查看: 127|回复: 2
6G无线网络研究白皮书:愿景/使能技术与新应用范式
发表于 2022-6-21 10:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
前言................................................................................................................................................... I
3 a  C% P6 o* M' ^7 {目录.................................................................................................................................................III! E  s6 S. z+ _1 U0 M! P3 t
图目录..............................................................................................................................................V' N6 v1 q3 q* W: Z0 F
表目录.............................................................................................................................................VI
& y8 U9 L" y/ T6 h6 u6 ?一、6G 无线通信网络的发展背景.................................................................................................1. }7 `# _4 D: h. h
二、6G 性能指标、应用场景和垂直行业应用示例.....................................................................5
+ w0 a1 _$ `& b+ j; q& M2.1 6G 性能指标和应用场景...................................................................................................55 }6 a; k' N4 h+ K2 i" v7 y0 {
2.2 垂直行业应用示例............................................................................................................8' s. G/ U3 P" C1 Y4 `( w% \
2.2.1 云虚拟现实.............................................................................................................83 A( ?* j6 @1 N8 w5 G7 i# }+ R- P5 [
2.2.2 物联网工业自动化...............................................................................................10- B, ~  q- b# M) q
2.2.3 蜂窝车联网...........................................................................................................11( h5 ~1 _4 _, C8 y' ?
2.2.4 数字孪生体域网...................................................................................................13
4 k: r: E  r8 N$ P  D" u2.2.5 高能效无线网络控制与联邦学习系统...............................................................15& B7 W$ ^9 |- m" s: ~5 [( i
三、6G 使能技术...........................................................................................................................17; x  a5 {* [$ s% v+ t3 B! z% E
3.1 6G 空口与传输技术.........................................................................................................17
# X; ]) U! D% X$ q' ]; z4 U3.1.1 新的波形设计.......................................................................................................17' b2 @5 N* A$ V$ B4 }7 H$ s. J. N, ^
3.1.2 多址接入...............................................................................................................19
* r$ N  S; n3 G/ B- Q! ~* M0 ]3.1.3 信道编码...............................................................................................................20* t$ g7 ~+ ]  O; P2 ^! G+ Y' S7 ]# ~
3.1.4 无蜂窝大规模 MIMO ..........................................................................................24
1 \. R" o- |8 T& ^# |0 R9 y" z3.1.5 动态智能频谱共享与接入...................................................................................25) H0 e* _! k& B$ {
3.1.6 基于区块链的无线接入网络...............................................................................26
. {. N9 x% w& Z+ i3.1.7 光子定义无线电...................................................................................................27
9 J. ?, {$ Z  g) _9 q3.1.8 关键任务 uRLLC..................................................................................................29
1 g) H& R1 Y1 Q( d; v8 ^' U* r& Q- @3.2 6G 网络架构.....................................................................................................................30
8 @; s2 b- V+ [8 L3 o3.2.1 软件定义网络/网络功能虚拟化..........................................................................30
& h2 L* q. f8 w9 I! n6 y3.2.2 网络切片及其演进...............................................................................................347 ^. C; r3 |2 [, Z
3.2.3 基于服务的网络架构及其演进...........................................................................35. H7 o- D! g. [6 z( |9 A
3.2.4 认知服务架构.......................................................................................................36
! Q. Y0 d: E/ ?9 h4 c+ {3.2.5 深度边缘节点和网络(DEN2) .........................................................................37
  L! Z# T8 j- \/ q0 ]; \& I3.2.6 无蜂窝架构...........................................................................................................38# {, `6 M. U3 i5 N9 i5 b
3.2.7 云/雾/边缘计算.....................................................................................................41; R  y* _1 E% k) h& G
四、6G 新的范式转变...................................................................................................................457 b9 R" ]5 f% r8 s6 Y; N
4.1 全覆盖:空天地海一体化网络......................................................................................45
: A; g5 F5 G, v8 h6 ]  \5 ^  u4.1.1 卫星通信网络.......................................................................................................45* _0 u, z, o: {6 ~3 J8 D
4.1.2 无人机通信网络...................................................................................................46( K% H+ m7 D4 Q6 l% ?
4.1.3 海洋机器类通信网络...........................................................................................48- n, S% \% M+ T" g( i9 v
4.1.4 空天地海一体化网络...........................................................................................50
- a; {9 L, n4 y- g$ d! X8 _# T6 ^4.2 全频谱:Sub-6 GHz、毫米波、太赫兹、光频段........................................................53
, N6 H2 u, x0 u# l4.2.1 Sub-6 GHz 频段.....................................................................................................53
9 k5 N& w  i3 ^4.2.2 毫米波频段...........................................................................................................54
& y# t6 G7 z% e- U& ^' @2 [4.2.3 太赫兹频段...........................................................................................................55
# b& P5 b, q8 Z) }4.2.4 光频段...................................................................................................................584 ]9 i% o5 F' y) P
4.2.5 5G 及 5G 之后的信道测量与模型.......................................................................60# G( B% W% J5 R) W/ F
4.3 全应用:AI 使能的无线通信网络.................................................................................65
4 o' `8 ?! n5 I. Z+ ~, q7 L4.3.1 AI 及机器学习技术概述.......................................................................................65
2 u" \; R* w( d4.3.2 物理层应用...........................................................................................................661 k6 C7 C. J% [+ f* p+ }6 x9 y" `
4.3.3 上层应用...............................................................................................................68
9 j6 O; H' C: Q# G1 D7 {' M& h4.3.4 资源分配应用.......................................................................................................69
) a6 H' M+ L+ k- J4.3.5 智能内生网络(IEN)........................................................................................714 B) r/ }6 M& i
4.3.6 面向 6G 的信息、通信与数据技术融合............................................................72
* w! Z9 q/ e$ e+ Y9 u5 O% |1 }7 _4.4 内生安全..........................................................................................................................74( p. f: U* `( W8 E# r4 z: X
4.4.1 现状和主要问题...................................................................................................74
6 [1 `1 H8 P; v4.4.2 6G 中的网络安全隐患问题..................................................................................77
! v, u2 p; E, ^( y( ~+ W4.4.3 6G 网络安全和隐私问题的可能对策..................................................................78
1 r1 Z  L8 ~* b+ g/ a) s2 `3 u9 K五、总结与展望.............................................................................................................................819 c1 s5 R. l' H& D- p( y0 }  z
六、附录.........................................................................................................................................83
; n5 }! c% i7 M5 v; G2 e% |6.1 缩略语..............................................................................................................................83
9 H6 r# H# B- r. K! r  P; p参考文献.........................................................................................................................................929 ]. J8 w, U% w9 K3 K
9 W& z$ T: A4 _3 B3 p0 p6 Z一、6G 无线通信网络的发展背景+ ~4 U0 p! P! D0 s
自 2020 年起,第五代(5G)无线通信标准化工作进入尾声并开始在全球部署。5G 的三大应用场景包括增强型移动宽带(eMBB)、大规模机器类通信(mMTc)与高可靠低时延通信(uRLLC)。5G 的关键性能指标(KPI)包括 20 Gbps 的峰值速率、0.1 Gbps 的用户体验速率、1 ms 端到端时延、500 km/h 的移动速度支持、每平方千米 100 万设备的连接数密度、10 Mbps/m2 的流量密度、3 倍于第四代(4G)无线通信系统的频效,以及 100 倍于 4G 的能效。业界已提出了多种关键技术来达到 5G 的性能指标,例如毫米波(mmWave)、大规模多输入多输出(MIMO)、超密集网络(UDN)等。6 G7 m( ^* ~& Y, ^7 Y
但是,5G 将不能满足 2030 年之后的未来网络需求。研究人员开始着眼于第六代(6G)无线通信网络的研发。5G 的一个显著特点是低时延,更准确地说是保障/确定性时延,这需要通过确定性网络(DetNet)来保障未来用例需求的准时、准确的端到端时延。6G 对时间和相位同步的精确度提出了更多更高的需求,这是 5G 所不能满足的。除此之外,6G 还将提供接近 100%的全球覆盖、亚厘米级的定位精度和毫秒级的定位更新速率以满足未来应用需求。由于 5G 网络仅局限于一些典型场景,某些偏远地区还不能很好地覆盖,限制了无人驾驶等应用。非陆地网络,特别是卫星通信网络,由于其成本低、无缝接入、泛在服务能力的优势,可以作为陆地网络的有效补充。无人机通信网络由于其快速响应的特点,在严酷艰难的环境中尤为重要。海洋通信网络可以为船只提供高质量的通信服务。5G 毫米波可以提供 Gbps 级的数据传输速率,但对于高质量三维(3D)视频、虚拟现实(VR)、虚拟现实与增强现实(AR)混合等应用,需要 Tbps 级的数据传输速率,太赫兹(THz)和光频段将是可用的候选频段。由于面临大量天线单元、大带宽、新的服务需求产生的海量数据,6G 网络需要借助人工智能(AI)与机器学习(ML)算法,实现一系列智能应用。网络自动化将在多个方面进一步提升网络的性能,例如服务质量(QoS)、用户体验质量(QoE)、安全性、故障管理、能效等方面。( X9 D" @( o( k+ `1 p: ?
直到 5G 时代,网络流量仍然以视频或流媒体应用为主。除了上面提及的应用和需求,以 5G 触觉互联网应用[2]为代表的类机器人对象的无线网络控制(例如自动驾驶或工厂物流)将成为无线技术新的重要应用领域,但同时面临诸多挑战。当分析由这些应用产生的网络流量时,许多移动终端必须共享传感与控制信息,这给中央式控制系统带来了巨大负担。目前,基于 AI 的分布式控制系统正受到越来越多关注,其中联邦学习被认为是一种可行的方法,数据集相关算法分布于移动终端上,聚合学习在云端完成。这一应用产生了一类全新的网络流量,具有大带宽和极其多样的时延需求。这类应用以及相关的 AI 应用将很有可能主导 6G 的网络流量需求。这是一片未知的探索领域,机遇与挑战并存!与 5G 网络相比,6G 无线通信网络有望提供更高的频谱/能量/成本效率、更高的传输速率(Tbps 级)、10 倍以上的更低时延、100 倍以上的连接数密度、全自动的更高智能化水平、亚厘米级的定位精度、接近 100%的覆盖率,以及亚毫秒级的时间同步。新的空口与传输技术对于获得高频效和高能效十分必要,这包括新的波形设计、多址接入方式、信道编码方案、多天线技术,以及这些技术的有机结合。同时,需要设计新的网络架构,例如软件定义网络(SDN)/网络功能虚拟化(NFV)、动态网络切片、基于服务的网络架构(SBA)、认知服务架构(CSA)以及无蜂窝架构等。1 I9 k; v1 d" b! e- Y1 s9 @
另一方面,软件化伴随着相应的代价,正如我们从 5G 部署所得知的一样。商用现成品(COTS)服务器的使用与虚拟化无线接入网(RAN)中的特定领域芯片带来了能量消耗的大幅增加,由此需要更为高能效的新对策。虽然 5G 网络消耗的能量多于 4G 网络,但是提供了更大的带宽,从而使得 5G 传输单位数据使用的能耗小于 4G。因此,新一代无线网络的能耗不应超过上一代的能量需求。为此,6G 需要新的计算范式来获得软件化的所有优点而不增加总体能量消耗。以云计算、雾计算、边缘计算为代表的计算技术对于保障网络韧性、分布式计算与处理能力、低时延与时间同步十分重要。为了解决 5G 包括短包缺陷在内的限制,提供高可靠性、低时延、高传输速率服务、系统覆盖率、万物互联(IoE),满足 2030 年及之后的移动通信需求,6G 网络必须将以人为中心作为发展愿景,而非以机器、应用或数据为中心。为了满足这些需求,6G 无线通信网络将会产生新的范式转换。我们对于 6G 网络的发展愿景如图 1 所示。首先,6G 无线通信网络将会是空天地海一体化网络,用于提供深度全球覆盖。卫星通信、无人机通信、海洋通信将极大扩展无线通信网络的覆盖范围。为了提供更高的数据传输速率,包括 sub-6 GHz 频段、毫米波、太赫兹、光频段在内的全频谱资源将会被充分挖掘。为了实现全应用愿景,AI 与机器学习技术将与 6G 无线通信网络高效融合以实现更好地网络管理与自动化。此外 AI 技术可以实现网络、缓存、计算资源的动态调配以提高下一代网络的性能。还有一个重要趋势是强安全或内生安全,包括物理层与网络层安全,这在构建网络之初就要考虑。垂直行业应用,诸如云虚拟现实、物联网工业自动化、蜂窝车联网(C-V2X)、数字孪生体域网,以及高能效无线网络控制与联邦学习系统将极大促进 6G 无线通信网络的发展。6G 无线通信网络概述如图 2 所示,图中给出了 6G 的各种性能指标、应用场景、使能技术、新的范式转换,以及垂直行业应用。
* V9 }- Z! u( B2 a( A% N0 u3 b
& T* `( g5 V: L8 Q5 ]- m+ z0 @9 m; [) L
6G研究白皮书.pdf
6.46 MB, 下载次数: 0, 下载积分: 威望 -5
发表于 2022-6-21 11:10 | 只看该作者
看一看,学一学。\(^o^)/~
发表于 2022-6-21 14:35 | 只看该作者
学一学。\(^o^)/~
GMT+8, 2025-7-28 13:06 , Processed in 0.125000 second(s), 26 queries , Gzip On.
