost Operation When Battery" E. Z" p3 K/ P9 u0 {' N6 r" u% ~  @
    Removed
    # W. l' s2 d' f/ z& r! _+ h应用" J- g3 v$ \  e% }) v/ H4 z$ z9 z0 c) H
    ■ Power Bank5 j* e6 Z* t) P. a
    ■ Cellular Telephones,MP3Players,MP4 Players
    3 P9 A) ]/ ]% f" r) V( `5 Y! p6 @■ PSP Game Players,NDS game Players
    5 \2 r. K+ `/ X■ Notebook% j8 }6 O! z2 ?: ?! U
    描述
    9 T% I, k) E" \ZCC6982 is a highly integrated synchronous boost6 c, r: d+ G% y! }# s4 B/ _
    charger IC for Lithium-ion batteries with four cells in
    ' T7 K$ M+ B, ~  qseries . The charge current up to 2A can be& Y4 n. i7 L! ^; h# S8 X
    programmed by using the external resistor for different
    ( _. ~2 u  t) [' ~0 ~portable applications.$ Y8 V; b2 b, @/ u, B* y
    Robust protections include input over-voltage
    4 n& J$ E9 U/ f  ~protection (OVP), battery OVP, battery short protection,; Y$ D9 D* A6 k# A- I; k
    thermal shut down, battery temperature monitor, a
    6 l0 j5 M( t. s4 X; `3 j. wconfigurable timer to prevent prolonged charging of a
    , |5 x' q0 e& v+ C2 t. d2 [3 mdead battery.
    - y9 J5 u! v$ L. B% E6 m
    - s, ]0 M3 h0 x" u
    [url=]使用特权[/url]
    [url=]更多操作[/url], l3 B- ]' `3 w6 p3 Q6 G6 y! F
    1 B( f1 ^! X& {# \( }( Y
      ~% k- v  p* B) W1 w6 J* l# e7 r* S8 f+ M1 U5 _8 \" t3 l
    GMT+8, 2025-7-6 15:16 , Processed in 0.109375 second(s), 24 queries , Gzip On.
