SYM_NAME | COMP_DEVICE_TYPE | REFDES |
1SMB5920BT3 | 1SMB5920BT3G-6_2V_1SMB5920BT3_O | ZD3 |
156-1001000901 | SD_HSMMC_TAISOL_4_156-100100090 | CON8;CON12;CON13 |
A2-4PA-2_54DSA | A2-4PA-2_54DSA-MALE_A2-4PA-2_54 | J4 |
A2-6PA-2_54DSA | A2-6PA-2_54DSA-6P-2_54-MALE_A2- | J1 |
A3B-12PA-2DSA | A3B-12PA-2DSA_A3B-12PA-2DSA_A3B | CON16 |
A4B-2PA-2DSA | A4B-2PA-2DSA_A4B-2PA-2DSA_A4B-2 | JP1;JP2;JP3;JP4;JP5;JP6;JP7;JP8;JP9;JP10;JP11;6 m0 E, Z4 c$ L4 B, X3 p
JP12;JP13;JP14;JP15;JP16;JP17;JP18;JP19;JP20;
0 L" O1 F1 y* R9 d% ]+ G4 LJP21;JP22;JP23;JP24;JP25;JP26;JP27;JP28;JP29;" ]! t4 s, l! _" e; t
JP30;JP31;JP32;JP33;JP34;JP35 |
A4B-3PA-2DSA | A4B-3PA-2DSA_A4B-3PA-2DSA_A4B-3 | J2;J3;J5 |
A4B-5PA-2DSA | A3B-10PA-2DSA_2_A4B-5PA-2DSA_A4 | CON9;CON10;CON11 |
AXK8L24125B | AXK8L20125B_HEADER_0_AXK8L24125 | CON6 |
AXT634124 | AXT634124_AXT634124_AXT634124AW | CON7 |
B320 | B320_0_B320_B320A | D1 |
BEAD1608 | BLM18BPG121_BEAD1608_BLM18PG121 | FB1;FB2;FB3 |
BGA60_W9_0X11_0_P0_8_PAD0_4 | K4T1G084QQ-HCE6-DDR2_BGA60_W9_0 | U51;U52;U53;U54 |
BGA68_W11_0X18_0_P0_8_PAD0_45 | K4T2G084QA-HCE6_0_BGA68_W11_0X1 | U47;U48;U49;U50 |
BGA584_W35_0_P0_65_PAD0_35 | S5PV210_3_BGA584_W35_0_P0_65_PA | U55 |
C1005 | C1005_C1005_1.8NF | C1;CB172 |
C1005 | C1005_C1005_47PF | C2 |
C1005 | SMALL CAP_C1005_100NF | C3 |
C1005 | C1005_C1005_1UF | C4 |
C1005 | C1005_C1005_1UF/6V | C5;C6 |
C1005 | C1005_C1005_22PF | C16;C35;C36;C37;C38;C39;C40;C41;C42;C49;C56 |
C1005 | C1005_C1005_100NF | C24;C45;C51;C55;CB1;CB2;CB3;CB4;CB5;CB7;CB8;8 g/ _, \) X9 \1 K& D
CB9;CB10;CB11;CB12;CB13;CB14;CB15;CB16;CB17;. k# q/ t& h$ o8 ~; C
CB19;CB20;CB21;CB22;CB23;CB24;CB25;CB26;CB27; ?. R5 T# Q0 @/ w1 {
CB28;CB31;CB32;CB33;CB34;CB35;CB36;CB37;CB38;4 ?% S1 i+ Y/ l. m1 ~ k
CB39;CB40;CB41;CB42;CB43;CB44;CB45;CB46;CB47;
, l. p% a! c5 ^9 }6 u+ d$ N- NCB50;CB51;CB52;CB55;CB56;CB59;CB60;CB61;CB62;/ x2 B" l4 i1 e8 V, c* {' u3 ?, n1 g
CB63;CB64;CB67;CB68;CB71;CB72;CB73;CB74;CB75;/ d0 Z3 L: p) y
CB76;CB79;CB80;CB83;CB84;CB85;CB86;CB87;CB88;
, ~& P, [% I" y# a$ m8 `CB91;CB92;CB95;CB96;CB97;CB98;CB99;CB100;CB101;
( g+ A* Y2 i# G6 @9 G, O/ pCB102;CB105;CB108;CB109;CB117;CB118;CB120;CB121;1 F$ A: N6 d) f4 |" }4 R& X8 f
CB122;CB123;CB124;CB126;CB127;CB128;CB129;CB130;
. _+ t* Y. B; A3 R. B& lCB131;CB132;CB133;CB134;CB135;CB137;CB139;CB141;
6 `& y' f5 r8 Q RCB142;CB143;CB144;CB145;CB146;CB147;CB148;CB149;
* e0 l1 u' `/ u f$ j$ hCB150;CB151;CB152;CB153;CB161;CB166;CB170 |
C1005 | C1005_C1005_1NF | C34;CB53;CB54;CB57;CB58;CB65;CB66;CB69;CB70;CB77;' `6 a9 l2 O# b" Z! @& t5 H
CB78;CB81;CB82;CB89;CB90;CB93;CB94;CB103;CB104;
+ `" f: b* A: F( H4 cCB110;CB111;CB116;CB119;CB136;CB138;CB140;CB156;8 i+ z+ N3 [- ~& U9 v2 M: [3 K1 }
CB157;CB167;CB168 |
C1005 | CAP_0_C1005_100NF | C50;CT1 |
C1005 | C1005_C1005_470PF | C54 |
C1005 | C1608_C1005_100NF | CB29;CB48 |
C1005 | C1005_C1005_2NF | CB169 |
C1608 | C1005_C1608_4.7UF/X5R | C7;C8;C9;C10;C11;C13;C17;C18;C19;C20;C21;C22;C23;% j& D) k2 U$ K1 z/ v+ T0 A5 m& Z
C25;C26;C27;C28;C29;C30;C31;C32;C33;C43;C44;C52;C53 |
C1608 | C1608_C1608_100NF/C1608 | CB18;CB30;CB49 |
C2012 | C2012_C2012_22UF,6.3V | C46;C47;C48 |
C3216 | C3216_1_C3216_2.2UF/50V | CB6 |
CDRH6D28 | CDRH6D28_0_CDRH6D28_CDRH6D28 (1 | L12 |
CH-308 | CRYSTAL_CH-308_CH-308_32.768KHZ | X3 |
COIL_1005 | INDUCTOR_COIL_1005_BLM15HD102SN | L3;L4;L5 |
COIL_3225 | LQH32C_0_COIL_3225_22UH (LQH32C | L1 |
COIL_3225 | LQH32C_0_COIL_3225_1UH (LQH32CN | L2 |
COIL_3225 | LQH32C_0_COIL_3225_2.2UH (LQH_1 | L6;L8;L13 |
COIL_3225 | LQH32C_0_COIL_3225_2.2UH (LQH32 | L9;L10;L11 |
DC-JACK | POWER JACK_0_DC-JACK_POWER JACK | JACK1 |
FUSE3225 | FUSE_MICROSMD150-2_FUSE3225_MIC | F1 |
GF056-60S-LSS-P2000 | CON60_GF056_GF056-60S-LSS-P2000 | M1 |
HIF3F-20PA-2_54DS | HIF3F-20PA-2_54DS_HIF3F-20PA-2_ | CON15 |
KHS02 | SW-SLIDE2_KHS02_KHS02_KHS02 | CFG1 |
KHS02 | SW-SLIDE2_KHS02_SW-DIP2 | CFG2 |
KHS06 | SW-SLIDE6_KHS06_KHS06_KHS06 | CFG3;CFG4 |
LED-2012 | LED-RED_SMD_LED-2012_LED-BLUE ( | LED1;LED2;LED3 |
LED-2012 | LED-RED_SMD_1_LED-2012_LED-RED | LED4 |
LED-2012 | LED-RED_SMD_1_LED-2012_LED-GREE | LED5 |
LM2832XMY | LM2832XMY_LM2832XMY_LM2832XMY | U39 |
LT3591EDDB | LT3591EDDB_1_LT3591EDDB_LT3591E | U2 |
LTC3872 | LTC3872ETS8_LTC3872_LTC3872ETS8 | U3 |
MAX8698C | MAX8698C_0_MAX8698C_MAX8698C | U33 |
MBRS320T3 | MBRS320T3_MBRS320T3_MBRS320T3 | ZD2 |
MD60-19P | MD60-19P_1_MD60-19P_MD60-19P | CON3 |
MSOP08P-0_65-3X3 | PCA9517DGK_0_MSOP08P-0_65-3X3_1 | U5 |
MSOP08P-0_65-3X3 | PCA9517DGK_0_MSOP08P-0_65-3X3_P | U14 |
QSE-020-01-X-D-A | QSE-020-01-L-D-A_0_QSE-020-01-X | CON1;CON2 |
QSH-030-01-F-D-A | QSH-030-01-F-D-A_0_QSH-030-01-F | CON14 |
QSS-075-01-F-D-A | QSS-075-01-F-D-A_4_QSS-075-01-F | JB1;JB2 |
R1005 | R1005_0_R1005_100K | R1;R3;R5;R26;R82;R84;R86;R93;R96;R108;R127;R128;
/ J% [. X( ^& f' @R129;R130;R131;R138;R140;R147;R159;R161;R173;R268;
* T; A' O7 x# J. K z7 WR270;R271;R272;R273;R274;R275;R277 |
R1005 | R1005_0_R1005_0 | R2;R7;R9;R10;R11;R12;R19;R20;R23;R24;R27;R34;R35;
: J/ `3 K( T" j; KR49;R53;R54;R58;R59;R62;R64;R85;R95;R109;R121;R122;
7 U% w1 M5 G3 |9 yR123;R124;R126;R132;R133;R134;R135;R136;R139;R141;
; v5 E& L" a0 U7 @R143;R155;R170;R180;R183;R185;R186;R188;R192;R197;
2 }) k& |* V2 L8 YR200;R211;R223;R233;R257;R258;R260;R276 |
R1005 | R1005_0_R1005_10 | R4 |
R1005 | RESISTER_0_R1005_100K | R6 |
R1005 | RESISTER_0_R1005_17.4K, 1% | R8 |
R1005 | RESISTER_0_R1005_10K/1% | R13 |
R1005 | R1005_0_R1005_NC | R14;R15;R17;R18;R30;R32;R36;R40;R47;R50;R51;R57;: K: ]) z7 O2 G3 a& U- q1 X
R111;R112;R113;R114;R115;R116;R117;R118;R120;R125;
0 r2 w) g$ B& w$ E% BR137;R144;R145;R146;R148;R149;R152;R153;R154;R157;+ x4 m% N$ y* L+ T
R160;R269 |
R1005 | RESISTER_0_R1005_40.2K/1% | R16 |
R1005 | R1005_0_R1005_4.7K | R21;R22;R33;R263;R264;R265;R266;R267 |
R1005 | R1005_0_R1005_44.2/1% | R25;R39 |
R1005 | R1005_0_R1005_1K | R28;R29;R83;R94;R107;R210;R278;R279;R282;R283 |
R1005 | R1005_0_R1005_10K | R31;R52;R79;R89;R100;R240;R250 |
R1005 | RESISTOR_R1005_0 | R37;R45 |
R1005 | RESISTOR_R1005_10K | R38 |
R1005 | R1005_0_R1005_20K | R41 |
R1005 | RESISTOR_R1005_NC | R42 |
R1005 | RESISTOR_R1005_1.8K | R43 |
R1005 | R_R1005_NC | R44;R46 |
R1005 | R_R1005_0 | R48;R55;R56 |
R1005 | R1608_R1005_249K | R66 |
R1005 | R1608_R1005_68K | R67 |
R1005 | R1608_R1005_150K,1% | R70 |
R1005 | R1608_R1005_100K/1% | R71 |
R1005 | R1005_0_R1005_330 | R72;R92;R106;R172 |
R1005 | R1005_0_R1005_51K | R73;R74;R75;R76;R77;R78;R80;R81;R87;R88;R90;R91;& x! P! {6 ?/ W5 H/ u* m
R97;R98;R99;R101;R102;R103;R104;R105 |
R1005 | R1608_R1005_100K | R110;R163;R166 |
R1005 | R_0_R1005_NC | R119 |
R1005 | R1005_0_R1005_10K/R1005 | R142 |
R1005 | R1005_0_R1005_5.1M | R150;R151;R158 |
R1005 | R1005_0_R1005_10M | R156 |
R1005 | R1005_0_R1005_20K,1% | R162 |
R1005 | R1005_0_R1005_10K,1% | R164 |
R1005 | R1005_0_R1005_510 | R171 |
R1005 | RESISTOR_1_R1005_47K | R176 |
R1005 | RESISTOR_1_R1005_10K | R177;R179 |
R1005 | RESISTOR_1_R1005_12.7K | R178 |
R1005 | R_R1005_240K | R230 |
R1005 | R_R1005_300K | R232 |
R1005 | R1005_0_R1005_10K/1% | R236;R237;R238;R239;R242;R243;R244;R245;R246;R247;
- q) K+ K6 ~8 u5 z, L6 TR248;R249;R252;R253;R254;R255 |
R1005 | R1005_0_R1005_10K/NC | R241;R251 |
R1005 | R1005_0_R1005_1.2K/1% | R256 |
R1005 | R1005_0_R1005_75/1% | R262 |
R1005 | R1005_0_R1005_1.8K | R280;R281 |
R1608 | R1608_R1608_100K,1%/R1608 | R60;R65;R167 |
R1608 | R1608_R1608_20K,1%/R1608 | R61;R169 |
R1608 | R1608_R1608_44.2K,1%/R1608 | R63;R165 |
R1608 | R_R1608_0/1608 | R68 |
R1608 | R1608_R1608_91K,1%/R1608 | R168 |
R1608 | R1005_0_R1608_453K,1%/R1608 | R174 |
R1608 | R1005_0_R1608_100K,1%/R1608 | R175 |
R1608 | R1005_0_R1608_NC/R1608 | R181;R182;R184;R187;R189;R190;R191;R193;R194;R195;" Z' V h) a1 A( u* h7 e
R196;R198;R199;R201;R202;R203;R204;R205;R206;R207;
" {# r) Q+ o4 f# _R208;R209;R212;R213;R215;R216;R217;R220;R221;R222;2 X! h" `) b+ ?" M- g4 f
R224;R225;R226;R228;R229;R231;R235;R285 |
R1608 | R1005_0_R1608_0/R1608 | R227;R234;R284 |
R-AR4 | RP_0_R-AR4_0 | RA1;RA2;RA3;RA4;RA5 |
RB414-IV02N | BATT_2_RB414-IV02N_RB414_IV02N( | BAT1 |
SCO-103 | OSCILLATOR_SMD_SCO-103_SCO-103_ | OSC1 |
SOP8_W6_0_E1_27 | LP3962_EMP_0_SOP8_W6_0_E1_27_SI | U4 |
SOP8_W6_0_E1_27 | MAX1818EUT33_0_SOP8_W6_0_E1_27_ | U16;U41 |
SOP8_W6_0_E1_27 | SI4423DY_SOP8_W6_0_E1_27_SI4423 | U43 |
SOP24P-0_4-5X4_4 | SN74AVC8T245-DGV_3_SOP24P-0_4-5 | U1 |
SOT23 | MOSFET P DGS_2_SOT23_FDV301N | Q1 |
SOT23 | IRF4905/TO_0_SOT23_SI2333DS | Q2;Q3;Q4;Q5 |
SOT23-5 | SN74LVC1G04DBV_2_SOT23-5_SN74LV | U10;U34;U36 |
SOT23-5 | TPS2051BDBV_0_SOT23-5_TPS2051BD | U11;U13 |
SOT23-5 | LTC3406ES5_SOT23-5_LTC3406ES5 | U18;U21;U42 |
SOT23-5 | LTC3406ES5_0_SOT23-5_MIC5319-3. | U19;U37 |
SOT23-5 | 54ALS32/LCC_1_SOT23-5_74LVC1G32 | U22;U23;U24 |
SOT23-5 | SN74LVC1G08DBV_SOT23-5_SN74LVC1 | U30;U38 |
SOT23-5 | MAX6458_SOT23-5_MAX6458 | U44 |
SOT23-5 | LTC3406ES5_1_SOT23-5_MIC5219BM5 | U46 |
SOT23-6 | NDC7002N_SOT23-6_NDC7002N | Q-1 |
SOT23-6 | MAX1818EUT33_SOT23-6_MAX1818EUT | U17;U40 |
SOT23-6 | SN74LVC1G11DBV_SOT23-6_SN74LVC1 | U29;U31 |
SOT23-6 | MAX16054AZT_SOT23-6_MAX16054AZT | U35 |
SOT-523 | RCLAMP0502B_SOT-523_RCLAMP0502B | U6;U7;U8;U9 |
SOT-523_BEC | SDMP0340LT_SOT-523_BEC_SDMP0340 | U12 |
SW-TACT-1105SMD-4_3MM | SW-TACT_SW-TACT-1105SMD-4_3MM_S | SW1 |
SW-TACT-1105SMD-4_3MM | SW-TACT_SW-TACT-1105SMD-4_3MM_1 | SW2;SW3 |
SX-8 | CRYSTAL_SX-8_SX-8_24MHZ (SMD,SX | X1;X2 |
SX-8 | CRYSTAL_SX-8_SX-8_27MHZ (SMD,SX | X4 |
T2012 | CT2012_0_T2012_10UF/6.3V | C14;CTB4;CTB5;CTB8;CTB9;CTB14;CTB15;CTB16;CTB17;+ g2 Q2 j+ Y3 ?) \- P
CTB18;CTB25;CTB28;CTB29;CTB31;CTB32;CTB35;CTB36;
% A' T5 [- \7 G, v) G* yCTB37;CTB38;CTB39;CTB40;CTB41;CTB42;CTB44;CTB46;
" q, n$ P0 Z4 k. Y7 k8 JCTB48;CTB69;CTB71;CTB72 |
T2012 | CT2012_T2012_10UF/6.3V | CT2;CTB20;CTB22;CTB24 |
T2012 | CT2012_0_T2012_10UF/10V | CTB1;CTB2;CTB3;CTB6;CTB10;CTB11;CTB12;CTB13;CTB26;
. o* i( i, E. P8 fCTB27;CTB30;CTB33 |
T2012 | CT2012_0_T2012_1UF/6.3V | CTB19;CTB23 |
T2012 | CT2012_0_T2012_1UF/6.3V/T2012 | CTB21 |
T2012 | CT2012_0_T2012_10UF/6.3V/T2012 | CTB34 |
T7343 | CT6032_T7343_330UF/16V | CTB7 |
TH3_2S6_0 | MTH_P1_D0.6X12_TH3_2S6_0_GND | MTH1;MTH2;MTH3;MTH4 |
TP0_8-SMD | TP_TP0_8-SMD_TP | TP1;TP2;TP3;TP4;TP5;TP6;TP7;TP8;TP9;TP10 |
TP0_8-SMD | TP_P0_0.8_D0_TP0_8-SMD_TP | TP11;TP12;TP13;TP14;TP15;TP16;TP17;TP18;TP19;TP20;
% ~6 `4 q& C3 UTP21;TP22;TP23;TP24;TP25;TP26;TP27;TP28;TP29;TP40;
$ E! |" L7 S$ S& [% CTP41;TP42;TP43;TP44;TP45;TP46;TP47;TP48;TP49;TP50;
: c; [8 _8 q5 D6 R+ RTP51;TP52;TP53;TP54;TP55;TP56;TP57;TP58;TP59 |
TP0_8-SMD | TP_P0_0.8_D0_TP0_8-SMD_A_CAMDAT | TP30;TP31;TP32;TP33 |
TP0_8-SMD | TP_P0_0.8_D0_TP0_8-SMD_A_FIELD | TP34 |
TP0_8-SMD | TP_P0_0.8_D0_TP0_8-SMD_A_CAMPCL | TP35 |
TP0_8-SMD | TP_P0_0.8_D0_TP0_8-SMD_A_CAMVSY | TP36 |
TP0_8-SMD | TP_P0_0.8_D0_TP0_8-SMD_A_CAMHRE | TP37 |
TP0_8-SMD | TP_P0_0.8_D0_TP0_8-SMD_A_CAMD_1 | TP38 |
TP0_8-SMD | TP_P0_0.8_D0_TP0_8-SMD_FLASH | TP39 |
TP0_9-TH | TP_TP0_9-TH_GND | TPH1;TPH2;TPH3 |
TSSOP16P-0_65-5X4_4 | SN74CBTLV3257_TSSOP16P-0_65-5X4 | U25;U26 |
TSSOP48P-0_5-12X6 | SN74AVCA164245DGG_TSSOP48P-0_5- | U27;U28;U32 |
TVSOP16_W6_4_E0_4 | SN74AVC8T245-DGV_2_TVSOP16_W6_4 | U15 |
USB_CON_A | USB_SINGLE_A-TYPE_HOST_2_USB_CO | CON4 |
USB_MINI_AB | USB-MINIAB_0_USB_MINI_AB_USB-MI | CON5 |
