查看: 188|回复: 1
ZCC6908HV 替代MP6908 低边反馈
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-6-16 17:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    DESCRIPTION
    The ZCC6908HV is a Low-Drop Diode Emulator IC that, combined with an external
    switch, replaces Schottky diodes in high-efficiency Flyback converters. The chip
    regulates the forward drop of an external Synchronous Rectifier (SR) MOSFET to
    about 40mV and switches it off as soon as the voltage becomes negative. ZCC6908HV
    can generate its own supply voltage for battery charging applications with low output
    voltage or high side rectification applications. A programmable ringing detection
    circuitry prevents ZCC6908HV false turn-on during DCM and Quasi-Resonant
    operations.
    ZCC6908HV is available in space saving TSOT23-6 packages.
    FEATURES
    ● Operates in a wide output voltage range down to 0V
    ● Self-supplying for operation with low output voltage
    rectification without an auxiliary winding
    ●· Works with 12V Standard and 5V Logic Level SR MOSFETS
    ●· Compatible with Energy Star, 1W Standby Requirements
    ●· <30ns Fast Turn-off and Turn-on Delay
    ●· <100uA Quiescent Current
    ●· Supports DCM, Quasi-Resonant and CCM Operations
    ●· Supports both High-side and Low-side Rectification
    ●· Power Savings of Up to 1.5W in a Typical Notebook Adapter
    ●· TSOT23-6 Package Available
    APPLICATIONS
    Industrial Power Systems
    Distributed Power Systems
    Battery Powered Systems
    Flyback Converters
    GMT+8, 2025-8-1 01:24 , Processed in 0.109375 second(s), 23 queries , Gzip On.
